Meizu MX3 - 5,1 display ( 1920 x 1200 p) Samsung Orion 5410 Octacore ????
Manu-M3
Meizu Fanboy
Das liegt alles nur einzig und allein am Homebutton(den HTC z.B von Meizu kopiert hat!!!).
Natürlich sehen viele ein Meizu als Iphone, aber Klon?
Klon ist ein zu krasses Wort,zumal auch das Iphone nicht wirklich jedes Design-Element zu 100% selbst entworfen hat.
Das Iphone 4 ging auch in andere Richtungen ;)
J
johndebur
etliche Fotos und erstes review ( 5 Seiten ):
http://news.mydrivers.com/1/274/274748.htm
Übersetzung
Testfotos: http://news.mydrivers.com/1/274/274748_4.htm sieht klasse aus :)
Dual Quad Core 5.1 inches screen Flyme 3.0 Meizu MX3 Reviews
Review summary: After nearly a year of precipitation, Meizu MX3 finally came to our side, perhaps when you first saw the real machine because of the kind of familiar and somewhat regret, but when the real start to use after a day, I believe you will experience to changes in its various aspects. 5.1 inches 1800 × 1080 pixel screen on the data are indeed very wonderful, you can display it no unambiguous terms, and now we can not hastily conclude that it is the most appropriate, best big-screen smart phone, but at least vision and feel, etc., the Meizu MX3 does have its unique.
In addition to external things, Meizu MX3 Another highlight is Flyme 3.0, flat design, UI interface, give a refreshing feeling, practical gesture is to become the crowning touch. Overall, Meizu and MX3 are "no change", still focus on experience, still walking the fine line, from the quality and intentions extent, Meizu MX3 can definitely among this year's many flagship among the best.
5a5f83c97a9c44c780c45a5b44d80f25.jpg36fa93be4e1a41ac83a9885f175e2667.jpgbc4914d89c934392a32d7a4aa43870bb.jpgfbb54e0909ff4fbcbe206c9cf5fdab71.jpgs_1d33fbf8907647c99ec9751a74f10c56.jpgs_5deccd456b2d473db97a94824cae3063.jpgs_9c1140e50cd544e989efe290fc88e0ae.jpgs_9e8053fd9a494fe3bdb0716e4d4875b6.jpgs_27d18e1056eb4ea5a2c8c6691e9aaf48.jpgs_30dce3995a934a1ab5e386a7c5b97687.jpgs_55d41f4f5f044a13920879e9ce66020c.jpgs_55ff29a471ae44d3b7fae6afc5d3d038.jpgs_84c54c7055b448cbb85cae8a8b06266d.jpgs_35362becad8c4d6dbb935e7bbea29520.jpgs_56295fe6a7a34ff7bbdbb02106ed66f0.jpgs_a0446bf1a6d540cda6843c62e76f6551.jpgs_a986e899f11c475e974cea10ac1f0bfb.jpgs_abfa41a5d9a3416a963356aaf0ffd188.jpgs_ae9cbdbc79a54cab9237a96404bf7628.jpgs_b35224f5170643b4977040483173cb04.jpgs_d1259edd4bd94fa99c6479288467fe10.jpgs_d614244a99cd40baa8c39c179ac9900a.jpgs_ec8117fe44584111998a73fc99dc4e5d.jpg
Hier noch ein video review, allerdings chinesisch:
http://www1.pconline.com.cn/mobile/vreview/20130904meizuMX3/
J
johndebur
noch ein review von PConline.
da werden auch die SAR Werte und alles getestet
大屏手机的逆袭之战 魅族MX3详细评测 PConline
Übersetzung
Wärmebilder: http://mobile.pconline.com.cn/344/3449578_5.html
● Fever life
MX2 heat problem has been very serious, until now still not resolved, then the MX3 how do? we have also prepared a three hours of high intensity using the test, the test machine is not open any power-saving mode, the screen brightness automatically medium. As the mobile phone is the engineering version of the reason, the installation of several large games have appeared unable to open or second retreat of the phenomenon, so we have a big game instead of using a small game, the game is "the temple fled a courage edition." When tested at room temperature is about 22 degrees Celsius, the video playback using the phone comes with the player (ie hardware decoding). After testing, we get the following data:
Meizu MX3 heat endurance test (Medium automatic brightness)
Hardware to run sub-30 minutes 46 degrees (positive), 47.5 degrees (back) 15%
Big game 1 hour​
33,34
22%​
1080P video playback one hour​
35,32
12%​
Network Application 30 minutes
32,31
6%
( soll wohl Front heissen )
You can see the machine in a high-load operation is still a huge amount of heat, heat up the mobile phone is also relatively fast, thermal obvious fever on the phone half of the region, in the future if you use this phone to play the big point of the game will be very hot mobile phone . In dealing with some small games or easy task is called when the A7 1.2GHz processor architecture, such as brush microblogging, watching videos and the like, the phone can heat control is still doing quite good. Energy consumption, Meizu MX3 done this quite good, the hardware running points, video playback, battery life while surfing the results are very good. Below we posted strong overall quality HTC One heat endurance performance, for your reference.
