How do you know it doesn't work?
Have you tried it?
I think because this cable dosn´t support COM funktionallity.
The USB-COM bridging cable here is functionally same as the COM port data cable.
The USB data cables are using COM port bridging technique for software running. Due to the COM port number is self assigned by computer, it will vary with the computers to avoid conflict. Please make sure the required software can support a wide range of COM port numbers by consulting from the software supplier.
But it´s a different price between the two cables petteri 50€ and petertrol 9,12€. So witch cable???
And another thing is: Does Android 2.2 is running at our T-Mobile Dua Sim Phone?? It´s a risk. If it´s not running we can co back to WinMobile??
Regards
