Cuoco92
@Passienter
I'll try to answer your questions:
1. Does Wi-Fi autoconnect work flawlessly?
A) I haven't performed a deep test, but so far it works flawlessly
2. GPS ?
A) I haven't test it
3. Do the dualsim features work and does the 3G/4G work well (by that I mean does it not switch towers constantly and other stuff)?
A) There're some issues with the new modem (Roaming) but you can install a old modem to fix it and other issues :)
4. Bluetooth?
A) No problems until now
5. Touchscreen problems sometimes?
A) Normally not, but if it occurs, it is because you have a faulty touchscreen (Mine for example has the left side that is almost dead : p
6. Battery problems? (going from 50-60% to 20% in one time)
7. Does the rom update from within the rom or do I have to come here and install it manually everytime (sorry maybe n00b question)?
A) With a modded firmware you can't install officials updates. You'll receive ota updates from me :)
Releasing a new firmware, you have to download and install manually.
8. Does audio, microphone and cameras work - + well?
A) No problem until now. Some users says that it's a little bit poor. I can't confirm that :)
9. Does FM radio still work?
10. How about recording calls and radio? (not very important).
A) Is working...recording too. I've added a shortcut into setting to enable stock FM (RDS) FM Radio. The default DragonFly FM Radio is working too but don't works if you switch to speaker mode.
11. Led notification light?
A) Works for third party applications like Whatsapp, Facebook and more
12. Can I still put the phone on and off automatically?
A) Yes you can :)
13. Are ther power saving settings/Ultimate
14. Power savings settings?
A) Power Settings are there but I haven't tested it yet
Just try it :)
Blänk
Hallo zusammen,
vorab wollte ich mich mal für die tolle Arbeit an dieser Rom bedanken.
Ich habe seid etwas mehr als einem Monat das Lenovo K3 Note mit dieser Rom und bin echt sehr zufrieden.
Sie macht das Handy mehr als alltagstauglich und ist ein absoluter Allrounder im Alltag.
Aktuell benutze ich die 1552 und bin überaus zufrieden.
Jetzt kommt meine Frage.
Ich blicke auf der Seite 1 nicht mehr ganz durch. Ich hatte am Sonntag mal die MM Version 1605 versucht und muss sagen bei mir lief es recht schlecht ... kaum Sound und etwas Buggy.
Jetzt gab es seitdem so viele Änderungen und Beiträge die einem Leihen nicht viel sagen.
Welche ist denn die aktuelle Version die auch gut läuft (will nicht immer alles neu machen) und muss ich diese neu draufspielen oder kommt das über diesen OTA Updater.
Ein bisschen Kontext wäre echt super.
Danke schon mal im Voraus :)
shishopa
Hi @Blänk ^^
Ja der thread hier enthält wirklich alles was der deutschsprachige K3 Raum zu bieten hat
Also bezüglich der Funktionalität der MM ROM kann ich dir den englischen Beitrag von Cuoco92 empfehlen, da erfährst du den aktuellen Stand der Dinge was die MM ROM angeht
@Passienter
2. GPS ?
4. Bluetooth?
A) Yes you can :)
Just try it :)
Blänk
Hi shishopa,
das mit der MM Rom hab ich schon verstanden. Auch das bei dieser Version noch nicht alles 100% läuft.
Aber die Frage war ja welche die aktuell am besten laufende Rom ist und wie diese Installiert wird oder ob das automatisch per OTA Update passiert. Wie gesagt mit der Version 1552 hab ich absolut keine Probleme. :)
Weil dann warte ich einfach auf das passende Update :)
shishopa
Also meine subjektive Meinung ist, dass die 5.1 DEV am besten läuft, nicht RAM-gierig, läuft flüssig und es kamen auch noch in letzter Zeit Updates ^^
Wenn du die hier installieren willst, dann
1. Datensicherung vornehmen (alles wichtige auf die SD Karte schieben, manuelles Whatsapp Backup etc)
Ich nehme an ein Custom Recovery besitzt du schon ^^
2. Dann die neue ROM in den internen Speicher kopieren, einmal das Gerät zurück auf Werkseinstellung zurücksetzen und dann das flashen beginnen, mehr Aufwand ist es nicht ^^
Was die Updates angeht: das meiste kommt direkt über die OTAs rein. Wenn es sehr große Änderungen im System gibt, wie jetzt von Android L auf M, dann muss man es wieder falshen ^^
L
Lucky 2
Kann mir jemand sagen was ich tun muss um MTB -USB treiber zu installieren.
Habe WIN 7 64bit.
Das braucht man um mit dem SP Flashtool eine Stockrom zu flashen.
Habe schon zig Treiber AIO installiert ,bin auch schon hin und mit USB Deview
einiges zu deinstallieren um neu zu erkennen.
Komme nicht weiter nur ins chinesisch englische recovery von da kann man aber nichts installieren.
shishopa
Du kannst auch direkt über das Flashtool die Rom flashen wenn ich mich nicht irre.
Ansonsten musst du erst über das Flashtool ein Custom Recovery flashen und Dann mit ihr die ROM
L
Lucky 2
Also ich hab das anders gelesen- zuerst Stockrom mit der du die interne Struktur
herstellst dann könnte man ein Recovery und danach die Custom rom installieren
Und das Flashtool kannst du zwar starten aber ohne MTB Treiber wird ja das K3 nicht erkannt.
trotzdem Danke
Tobee
Born to buy from China
Habe WIN 7 64bit.
Schau dir mal das Howto unbrick every chinaphone tutorial auf YT an. Dort wird auch gezeigt wie man "Alttreiber" deinstalliert und alles völlig neu aufsetzt. Ein echt gutes Tutorial nicht nur zum "unbricken".
Tobee
L
Lucky 2
Danke !!!!!
Werde ich ausprobieren.
Du meinst ja das wenn man das K3 anstöpselt an PC .
SD Card - also interner Speicher wird ja erst angezeigt wenn man wieder USB-Debugging einstellen könnte.
Das mit dem Lenovo Softwarezeug hab ich tatsächlich noch nicht probiert.
Werde ich nachholen -Danke Dir recht herzlich !!!!!
Thomas.K
Also lohnt es sich schon die v.1604 drauf zu machen oder doch erstmal die 1552 lassen?
habe bis her noch kein update bekommen wegen der weiteren Übersetzung o_O?
gerade die Anruf,sms und Kontakt Einstellungen sind noch teils englisch und Spanisch ^-^
Tobee
Danke !!!!!
Ja, die Software (Mobile Phone Manager) die sich installiert ist komplett chinesisch, macht aber nix. Einfach geöffnet lassen und weiter.
adelbert
hey, ich hab mal ne dumme frage, kann man auf das lenovo k3 adobe flash player instalieren? bei mir kommt immer das das gerät dies nicht unterstützt, kann den player dann nicht laden oder instalieren.
grüße