HTC One Life fever test (automatic brightness)
Hardware to run sub-30 minutes 36 degrees (positive), 37 degrees (back) 24%
Big game 1 hour​
39,38
33%​
32,33
18%​
Network Application 30 minutes​
34,35
6%​
[HR][/HR]
Meizu MX3/MX2 parameter comparison
Phone Model Meizu MX3 Meizu MX2
CPU Intelligent 8-core processor Exynos 5410
(A15 Quad-Core 1.6GHz + A7 four-core 1.2GHz, 28nm HKMG process)
MX5S quad-core processor (A9 1.6GHz, 32nm HKMG process)
GPU PowerVR SGX 544MP3 (three-core 533MHz) Mali-400 MP
RAM 2GB DDR3 dual-channel low-power (bandwidth of 12.8GB / s) Dual Channel 2GB LPDDR2
ROM 16GB/32GB/64GB / 128GB does not support extended (support more than 4GB file copy) 16GB/32GB/64GB does not support extended
Screen 5.1 in. New Mode2
1800x1080 resolution 415ppi
CGS, 85 ° wide viewing angle, all fit, TOL
2.9mm frame (with black bars)
4.4 in. New Mode2
1280x800 resolution 347ppi
Fully fit, TOL
3.15mm border (with black bars)
Webcam Sony back-illuminated 8 million pixel camera, the second generation of blue glass filters, F/2.0 aperture, up to 20 frames / second continuous shooting
2.0 megapixel front Sony back-illuminated camera 1080P
8 million pixel back-illuminated camera, 9-speed continuous shooting, F/2.4 aperture, blue glass filters pre 920,000 pixel back-illuminated camera 720P
Operating system Flyme OS 3.0 based on Android 4.2 Flyme OS 2.0 based on Android 4.1
Dimensions Weight 139.0 × 71.9 × 9.1mm 143g 124.9x64.9x10.2mm 142g
Battery 2400mAh (Sony lithium polymer battery, not removable) 1800mAh (not removable)
Network GSM / GPRS / EDGE / WCDMA / HSPA + GSM / GPRS / EDGE / WCDMA / HSPA +
TD: GSM / GPRS / EDGE / TD-SCDMA / HSPA
Type of SIM card Micro SIM card single card Micro SIM card single card
Built-in chip Wolfson WM5102 audio decoder chip, Fujitsu Quad ISP,
Three wheat Noise Reduction, Smart PA speaker chips
Speech noise reduction, independent audio decoder,
Independent photographed image processing chip
Extensions S / PDIF OUT, OTG, MHL
(Some models support NFC, NFC support to WiFi Direct Connect)
Positioning means GPS / A-GPS / GLONASS, inertial navigation, electronic compass (new generation GPS chip, signal enhancement of 25%, saving 50%) GPS / A-GPS / GLONASS, inertial navigation, electronic compass
Starting price 16GB/2499 yuan, 32GB/2699 yuan,
64GB/3099 yuan, 128G/3999 yuan (bare metal)
16GB/2499 yuan, 32GB/2999 yuan,
64GB/3999 yuan (bare metal)
Manu-M3
Meizu Fanboy
Ich finde 46°C,wenn es die Höchsttemperatur ist ziemlich gut!
Mein MX2 haut bei MHL-Verbindung bis zu 53°C raus!
Und danke fürs posten John.
Gesendet von meinem M040 mit Tapatalk 4
Manu-M3
Meizu Fanboy
AW: Meizu MX3 - 5,1 display ( 1920 x 1200 p) Samsung Orion 5410 Octacore ????
