Xiaomi Hongmi/ Redmi/ Note- Alles Roter Reis von Xiaomi
ExUser 49808
Die 45 läuft zwar sehr flott, braucht aber merklich mehr Akku als die 37. Ich würde Dir die 37er empfehlen
IceTea7
Ich habe jetzt die Rom, die auf Tradingshenzhen verlinkt ist geflasht, da ich im Decuro Forum keine Downloadlinks fine, was eventuell damit zusammenhängt, dass ich dort keinen Account habe.
J
johndebur
Gibt ein neues Redmi mit 4G. Unterstützt u.a. WCDMA und FDD-LTE.
699的节奏?小米联通4G新机曝光!mydrivers
699 rhythm? Millet Unicom 4G new machine exposure!
Before, GFXBench database has appeared a model for 2,014,811 millet new machine, since the data show it is equipped with 9.2-inch display, so speculation that it was the true identity of a cheap version of millet plate.
Now, you can finally confirm the identity of the aircraft, as it appeared in the afternoon, the Ministry official. The final proved it is not a cheap version of millet flat, but China Unicom version of 4G Redmi, supports GSM / WCDMA / TD-LTE / LTE FDD network.
Ministry data show that the aircraft is equipped with 4.7 inches screen, dual card dual standby, the battery capacity of 2200mAh, which is identical and Redmi 1S.
But note that the aircraft's size, some special, appeared in the Ministry of millet new machine size is 134 × 67.21 × 9.2 (mm), (137 × 69 × 9.9mm) smaller than the existing version 1S 4G of red rice circle.
It is not clear the final name of the machine will be Redmi 1S, or directly preceded Redmi 2. But it is certain that the machine will definitely change the shape, size has also been reduced, red rice border tucao much money will soon become the past.
As for the price, Redmi 1S Mobile 4G 599 yuan was arrayed expected Unicom is the 699 version of 4G rhythm.
As GFX inside why it is 9.2 inches display screen? Should identify the error, after all, it is against the push by ppi, not too accurate.
s_4be8bc6cf0af4794b648aa524995b010.jpg s_49c86616159e4b2784225c7b326ccb70.png.jpg
Megalampe
Super, gerade wo ich mir ein Cubot Zorro bestellt habe (wegen LTE). Ich warte aber erst mal ab, ob es wirklich Dual Sim hat und wie sehr das verkleinert wurde. Und vor allem was es letztendlich wirklich kann und kostet.
J
johndebur
So soll dann das neue Redmi aussehen:
小米首款64位手机现身!轻了/瘦了/薄了 mydrivers
Millet's first 64 handsets coming out! Lighter / thinner / thin
Remember last night we exposed millet new machine it? Now the Ministry has finally released its photos.
Last night we had to guess Unicom version of the aircraft should be 4G Redmi 1S, but because of the size has been reduced, so do not rule out the possibility that it is Redmi 2.
The latest announcement from the Ministry of the picture, the aircraft's appearance compared to the mobile version of red rice 1S 4G is indeed a certain change, even though the screen size is 4.7 inches, but whether it is up and down or left and right borders Borders has narrowed . Three buttons at the bottom of the design has changed, and the same style rice 4. Weight reduced from 158 grams to 134 grams, feel should be improved.
Changes in the back is particularly evident from the bottom of the camera flash is transferred to the left side of the camera, speaker hole location is more close to the middle of some, after the shell has become a highlight of a similar material.
Specific configuration, the machine uses 4.7 inches 720p display, equipped with quad-core 1.2GHz processor (should be Xiaolong 410), built-in 1GB of RAM and 8GB of storage space body, providing a 2.0 megapixel front camera and a 800-megapixel rear camera, battery capacity 2200mAh, running Android 4.4.4 operating system.
Red, orange, black and white terms of total aircraft shell yellow green blue purple several colors to choose from, comparable to four meters, but when the IPO should be only two colors, black and white.
