Vphone V1 624Mhz WM6.5 kapazitiver touch
J
johndebur
mal ein iphone klone mit Marvell CPU, mit 624 Mhz. Dann natürlich auch kapazitiver touch :) jetzt muß nur noch der preis stimmen :pardon:
gar nicht so übel :)
http://www.shanzhaiji.cn/mobile/20100723/18963.html
This is called Vphone V1 mobile phone is clearly the high imitation of Apple iPhone, but its not the latest target iPhone 4. Cool profile with Windows Mobile 6.5 operating system has not either substance, high-definition 3.5-inch 480x320px pixel capacitive touch screen is enough to make people remember when the Ciphone C6 cell phone.
Vphone V1 with Marvell PXA310 processor, clocked at up to 624MHz; memory with the more mainstream 256M (NAND Flash) 128m (DDR RAM); Another WIFI wireless Internet access and Bluetooth support. This hardware configuration in the high imitation iPhone, very rare. Further information about this machine please pay attention to this site.
Petteri
Das stimmt, Preis ist klasse...warum werden nicht mal ein wenig mehr Ram und Rom Speicher eingebaut?! Das ist schade....aber ist natürlich dann der PinPhone Killer! :)
J
johndebur
neues vom Vphone und viele Bilder, soll um die 1000 Jönns kosten:
http://shanzhaiji.cn/labs/20100727/19021.html
you see it 115 × 64 × 12.8mm of measurements,
It can be said Vphone v1 greatest feature is its 3.5-inch has a capacitive multi-touch screen, with the original Sharp LCD with a resolution of 320X480. As Ciphone C6 switch interface to create a two-UI who also appeared in V1, WM6.5 and iPhone OS's UI switch that Apple's smart phone in the cottage has been very common.
Vphone v1 adoption Windows6.5 OS, processor (CPU) is the Marvell PXA310, clocked at speeds up to 624MHz, 256M (NAND Flash) 128m (DDR RAM) body memory, maximum support 16G TF card expansion.
V1 is relatively thin in order to maintain body degrees, and there is no built-in GPS module, support TF card expansion, and WIFI wireless.
This capacitive screen WM / iphone Apple Dual smart phone UI Vphone V1 Huaqiang North now offer less than 1000 yuan, already a good value for money.
sind das 2 Speicherkarten?
Finchy
Ok, Danke Zap... Die Seite ist wirklich hilfreich ;)
Hat das Phone eigentlich auch Gps? Weil auf nem Bild sieht man ja wo man GPS auswählen kann. Und beim Multitoch- Zoom sieht es auch nich so verpixelt aus, wie beim Pinphone ;)
wär richtig gut, wenn der Zoom so wie beim Originalen wäre, wenn Gps und guter Multitouch zoom, dann muss das Phone wohl her ;)
MJD
aber was soll denn wieder die diese verdammte frontkamera? die hat da doch nichts verloren...
J
johndebur
glaube GPS hat es leider nicht, wenn die Übesetzung stimmt. nur komisch daß man auf den bildern was von GPS sehen kann.
SuperSpeMo
und wenn schon,dann gibt es eben nen externen empfänger...aber ich glaube kaum,dass das bei diesen specs für uns 114€ kosten wird....
Imperator
El grande Imperatore
das sieht wirklich sehr interessant aus, obwohl ich irgentwie eher vermutet hätte das nächste ding in die richtung wird eher was "androides"...
aber auch die iPhone UI schaut auf dem was da so zu sehn ist garnicht schlecht aus...
J
johndebur
hab mal gebaidud. glaube das ist deren Forum:
http://www.vphone.cc/
vielleicht hat man da dann mal auch so einen support wie im cifans forum. naja ist im moment nur einer im Forum registriert. Vielleicht sollten wir mal hallo sagen, damit es ein deutsches Rom gibt :)
Hier mal nen Schwung Bilder :)
j880001
