THL Monkey King 2 - MT6592 2GB Ram Gorilla Glas 13MP Cam
J
johndebur
Viel hardware info gibt es noch nicht, außer das es einen octacore haben wird.
设计有变化 疑似THL美猴王2代谍照曝光 mtksj
Design changes suspected THL Monkey 2nd generation Spy Shots
True eight -core MT6592 shortly after news came out , there THL Monkey King II generation design sketches appear on the network , the display will be similar to that of the machine -like round pebbles body, but the real situation with the previous design sketches unfolded style diametrically opposed , there have been suspected THL Monkey II generation real machine spy photos show , Monkey 2nd generation more than one generation of correct !
Outflow from GIZCHINA photos you can see, two generations , though still tough straight + rectangular shape, not the past in addition to a generation of upper and lower ends of the small curve , instead of a flat line , the overall style is more masculine, almost corner 90 degree angle . Furthermore fuselage style has also undergone a major change , the main camera onto the upper left corner , and flush the body , left and right sides using arc treatment , which will help handheld comfort .
On behalf of another with a different design , from engineering machine photos, the two generations is not unibody, but support remove the rear cover , which means you can replace the battery . According to sources, the aircraft will be added to the alloy material to create slimmer body .
THL phone after another official recently revealed some details of new machines , Monkey 2nd generation will be equipped with the third generation of Corning Gorilla Glass scratch resistant wear better , using MTK6592 eight -core processor, 13 million pixel main camera there may be shipped 2GB memory , front-facing camera is likely to still be 13 million pixels.
1-131116031A24a.jpg 1-131116031F3258.jpg 1-131116031G1438.jpg 1-131116031634Z8.jpg
J
johndebur
Ausstattung vom THL Monkey 2 . Angeblich auch im Dezember verfügbar.
NFC/硅负极电池/三代玻璃 THL美猴王2代亮点汇总 mtksj
NFC / silicon anode batteries / three generations Monkey 2nd generation glass THL Highlights Summary
Starting from the "old" V7, THL candied fruit phone 's smart phones and both are using the MTK chip position is very firm , the upcoming eight-core era THL is always in sync with MediaTek , the MT6592 is equipped with eight-core chip the product is named THL Monkey 2 generations, selling some of the characteristics of the exposure was 11 Recently the machine out , today we have to look at Monkey 2 Summary What are appealing on behalf of local concern .
Picture : After 13 million pixel front camera Monkey King was born , THL smartphone front camera specifications pulled a new level , and this advantage will be extended to two generations the same body . Monkey 2nd generation is still equipped with a dual 13 million pixel camera, but the hardware has been upgraded . 2nd generation dual cameras will use a smaller volume higher performance Sony stacked modules , 5P + blue glass filter lens , aperture increases to F2.0, and support for beauty , voice-activated camera and other features.
Screen: Monkey 2nd generation third generation joined Corning Gorilla Glass to provide better protection for the screen , scratch resistant magic performance greatly improved . Also the screen size is still 5 inches , with a resolution of 1920 * 1080 , using the OGS full lamination technology , PPI of 441.
Battery : THL Monkey 2nd generation battery capacity of 2700 mA , using a new generation of silicon anode battery technology, has a higher cell density , durability and better , thin body can do the same large battery .
Expansion: the new machine will support NFC, OTG and HALL switch , dual noise reduction wheat and other functions, in addition other sensors should be more comprehensive.
Design: Although it is an upgraded version of the Monkey King , but two generations with a new mold , shape more Founder atmosphere, tough lines and fashion sense , the aircraft reportedly thickness thin, and can be done to replace the battery . Alloy body with a pass , more texture , borders are narrower than a generation .
Hardware : THL Monkey 2nd generation aircraft equipped with MTK MT6592 is also a highlight , using the 1.7GHz frequency version of the main memory areas using a combination of high-capacity 2G RAM +32 G ROM 's . 2 generations of jelly beans will be the built-in upgrade OS, based on optimization from Le Frog OS5 , add numerous somatosensory operation , the interface is also more beautiful.
