Der Schnäppchen Thread
TinyDeal.com
Gibt es dafür eigentlich auch passendes Kabel, für die höhere Geschwindigkeit
Set to be widely available starting 2015, Type-C USB will support USB 3.1 with the top speed of 10Gbps and has much high power output of up to 20V(100W) and 5A. Considering most 15-inch notebook computers require just around 60W of power, this means in the future laptop computers can be charged the way tablets and smartphones are now, via their little USB port. In fact Apple's latest 12-inch Macbook is the first notebook that incorporates a Type-C USB as its power port.
Going forwards, USB-C will enable storage vendors to make bus-powered (no separate power adapter required) external hard drives of much larger capacity, since it provides enough power to run one or even multiple desktop hard drives.
Type-C USB also allows for bi-directional power, so apart from charging the peripheral device, when applicable, a peripheral device could also charge a host device. All this means you can do away with an array of proprietary power adapters and USB cables, and move to a single robust and tiny solution that works for all devices. Type-C USB will significantly cut down the a amount of wires currently needed to make devices work.
http://www.cnet.com/videos/link/vVunTlQnRI_A1VZSuDNdAqkWQ73bbfqc/
Quelle:http://www.cnet.com/news/usb-type-c-one-cable-to-connect-them-all/
ni8mar
Ich denke der preis ist gut
Herzlichen Glückwunsch, global_egrow hat Ihren Preisvorschlag in Höhe von EUR 104,99 akzeptiert.
iNew L4 5.5" Android 5.1 MTK6735P Quad Core Dual SIM 16GB 5000mAh 4G Smartphone
Angaben zum Verkäufer
global_egrow (40621 )
98,9% Positive Bewertungen
Angemeldet als gewerblicher Verkäufer
Versand:
KOSTENLOS Standardversand
Artikelstandort:
Karlsruhe, Deutschland
Versand nach:
Deutschland
Lieferung:
Zwischen Fr, 30. Okt. und Sa, 31. Okt. bei heutigem Zahlungseingang
Sotair
Kaffes Nikotides
Sieht für mich wie das Original Wsken X-Cable aus, allerdings die aktuelle Generation mit mehrfarbiger LED. Bei AE wird oft noch die Vorgänger-Version verkauft, die nur eine weiße LED hat.
@Chocoball - woher hast Du, dass die WSKEN nicht mehr fertigt?
j880001
