iPhone 5s und 5c clones sind da.
J
johndebur
Die Japaner haben auch ein 5C klon herausgebracht :) Hardware ist aber nicht sehr prickelnd. koset 15490Y (109€)
Hersteller: http://iosys.co.jp/pb/iophone5-syoku/
真坑爹 这就是岛国的山寨iPhone 5C mydrivers
This is the true father of the pit island cottage iPhone 5C
Yesterday, there was news that appears on the Japanese market a product called ioPhone5 cottage iPhone 5C , at first glance it iPhone 5C almost exactly the same shape and color equally white, red , yellow, blue , green, several alternative , cottage more successful . But in fact this is just the appearance of it , from the Japanese media announced today the latest pictures of view machine is in a little pit father .
Nothing specific configuration changes , indeed MT6572 dual-core processor , 4 inches 854 × 480 resolution display , 512MB of RAM , 4GB of storage space body , 200,000 -pixel rear camera and a 3 megapixel front camera , runs Android 4.2 operating system that supports WCDMA / GSM dual sim dual standby and micro SD card expansion , of course, is also free to replace the battery .
Overall, though it is very similar and iPhone 5C , but overall was better than iPhone 5C large circle , this is the fault of the border . Besides the aircraft origin should be Chinese , IOSYS from Japan but only sales agents only.
The following are solicited for everyone of our aircraft , " Videos of " interested may wish to carefully compare .
s_2e9d47aa62614349b8703658347fb531.jpg s_5d64d4d6e1c349ceb04fc1d62b97f6e0.jpg s_7d4a9f80f5f44d6483670eec84197162.jpg s_75aa5785a52b4c6f99798e6db22813c1.jpg s_377a504a057640c2a618b43cb3ac6c32.jpg s_5130f25f66094b5781b8c55ea7fae3a4.jpg s_67611f20399c4256845a1cf5e9bf9a24.jpg s_991340347dec43a2bf0eccf63f2ddfa3.jpg s_bac9a198a9224e92b770594c08b6e909.jpg s_dc54383900234168ad307d4b7e4947f1.jpg s_e1ea58cb7fac476a95d1f7889050daef.jpgs_1d6b397bf13a4eedb65d32fbb54ecb89.jpg
noplan
GNO Member
Ja, für Spanien wollte sie für Free Shipping 40$ - klingt komisch...ist aber so:)
Habe jetzt auf eine deutsche Adresse umgeswitcht. Die ist nah genug an China dran, um DHL Free shipping zu nutzen:p
Squizzy
Hallo Zusammen,
Ich habe da auch mal ein Paar fragen als Neuling.
Gerne würde ich mir so ein Clone vom i5s Kaufen, jedoch stellt sich mir die Frage welche anbieter sind Seriös.
Es geht um dieses Handy:
http://www.dhgate.com/store/product/new-ios7-1-1-5s-goophone-i5s-3g-wcdma-single/176464085.html#ctabBox
Würden schon Erfahrungen mit den Anbietern ibaby888, EFIT gemacht?
Welche Erfahrungen würden schon gemacht mit dem Zoll, ich als Neuling habe keine Lust direkt beim ersten Import Post vom Apple oder so zu bekommen :)
Über ein Paar infoś eure Seite aus würde ich mich sehr freuen.
Mfg
efit ist einigermaßen zuverlässig. nimm auf jedenfall dhl express. ansonsten ist die wahrscheinlichkeit gecasht zu werden groß. ansonsten musst du mit den 19% steuern rechnen die drauf kommen. und wenn der händler den porto nicht expliziet auf die rechnung klatscht dann nehmen die einfach irgend so ein fiktiven portowert der deutlich höher ist und dann biste mal schnell bei 30% die du drauf zahlst ;)
washY
Ich persönlich würde keinen Clone momentan empfehlen. Beim i5s und i5c von efit ist das gps nicht gut. Teils ist das handy noch auf englisch (für mich zwar kein problem, aber so ein mix nervt). Das i5c läuft aber flüssig bei mir, jedoch ist der homebutton nur ein back button. Dafür passen original hüllen. Das i5s läuft etwas laggy (ein anderer launcher schafft anscheinend abhilfe, habe ich selbst nicht getestet. Zudem passte eine bei amazon bestellte hülle ganz knapp nicht (wohl nicht 100% maße). Bei beiden fühlt sich der homebutton relativ billig an. Hoffe der hält soweit aber. Verarbeitet sind sie ansonsten gut und mit original logos.
flocker
Habe gerade festgestellt das beim ankommende SMS oder Anruf es gibt keine Hinweis. Nicht oben oder unten. Ist das was in der Einstellungen?
Squizzy
gebe ich dir recht. diese kinderkrankheiten nerven und ich hoffe dass die da ne refresh version anfang nächsten jahres raushaun ;)
Squizzy
Es kamen diese n2 Versionen raus und ein goophone i5s
Gesendet von meinem HTC One mit Tapatalk
gifftstaub
Ich Danke euch beiden erst mal für das Tolle Feedback.
Mfg
noplan
GNO Member
Ich lasse meine bestellten I5er erstmal im Originalzustand und hoffe, dass sie einigermaßen laufen.
Wenn es zwingend notwendig sein sollte und es eine funktionierende Flashmethode gibt, würde ich noch einmal einen Flashversuch starten.
Mein erstes I5S war perfekt ohne Schwächen, es geht also. (leider habe ich es mit dem Flashtool zur Strecke gebracht).
hobbyrooter
schau noch mal in meinem thread, scheinbar bin ich ja nicht der einzige bei dem das gerät (Z5S von efit) gar nicht aufgeladen werden kann!
nimmt mich dann wunder wies bei dir aussieht wenns ankommt.