Reliable sources said THL Monkey 2 generation will be officially released in December , almost a big shake-up inside and outside the Monkey 2 generation will be ending this year THL phone products , in addition to blazing hot hand of eight-core platform , 2 generation of more integrated a high degree of concern currently a number of new technologies and new features, and the subsequent public will have more highlights .
highwind
Ist aktuell auch mein Favorite, das Design finde ich einfach super.
Unter "THL T100" findet man übrigens noch mehr zu dem Gerät
Bei einigen Anbietern ist es auch schon als "in stock" gelistet
na da bin ich ja gespannt :)
auch die preise wären interessant zu vergleichen :grin:
highwind
Habe grade mal mit dem Support von tinydeal gechatted... bei denen im Shop steht das Gerät auf "in stock", aber auf Nachfrage sagte man mir das, was ich bereits vermutete: ist nur Pre-Order.
Verfügbar werden soll es laut Aussage der Mitarbeiterin angeblich am 20 oder 21 Dezember, was sich auch mit den Angaben aus anderen Shops (z.B. Antelife und geeksbuying) deckt.
Kommt also für den Weihnachtsmann zu spät :hehehe:
J
johndebur
Laut mtksj ist das THL Monkey 2 offiziell am 10.12 erhältlich. Der Preis wurde noch nicht bekannt gegeben.
5英寸1080P屏八核 THL美猴王2代10日发布 mtksj
http://www.thl.com.cn/News/detail-535.html
5 inches 1080P screen eight nuclear THL Monkey 2nd generation 10 released
Approaching the end of mid- 2013 , each successive release of flagship product contests, Lenovo / Nubia / vivo / Jin 's flagship product brands have certainly superior flair for the other end of the finale of the second and third tier brands also have Aspect. THL THL candied fruit officially changed its name to the phone , the annual flagship product called THL Monkey 2 generation , internal model THL T100, prior to the official network , Published also public finally announced, this eight -core phone on the 10th of this month officially released .
Monkey 2nd generation core selling point has been " leaked" almost, the aircraft continued the Monkey King a tough exterior design , on behalf of more than one founder , around the body were designed to be relatively flat , the main camera has not outstanding. In addition it is only about 8 mm thickness , screen frame is also narrower than a generation , though slim figure , because of the adoption of new technologies , the aircraft battery capacity of 2700 mA .
As candied fruit wrap up 2013 mobile phone , the machine uses a high level of hardware configuration, functionality is also very comprehensive , focused and off the screen , camera and so on. The aircraft is equipped with a main frequency of MTK MT6592 1.7GHz eight-core processor , 5 inches 1080P resolution screen also joined three generations of Corning Gorilla Glass protection , 2G RAM +32 G ROM large memory . 2nd generation also supports NFC / OTG / Dual wheat Noise / HALL switch, optimized to run on Le Frog OS5 comes jelly beans OS, 3G network support TD-SCDMA/WCDMA double .
The previous generation due to the pre- 13 million -pixel high-definition camera won numerous concerns , and two generations continue to maintain this characteristic , and specifications stronger , THL Monkey 2nd generation dual front and rear 13 million pixel camera used Sony stacks CMOS sensor , 5P + F2.0 large aperture lens , camera performance should be better .
At first glance , THL Monkey 2nd generation almost all the others , the difference is only a moderate price only, not previously published , do you think the machine is to keep a generation of higher prices or will some of it ?
1-131206231600R6.jpg 201311210928183205.jpg 201311210928431472.jpg 201311210929031460.jpg 201311210929146454.jpg 201311210929234886.jpg
J
johndebur
Anscheinend ist der Verkauf vom THL Monkey 2 schon gestartet. Gibt eine international Version mit WCDMA + GMS und eine chinesische Version mit TD-SCDMA + WCDMA
售$309.99美元 THL美猴王国外开售 mtksj
U.S. $ 309.99 THL sale Monkey sale abroad
THL candied fruit phone THL year's finale product called Monkey 2 generations , although not yet officially listed in China , but recently the number of aircraft has landed online store started selling abroad , the international version is priced at 309.99 U.S. knife , about RMB 1880 yuan or so. Domestic version will be released today ( 10 May ) , the synchronization will enable new LOGO.
