T-Mobile HD2 English Discussion Thread
petertrol
Is somebody out ther how test flashing the Android rom?
I would get the Android rom!!!
But i think there is the same Problem with the "old" screen or did somebody know if this is no problem?
Noha
are you going to try the rom in tmobile model?? if you are going to do i have a good tutorial how to do it. Tell me an ill share it.
g.romano81
To GeoBroker
I've tried but it doesn't work
Thank you
Regards
About How to flash Android ROM on T-Mobile please share the instructions petertrol
petertrol
Sorry but the instructions are for hd9 model but anyway i think its the same process for tmobile (is another mtk, so will be the same thing), anybody is going to try with tmobile??
GeoBroker
Hi peterol,
I'm also interested to try the android ROM, are there any instructions on how to do it that are tested?
Please share it.
@g.romano81
I´m so sorry. Now I have no more ideas. The Software runs at my phone correct.
Best regard´s
Noha
Anyone knows the pinout of the USB and what does the 2.5mm jack makes.
I dont think it is for data transfer i think he is crabed!
Petteri
The Problem is to find out Pin on 2,5mm jacks! So i doesnt want to Cut my flashcable, because its the only one i have!
GeoBroker
I have bought USB to 3.5mm Jack Data sync cable like in this link
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=300509963300&ssPageName=STRK:MEWNX:IT
Do you think it's the rigt cable?
Thank you for everything
I'll give you any info about my experience
I don´t know anything about this or other cables. I need a infomation witch cable works.
I have one more question about WiFi Remote Access: Do you have Internet access via WLAN with your T-mobile Phone at home?
@Petteri: Welche Kabel nutzt du denn zum flashen?
Gruß and regards
Rainer
GeoBroker
How do you know it doesn't work?
Have you tried it?
I think because this cable dosn´t support COM funktionallity.
The USB-COM bridging cable here is functionally same as the COM port data cable.
The USB data cables are using COM port bridging technique for software running. Due to the COM port number is self assigned by computer, it will vary with the computers to avoid conflict. Please make sure the required software can support a wide range of COM port numbers by consulting from the software supplier.
But it´s a different price between the two cables petteri 50€ and petertrol 9,12€. So witch cable???
And another thing is: Does Android 2.2 is running at our T-Mobile Dua Sim Phone?? It´s a risk. If it´s not running we can co back to WinMobile??
Regards
veralzasyf07
