Since there appear to be quite a few visitors and members from non-German-speaking countries, I decided to write a little tutorial on how to flash the ciPhone 3G firmware to an "old" ciPhone. First of all, you need a flash cable, you CANNOT use the original USB cable that comes with the ciPhone. It is available here:
http://www.ipmart.com/main/product/China,4,Nokia8800,,NokiaN70,,NokiaN73,new,release,PDA,screen,big,than,old,model,,NokiaN73C,,NokiaN73 C2sim,,NokiaN73G,,NokiaN75,small,,NokiaN91,,Nokia6228PDA,,TecnoM280,,EverfoE591,,EverfoE713D,,Eve,,8 ,pin,COM,1,Cable,25895.php?cat=2185∏=25895
EDIT: I think the URL has changed, check this out:
http://www.ipmart.com/main/product/China,4,Nokia8800,,NokiaN70,,NokiaN73,new,release,PDA,screen,big,than,old,model,,NokiaN73C,,NokiaN73C2sim,,NokiaN73G,,NokiaN75,small,,NokiaN91,,Nokia6228PDA,,TecnoM280,,EverfoE591,,EverfoE713D,,Eve,,8,pin,COM,1,Cable,Compatible,25895.php?cat=2185%E2%88%8F=25895∏=25895
You also need software for flashing, you can download it here:
http://rapidshare.com/files/134495331/FlashTool_v3.748.0.rar.html
The Firmware APL216_V1.5_20080916, languages: English, Arabic, 2x Chinese:
http://rapidshare.com/files/149362063/APL216_V1.5_20080916___33521___20013___32321___38463_.rar.html
UPDATE!!! New Firmware:
New Firmware:
Version: APL216_PCB01_GPRS_MT6230_S02.APL216_V1_2_20080916.BIN
Build: APL216_V1.2_20080916.6230_06B_HW.2008/09/18 13:53.BUILD_NO.06B APL216
Languages: English, Spanish, German, Vietnamese, Thai
Edit: NEW LINK!!!!
http://rapidshare.com/files/153172083/M_Repair_MasterFull_CiPhone_3G_MTK6230_TH_Flash_Tool.zip.html
In order to have all the applications on the 3G firmware running properly, here are the original JAVA applications that come with the ciPhone 3G, after the whole flashing procedure is done, simply copy them into the "Java" directory on your TF-Card.
http://rapidshare.com/files/149623211/3G_original_files.zip.html
Once you have all this, the flashing can begin:
Go to your flash tool directory and start the "Flash_tool.exe" file.
Go to "File" - "Open Download Agent File", select the "MTK_AllInOne_DA.bin" file which is inside the "MTK FlashTool_v3.748.0" directory
Go to "File" -"Open Scatter-loading File", select the "scatAPL216.txt" file which is inside firmware directory. Edit: The name of the file could be different, it depends on which firmware your are flashing, but it's ALWAYS a txt file!!!!
Your Flash Tool should look something like this:
Switch your phone OFF, connect it with your PC via your flash cable, connect a 9V battery to the flash cable.
Press the "Download" button of the Flash Tool software, the software now waits for the phone to be turned on to start the flashing process.
Turn your phone on, flashing will start and it will take approximately 50 minutes to complete.
[FONT="]After flashing is complete, close the Flash Tool software, turn on your phone and enjoy your new firmware
EDIT: After Flashing the "[/FONT]APL216_V1.5_20080916" Firmware, you need to do a "Pen Calibration" and the language will be Chinese, so here's a little "step-by-step" instruction:
New Firmware:
Edit: NEW LINK!!!!
