Lenovo A750 - 1ghz MT6575 4" display - A60 Nachfolger
Chocoball
Ich habe das hier gefunden habe die Dateien auch schon:
1. Download recovery_etotalk_com.zip and unzip it to a folder.
http://www.4shared.com/zip/RUFEomdV/...otalk_com.html
2. Download and install the driver:
http://www.4shared.com/rar/VwNMH8r0/A750USBdrivers.html
3. Download the Smart phone flash tool:
http://www.4shared.com/zip/DtK6rn6_/..._v3120801.html
4. Unzip tool.zip to a folder.
5. Open the folder and run Flash_tool.exe
6. Click on Scatter-loading
7. Select the scatter file from recovery_etotalk_com folder (Point1)
8. Untake the Preloader option
9. click on download as shown below:
10. When you see the above message, click on yes to continue.
11. Now connect your phone to your pc by USB cable
12. Insert the battery and wait for a few seconds
13. You may see the yellow bar goes after a red bar, when you see the icon below, recovery has
been installed successfully.
14. Download the latest rom, here is the rom for example:
http://www.4shared.com/zip/AjBnl6Eo/...lang_V20_.html
15. Save the A750 S143 full multi lang V2.0 etotalk.zip to your sd card.
16. Unplug and reinsert the battery to your phone.
17. Press power for about 5 seconds then release and press volume up + volume down very
quick till the recovery menu shows as below:
18. If the menu not showing, but showing etotalk logo, please redo Point 17 till it shows.
19. Just do it as the photo above and then the photo below as steps: (browse the rom file)
20. When you found your A750 S143 full multi lang V2.0 etotalk.zip, press power key to confirm
the installation of rom. Volume up and down for selection.
21. When the rom has been upgraded, it will show “done”
22. Now use the touch key below to go back to the main menu and restart the phone as shown
like the picture below:
Das CWM Recovery kann ich uebersetzten lassen. Das einzige ist ich habe das noch nie ein FW flash gemacht :[
Chocoball
Ich habe die VCOM treiber Anleitung vom Forum benutzt aber komme leider nicht weiter wegen Fehler 1012. Hatte noch vielleicht Hoffnung met Android Commander aber kann da auch kein Verbindung zum Handy machen.
Chocoball
Treiber ist installiert, habe es mit Android Commander lösen können endlich funzt das Lenovo wieder. Allen Danke für die Hilfe :happy:
kuschy13
Beim Start nur noch Lenovo
Hallo, habe seit einiger Zeit ein Lenovo A750, welches schon gerootet war. Seit heute steht nur noch lenovo im Display, es läßt sich auch nicht mehr ausschalten. Es hilft nur noch Akku raus. Lautstärketaste und Einschalttaste drücken bringt das gleiche Ergebnis. Bin ziemlicher Anfänger und weiß nicht mehr weiter. Wie gesagt, dieser Zustand ohne ein Bedienungsfehler, einfach so. Danke im voraus.
Chocoball
kuschy13
Mein Menue ist leicht anders, ich komme auch ins Menue. Habe es versucht, aber kein Erfolg. Wie ist dies mit dem reset gemeint. Nach anklicken der einzelnen Programmpunkte öffnet sich eine neue Unterseite,was dann? Ich bin am verzweifeln. Kann man in diesem Zustand eine neue ROM raufspielen.