Habe vor wenigen Minuten eine Beta fürs MX2 bekommen.
Könnt euch mal paar Screenshots anschauen(Large Statusbar Patch von Kingsonwong noch drauf).
Mehr darf ich nicht zeigen,aber wer mag kann sich ein Themen im Meizu Store runterladen das die Icons und Wallpapers auf 3.0 setzt :)
Fork
47.5 degrees (back)
ist mir dann für den für OpenGL ES 3.0 zu schwachbrüstigen "PowerVR SGX 544MP3 (three-core 533MHz)" gegebenenfalls doch zu warm, außerdem kommt das MX3 ohne LTE. Das sind für mich trotz toller Kamera mit f2.0 ausschlaggebende k.o.-Kriterien, dass ich mich weiter nach einem für mich zukunftsträchtigeren Gerät umschauen werde. Ich schiele derweil nach dem LG G2, aber Weihnachten ist ja noch ne Weile hin ... ;)
Manu-M3
Meizu Fanboy
Was hat denn das S4 und das G2 für einen drinne?
Hands-On von MobiletelefonRU:
[video=youtube;nJWEiKBJYOs]https://www.youtube.com/watch?v=nJWEiKBJYOs&feature=youtube_gdata_player[/video]
Lässt auf eine weiße Version schließen;)
Mülle
danke für das Video ;) die Russen haben es gut... können einfach so in einem Laden ihr Meizu kaufen :thumb_up: nicht wie bei uns wo man das Handy aus dem AUsland bestellen muß :'(
Also für mcih brauchen die keine komplett weiße Version!! Ganz im gegenteil ich finde den Kontrast schön und würde das Phone nciht anders haben wollen ;)
Nur mal eine Idee... gibts auch gute Russische shops bei denen man das Meizu bestellen könnte?? Wenn ja wie sieht das mit Zoll und Versand aus??
J
johndebur
Wie ist das eigentlich mit dem Google Play store , ist der im Flyme OS mit drinnen , oder muß man das nachinstallieren ?
Manu-M3
Meizu Fanboy
Sowas ist bei Meizu alles drinne :)
Alles von Google ;)
Zu teuer ;)
Teurer als aus china ;P
Mülle
Ok na wenns da teurer ist als in China dann verwerfe ich die Idee mal wieder :)
Wie ist bei Meizu eigentlich das GPS?? Ich würde sehr gerne Runkeeper nutzen und man ließt ja doch immer mal wieder von Chinaphones die es nicht so mit Runkeeper im speziellen und mit GPS im allgemeinen haben... Habe bis jetzt aber noch keinen hier gesehen der ein Problem mit seinem Meizu hat... Was aber auch daran liegen kann das Meizu wohl nicht so wirklich stark vertreten ist hier im forum?!?
Manu-M3
Meizu Fanboy
Ich nutze GPS kaum,aber hab noch nie eigentlich von Problemen gehört auf MeizuMe,Gfans oder der offiziellen BBS.
Bei mir wenn ich es nutze läuft eigentlich immer alles glatt:)
Ich kann das aber für dich auch gerne testen,wenn dir das wichtig ist.
Mülle
Ach quatsch extra testen brauchst du das nicht ;) ich kann zur not auch ohne gutes GPS leben :p wäre halt nur cool wenn bei einem doch recht teuren Phone alles gut funktioniert...
Aber wenn sich keiner in den Meizu Foren meldet dann wird das auch nicht so das Problem sein!! Wenn ich bedenke wie oft hier im Forum einer wegen GPS Problemen postet ;)
Manu-M3
Meizu Fanboy
Das stimmt :grin:
Also man liest bei GizChina ja immer von Bugs etc bei Meizus Flyme Oberfläche.
Ich kann euch nur raten,auf deren geschwetz nix zu geben.
Mein MX2 ist das stabilste und bugfreieste Handy das ich jemals in den Händen gehabt hab.
Ich glaube der GizChina Redakteur ist halt Xiaomi Fan,und daher lobt er sogar MX2 Klone mehr als das Original :(
Manu-M3
Meizu Fanboy
Naja bei der 32GB Variante sinds um die 100€ teurer als beim Meizu Store...
Die müssen halt so teuer sein,ist für die selbst schwer zu überleben.
Und andere Shops sind noch teurer..