Monkey 2nd generation International Edition (THL T100) Specifications and domestic version without too obviously different , only slightly different network standard , international version supports WCDMA / GSM dual card dual standby , while the domestic version of the MIIT certified as TD-SCDMA + WCDMA dual-mode mobile phones.
Currently two generations Monkey King has more comprehensive information , this phone also has dual 13 million -pixel high-definition camera equipped , are used SONY stacked CMOS sensor + F2.0 aperture +5 P lenses , etc., 5 inches 1080P full lamination screen + Corning three generations of gorilla glass. Has MTK MT6592 1.7G high eight nuclear +2 G/32G memory configurations are supported features more comprehensive , NFC Near Field Communication , USB OTG , like many other functions , in addition thickness of about 8 mm machine built 2700 mAh battery capacity , run jelly OS.
THL priced products from the past speculated that the new version of the Monkey King 2nd generation domestic prices may be lower, the government has also made it clear that the price of the machine is not too 2K.
highwind
Es wurde heute released und diverse Shops haben es nun auch "in Stock"
Bin am überlegen ob ich es direkt bestelle oder erst noch Reviews abwarte... o_O
highwind
Hast recht...
Nachdem ich dann heute gelesen habe, dass die 8-Kern LTE Chips wohl auch schon Ende Januar (statt wie ursprünglich erwartet erst Mitte 2014) kommen sollen bin ich auch eh nicht mehr ganz so überzeugt. :(
J
johndebur
Sieht echt schick aus :)
比1代更加大气美观 THL美猴王2代官方图赏 mtksj
On behalf of more than a beautiful atmosphere THL Monkey 2 reward on behalf of the official map
July Monkey generation market, with around 13 million pixel true HD dual camera design, THL Monkey King series will soon be familiar, after a lapse of nearly five months, on behalf of the Monkey King 2 official debut.
2nd generation while maintaining double 13 million pixel camera high specification, further improves the camera hardware, dual cameras are Sony stacked with F2.0 aperture and so on. It also uses a MediaTek's new eight-core processor really MT6592, has five inches 1080P full three generations fit screen + Corning Glass / 2G +32 G memory / 2700 mA battery, configuration, support for NFC and so many other features.
The eight-core machine will be on sale on December 18, the sale of 1888 yuan.
1-131211001346.jpg 1-131211001358.jpg 1-131211001401.jpg 1-131211001406.jpg 1-131211001410.jpg 1-131211001414.jpg 1-131211001417.jpg 1-131211001421.jpg 1-131211001428.jpg 1-131211001432.jpg 1-131211001439.jpg
Die Seite von THL hat es nun auch offiziell im Program
http://mtksj.com/html/mtkshoujizixun/5909.html
http://www.thl.com.cn/meihouwang2
THL Monkey 2 official website released the 17th generation of the formal sale
JensK
Nachtrag: Ich habe das vor 3 Tagen bestellt, ich denke (hoffe), Mitte Januar sollte es ankommen. Ich kann dann mit dem Zopo C2 vergleichen und berichten.
Feierlein
stiller Mitleser
Habe mir letztes Wochenende auch ein thL t100s bestellt.
Gestern meine Trackingnummer erhalten.
1 Shipment picked up
2 Processed at Shenzhen Peoples Republic
Wird wohl dieses Jahr nicht mehr kommen :no2::noo::rofl:
Ich werde berichten.
Guten Rutsch ins Jahr 2014
JensK
Feierlein, wer kann denn liefern, wenn ich mal fragen darf ?
Ich hatte eins bei Mixeshop bestellt, aber die haben (siehe oben) kleinlaut nach 5 Tagen nen Rueckzieher gemacht.
JensK
Danke dir. Aber koennen die wirklich liefern ?
Antelife hats schon seit ein paar Wochen im Shop, aber die verschieben die "presell time" jede Woche aufs neue. Orientdeal hats auch schon seit 4 Wochen, aber auf Rueckfrage nicht lieferbar. Mixeshop hats nicht.
Chinavision hat leider keinen Treuhand Service wie Aliexpress oder Paypal (und da der Mixeshop immer noch mein Geld hat ...)
Edit: Haben doch Paypal ;)
Prick
