G12 HTC Desire klon - Qualcomm , WCDMA, dual sim?
J
johndebur
die Qualcomm CPU ist wohl der neue Lieblingschip für die Klone :)
Hier ein Desire Clon mit der Qualcomm CPU, unterstützt 3G ( WCDMA ) und hat dual sim?
http://www.m8cool.com/znsj/67257.aspx
Cottage program G12 Dual 1:1 Qualcomm WCDMA standard is awesome!
Today just to see the machine, thought it was surprised to get the hand to the real machine! Qualcomm 7227, double the WCDMA standard, is said to be the operating system Android 2.3, 1:1 high wooden imitation of the G12 have! Can be used to play tomorrow, the day after the sky is expected to evaluating the video! We look greedy self! 2K is expected to retail for more than ... ah ... that blinded the price ... ...
Domestic smart phone, cottage G12, dual WCDMA, 3G
J
johndebur
hier mehr:
http://www.m8cool.com/znsj/67363.aspx
Domestic smart phone, 1:1 high copy G12, G12 cottage
Qualcomm WCDMA cottage most powerful 7227 G12 high imitation fruit according to multi-map
Yesterday put two machines in the market shot up today to get back, high-definition on the big picture decisive ah! Qualcomm 7227 600MHz, WCDMA standard, dual card dual standby, 3.7 inch WVGA resolution capacitive screen, supports multi-touch, very good thickness control, 500W-pixel camera, speed optimization is very good, smooth ah smooth, fine is money!
Battery capacity 1300 mA, dual card dual standby, WCDMA standard,, TF card does not support hot swap
If you do not consider the price, then this is definitely a very good machine very inviting! Appearance, workmanship, configuration, made ​​in the current smart phones are considered very good, of course, the price is also very "good." Tomorrow to evaluate yo
wienio
Was sehr interessantes für mich! Warte auf die erste Berichte...
Preis, Leistung und Akkuverbrauch würde ich mich noch interessieren :)
Viele Gruße
Wienio
J
johndebur
morgen will ja m8cool schon einen bericht machen. vielleicht nennen die auch den preis :)
Chocoball
Im Video gibt es im Statusbar 2 weisen SIM-kart ähnliche Ikonen. Aber was mich befremdet ist das dieses Klon ein HTC logo und Sense drauf hat also frage ich mich ob es wirklich ein Klon ist.
Im MU Forum sind auch schon die Ersten Probleme gemeldet. Kein Adobe Flash, RAM speicher ist nicht laut Spezifikationen aber es scheint auch das die GSM und 3G Verbindungen nicht stabiel sind.
J
johndebur
Benchmark test von m8cool:
http://www.m8cool.com/sjpc/67913.aspx
Run sub-989 can act as a WIFI hotspot WCDMA3G phone test
Look at the results of running points, total score 989 points, CPU3270, memory 719,2 D100, 3D249.
Equipment, system information, we can see which machine can act as a WIFI hotspot, which is different from the Android 2,2 Android 2.3 is an important aspect.
At this point, I believe that everyone on this machine have a more comprehensive understanding of the machine is a good machine, but the price is a bit high. In addition, according to industry sources disclosed that under the current Qualcomm W + G solution is not mature, the stability to be improved, you have your own discretion cheese.
dzenk
es gibt neulich auch G12 in einer anderen Ausführung, alle bestätigen Android 2.3, im Test hat sich doch anders ausgewiesen - also doch die 2.2 Version.
Es sieht überhaupt nicht schlecht aus. Hier noch eine Auswertung des Handys.
Mein nächstes Handy?:good3:
wienio
Hat es einer von Euch schon bestellt ?
G12-T schient schneller als normale G12 zu sein oder?
Kann jemand von Euch was zum dem Telefon aus eigener Erfahrung berichten ? Ich bin sehr scharf drauf :)
Boeck
Hallo ich habe mir das G12 bestellt!
Es sollte am Freitag da sein.
Hat schon jemand ein optimiertes ROM für das Handy?
Oder gibt es ein Seite auf der es besondere Tips dafür gibt?
Ich würde mich über jede Antwort sehr freuen!
Boeck
LorD_oF-W4r
würde mich ebenfalls interessieren wo du es bestell hast ^^
Zudem auch noch wo man denn das G12-t bekommt, da ich nicht wirklich was gefunden hab :resent:
moki155
Moin ....ich glaube die Benchmark Tests bei den Dingern sollte man etwas vorsichtiger betrachten. Was auffällt ist das die Dinger ihre Punkte immer im CPU-Bereich holen, weder I/O oder das Memory-Subsystem sind besonders gut. Und ich glaube einfach nicht das der alte Arm6 mit 600 oder 800 MHz soviel besser sein soll als die neueren Arms. Da werden alle Hintergrundprozesse aus sein beim benchen. Oder ich irre mich...kann ja auch sein. :)
Boeck
Hallo zusammen,
das Handy habe ich bei ETO gekauft: http://www.etowalk.com/AT&T-G12-Desire-S-Android-Dual-Sim-3G-WCDMA-WVGA_384899_USD.html
Das Handy funktioniert Einwandfrei!!!
Einzig die China Apps und die China Tastertur nerfen mich.
Hat jemand eine Ahnung wie ich diese Entferne buw. wo finde ich ein Clean ROM.
Wenn ich nächste Woche mal Zeit habe schreibe ich mal einen kleinen Bericht.
3G geht nur auf SIM 1
Vieleicht kann mir einer von euch jemand eine Info zu einem ROM geben.
Boeck
Dahmer
Persona non Greta
du kannst versuchen es zu rooten,mit z4root oder vielleicht mit superoneclick,dann titanium backup drauf- alles sichern und dann die nervenden progs einfrieren,
wo du eine andere rom herbekommst kann ich dir nicht sagen,vielleicht kann dir eto weiter helfen,
zur tastatur - mach die einfach ne andere drauf,es gibt genug schöne tastas
wienio
Mache vielleicht einen Benchmark und veröffentliche für uns ein Screenshot ...dann schauen wir, ob es so schnell ist wie auf der Seite gezeigt.
Was mich noch interessieren würde ... ist Akkulaufzeit.
Gast_
Moin,
ich hab heute mein G12 von FCT bekommen. Zumindest was die Tastatur angeht kann ich dir helfen: Lange in ein Textfeld drücken, Texteingabe ändern und von dem China Kram in Android Tastatur ändern.
Was mir sonst noch aufgefallen ist: Wenn das Handy mit dem mitgeliefertem Power Adapter läd, macht der Bildschirm zicken (also reagiert entweder nicht oder springt wie wild umher). Ist das Kabel abgezogen oder an einem normalen USB-Anschluss tritt das Problem nicht auf.
Boeck
vielen Dank für die Info mit der Tastertur!
Kann jemand von euch das China ROM bereinigen? z4root und Co haben bei mir nicht Funktioniert!
Wäre Super noch mehr Infos zu bekommen.
LG Boeck
