Jiayu G4 - 1,2ghz MT6589 4,7" IPS HD720 display 8,2mm dick 1800mah / 3000mah Akku
J
johndebur
Am 6.7. gibt es die MT6589T 2GB Ram Version. Ist halt nur ein kleiner batch. naja :)
佳域G4高配终于来临 7月6日正式发售 mtksj
High with good domain G4 finally arrived officially on sale July 6
Now equipped with MTK6589 four nuclear program thousand dollars / thousand dollars below the number of wins, not the number of products have been launched various 6589 platform quad-core products manufacturers a few, but for the good domain phones, it seems a good domain G4 most users can be attracted attention. In the standard version of the Offering, after several rounds of official commitment earlier this month offering good domain G4 high version has finally arrived.
From good domain handset official news show, the first good domain G4 high version of the Offering at July 6 (Saturday) 11:30, quantity of 5,000 units for the thick electric white version, priced at $ 1329 (1299 +30), the same is 7 working days delivery.
As low with an upgraded version, both versions are beginning to increase performance OTG functionality and equipped with a more powerful MT6589T quad-core processor, good domain G4 high version and low version only difference now is the memory of different sizes, high version 2G RAM +32 G ROM using a large capacity memory, while the low-equipped version is 1G RAM +4 G ROM routine combination, can support 64G memory expansion. Specific Xiangxi specifications refer to the table:
With 2GB of memory and 32G storage space running the good domain G4 high version launched to meet the majority pursuit of "fever" Configuring the needs of users, all aspects of the aircraft configuration called mainstream functions are more comprehensive, there will be late slimmer thin electric version will be introduced.
Antihero
Bin neu im Forum und habe mich nach vielen Stunden des lesens für die Jiayu Phones entschieden.:thumb_up:
Wobei ich immer noch unschlüssig zwischen dem G3S und dem G4 bin. (Tendenz zum G4)
Bin zwar ein Chinaphones Newbie habe aber schon mal was von Rooten etc. gehört und traue mir das auch zu.
Aber irgendwie habe ich immer noch viele Fragezeichen.:umnik:
Wann wird denn das G4 Advanced lieferbar sein?
Scheint mir dann am ehesten die optimale Version für mich zu sein, schneller Prozessor, ausreichend Speicher und ein großer Akku.
Was ist der günstigste Preis bei einem vertrauenswürdigen Shop?
Habe da bisher 271 $ bei boxwill incl. DHL Versand gefunden. Sind die vertrauenswürdig?
Ist es ratsam gleich zu kaufen oder noch ein paar Wochen zu warten?
AW: Jiayu G4 - 1,2ghz MT6589 4,7" IPS HD720 display 8,2mm dick 1800mah / 3000mah Akku
Wenn ich mich auch wiederhole, ist zwar gut, aber Preis gehypt. Mein UMI X2 mit FHD 5 Zoll Speicher 2GB RAM 32 GB ROM war $10 USD billiger.
Ich würde das für dem Preis nicht kaufen und wenn schon klein, dann 4,5 ". Das kommt auch bald ... als T
http://www.mixeshop.com/jiayu-jyg4-thickbattery-2g-ram-32g-rom-mtk6589t-15ghz-quad-core-47-inch-hd-ips-retina-screen-android-42-13mp-camera-gyroscope-smartphone_p2594.html
Antihero
Das UMI X2 ist mir mit den 5" schon zu groß.
Außerdem soll der Rahmen beim UMI nicht so stabil sein, was bei mir schnell zu Beschädigungen führen könnte.
Da ich das Handy immer in der Gesäßtasche habe und mich dann auch öfters draufsetze.
Deswegen lieber Jiayu. :Mauridia:
Ich habs vor 2 tagen bestellt und bin nach langem suchen sicher, dass das jiayu g4 der beste Kompromiss aus Größe, Leistung, Qualität und Preis ist. Vor allem in Kombination mit dem großen Accu und dem stabilen Ramen ist super.
Und, für mich ein Entscheidendes Kriterium, das, Design ist modern und gefällt mir deutlich besser als das des doch schon etwas älteren G3s.
Und das Auge ist ja bekanntlich mit. Klar ist das natürlich Geschmacksache.
Und Ja, es gibt größere, kleinere, schnellere, preiswertere.
Aber meines Erachtens nicht in der Kombination. Und . Für mich ist 5Zoll einfach zu Gross.
Gespannt bin ich dann auf das GPS.
Werde berichten , wie das Navi im Rheinland funktioniert.
Gruss vom Cannonball.
Gesendet von meinen Nexus 7
hotwebnet
Gibt es nichts neues..... würde gerne das JY -G4 T Modell kaufen... bekomme es aber noch nicht.... oder kennt einer schon einen Shop.... mein Dealer in China sagt es kommt nächste Woche..... stimmt das. Gibt es für das g4 schon Android 4.2.2
Gesendet von meinem JY-G4 mit Tapatalk 2
Mein G4 ist angekommen.
Erster Eindruck ist erstmal Positiv. GPS eingeschaltert und nach 8 sec. Fix.
Sonst noch weiter nichts damit gemacht
Denn das Gerät kam leider ohne Root.
Und ich bin was das betrifft eher ein Laie.
Also, Ideen zum Rooten hab ich jetzt zwar schon. Allerdings sagen ja alle - ACHTUNG- vorher Backup.
Wenn ich denn nach ROM Backup suche lese ich oft - geht nicht ohne Root.:noo:
Eine Variante hier im Forum habe ich probiert, ist aber evtl. veraltet, ich komme auf jeden Fall nicht weiter.
Jetzt meine Idee. Da das Gerät ja "nackt" ist, bräuchte ich doch nur die Originale Jiayu Stock-Rom, dich ich dann z.B. im Garantiefall wieder zurückspielen könnte.
Wenn dann beim Rooten was schiefgeht, spiele ich das Backup zurück und gut ist.
Meine Frage ist: Wo kann ich denn das Originale G4 ROM downloaden??
Cannonball
Thx, werds heute abend ausprobieren
Gesendet von meinem Nexus 7 mit Tapatalk 2
Nö. CWM Recovery mit SPFlashtool flashen, und damit nen Full Backup auf die SD Karte gemacht
Jep, hab ich verstanden und krieg ich wohl auch hin.
Allerdings möchte ich gerne den Auslieferungszustand später evtl. wieder hinbekommen (Garantie?). Dann würde ich auch gerne die Original recovery.img wiederherstellen.
Wie kann die ich Stock Recovery.img sichern?
Cannonball
Doppelpost zusammengefügt nach 18 minutes:
habs gefunden :pleasantry:
http://forum.xda-developers.com/showthread.php?t=2332783
Cannonball
So ist jetzt der Zwischenstand,
habe über das Droid Tool und das SPFlash Tool nach dem INstallieren der Treiber ein Backup des Originalen Rocovery, Boot und Android gemacht.
Dann wollte ich über das SpFlashtool das CWM Recovery flashen.
Jetzt kommt der Flashtool Error 8038.
Gegoogelt - keine klare Antwort gefunden. Treber? Anber dann hätte ja das Backup nicht funktionieren können, oder?
Nee, so macht das keinen Spass.
Es ist alles schon extrem aufwändig für mich.
Ich werds jetzt lassen. Zu viel Zeitaufwand.
Das was ich wollte, über Titanium meine Apps auf mein neues G4 übertragen werd ich jetzt per MyBackup pro machen. Dauert zwar länger und erforder auch etwas nacharbeit - aber das geht zumindest,
Danke trotzdem für die Hilfe.
RalphSming
