original firmware for flying 7100
N2k1
before i flashed this fw, i flashed another fw for feiteng n7100. the fw for feiteng makes my phone's touch screen goes like this
Nice to read!
it can boot up but the sound and camera don't work.
This is a small problem. So we can solve this.
when i got the original fw i flashed all the sound and camera all works but the touch screen still like that.
OK, so in the one firmware the digitizer works fine - but sound & cam are gone.
In the other firmware are sound and cam accessible - but digitizer is wrong?!
Ilut Ismail
no. both fw the touch screen is no good.
Doppelpost zusammengefügt nach 5 minutes:
ad the soft keys don't work
N2k1
Please make a logcat and a dmesg after booting.
adb shell "logcat -d >/sdcard/logcat.txt"
adb shell "dmesg >/sdcard/dmesg.txt"
adb pull /sdcard/logcat.txt
adb pull /sdcard/dmesg.txt
just pack the files with rar or zip and umload here.
N2k1
Strange!
Is this a 6577 or a 6575 device?
Is the firmware from a 6577 or 6577 device?
Why is there an iphonesubinfo2?
Your phone (better: your cpu) runs into thermal protection - but cpu wants to run higher than 1 GHz.
In this case some processes forced close.
You pressed home button and some times touch..
V/WallpaperService( 497): Delivering touch event: MotionEvent { action=ACTION_MOVE, id[0]=0, x[0]=438.18854, y[0]=868.09576, toolType[0]=TOOL_TYPE_FINGER, buttonState=0, metaState=0, flags=0x1, edgeFlags=0x0, pointerCount=1, historySize=0, eventTime=2378537, downTime=2378521, deviceId=0, source=0x1002 }
You repeat plugging phone on usb and remove.
Your phone tries to enable multi core cpu - but found 6575 (single core)
There are so much strange things... I guess, this is not fitting firmware for your phone.
But it is interesting: It runs!
Sorry for poor english - I hope you can understand my explanations..
Ilut Ismail
already ask. but he said he can't give it because i modified my phone and there's no warranty. i don't know if i will ever get it. he said he will try to get it from the supplier in china. but with so many phone out there in the market and this phone being the unpopular one i doubt i can get the fw.
tommy0815
@N2K1
you know that, you can write in build.prop what you want. You can say it is a iphone6 mit a MTK6699 so nobody cares *g
the software is definitly the correct one for his device!
here is the link of the Phone
http://www.fastcardtech.com/HDC-Galaxy-Note-2-7100
it says that it is 6589 but it is 6577! Don't know why in the logs it's listet as 6575?!?
Sorry don't know the problem :/
if you already done a factory reset and the trouble with the touch is still there.....and if you have really flashed (checked) all files in flashtool?!? Sorry, than i have no idea....
i would say that the touch has some defects :/
But you are now the third guy who has such kind of problems after flashing a wrong fw......i don't know... :(
tommy0815
i think it is not the problem with this fw!
my guess is that with flashing a wrong fw, you get a bug, which is still alive in the correct fw.......but why if you have flashed the WHOLE fw....i can't explain :(
N2k1
Try to boot with Vol+
Now you shouldenter the factory mode.
Here you are able to test all parts.