It supports supports GSM / WCDMA / TD-LTE / LTE FDD network, namely China Unicom 2G / 3G / 4G and mobile 2G, is expected to officially went on sale late this year or early next year, the price should not be more than 699 yuan, or 599 may also be .
s_1bc9cecc9b014965a02aeec2ea44778a.jpg s_2d35157a0d35437980bc0b570caa8b75.jpg s_395cfb4c576a4afd801b4c3ee464c351.jpg s_8171722485d3425fa77ab5c50e5f0904.jpg s_a8923e96f11c4fa0ba21aa6d53d32e68.jpg s_ab7ed9c65ab44352a03ecb86c582356b.jpg s_ad9b8e6b54e045218e608308af6f9b3d.jpg s_d63428e120e54ef0b318b343eb676cb9.jpg s_df6d4f7857e947aebf820f86df6095da.jpg s_dff54b1ed50a454aaa284826fc99a814.jpg s_f7ad535941ba42d78d8f4cde62d04dcd.jpg
Megalampe
Wie lösche ich das Google Konto?
Meine Meinung zu dem 1S: Das Teil ist so richtig ********, so nen verknüpften Mist habe ich ja noch nie gesehen. Ständig ploppen irgendwelche Nachrichten in der Statusleiste auf, nie wieder Xiaomi.
Daemonarch
Chiclone-Lover
Einfach die Apps deinstallieren, die das auslösen... Wo ist das Problem?
Normal kann man die benachrichtigungen der einzelnen apps auch separat abstellen.
Andreas G
Wohl kaum Problem von Xiaomi, sondern Miui und der Einstellungen.
Sei froh, was gekauft zu haben, dass funktioniert.
Gesendet von meinem HM NOTE 1LTEW
Megalampe
Weil es die Xiaomi Apps an sich selber sind, ich habe nur 9 Apps auf dem Gerät (ja, es ist wirklich erstaunlich was man wirklich braucht). Ich habe diese Apps schon "gestoppt/in die Knie gezwungen", aber es hilft nichts. Beim Playstore hilft nur das Konto löschen, was ich bei jedem meiner Geräte kann.
Das Mi Konto kann ich auch nicht löschen, da bin ich auch nur abgemeldet. Aber wo löscht man das, mal eben markieren und löschen geht nicht.
Ne, ist absolut nichts was Xiaomi zu vertreten hat. MIUI ist von Xiaomi, also ist es sehr wohl deren Schuld. Selbst das Inew V3 mit den ewigen GPS Problemen fand ich besser, da gab es auch ordentliche Rom Updates, bzw. vernünftige Custom Roms. Aber Xiaomi hat es ja auch nicht nötig, den Code frei zu geben, so das man sich an ein eigenes Rom setzen kann.
Von den Handys laufen schon fünf in unserem Bekanntekreis und das bis heute ohne Probleme.
Ich behaupte nicht das die Geräte nicht laufen, aber "wie" geht mir schon langsam auf den Zeiger. Und ich kann bei weitem viele Punkte weg stecken (kein LTE z. B., obwohl Umts hier mies ist).
Andreas G
Vielleicht doll test Du Dich damit auseinander setzen. Ich habe keine Probleme.
Die Frage ist doch, was für eine Rom Du nutzt. Ob Du sie einzustellen vermagst oder nicht.
Und ob es ggf sinnvoll ist auf die Decuro umzusteigen.
Gesendet von meinem Xiaomi Hongmi Note 4G
Andreas G
Ich habe auch nicht verstanden, welche Meldungen da überhaupt kommen sollen.
Mich haben die Zusatzapps gestört und bin nun auf Decuro unterwegs.
Wenn ich allerdings an den Müll anderer Lieferanten denke, geht es ja noch.
Andreas G
Dahmer, was passiert, wenn man einen Fullwipe ausführt?
Da sind dann alle Konten weg, oder? Wäre ja einen Versuch wert. Ich habe nämlich ein Problem mit dem Google - Account und bescheuerten Meldungen....
Andreas G
Dahmer und andere:
Ich hatte ohne Wipe Decuro installiert und bekam das:
Nun hatte ich einen Werksreset gemacht, also auf Auslieferung zurück.
Das hat nicht ausgereicht. Audible ist somit komplett nicht zu nutzen.
Es ist wohl nicht der Cache gelöscht.
Wie komme ich da hin? Wie wipe ich gründlicher beim Note?
