Fake Antutu
Louis777
@ColonelZap
hi,
habe gerade gelesen, daß Antutu sich durch die X-Version schützen will.
Die hatte ich nicht drauf.
Das 2. 850s macht die 28/29000. Das Antutu 4.4.2 ist schon hochgeladen.
Louis777
J
johndebur
Habe diesen Artikel gefunden, vielleicht erklärt der auch ein wenig? Ist leider chinesisch
Erklärt halt wie man die Ergebnisse ändert?
http://pcedu.pconline.com.cn/356/3566249.html
Übersetzung
Hmm toll hier ist der Text auf Englisch : http://www.antutu.com/view.shtml?id=7242
Stop running of cheating? An Bunny release AnTuTu X version
[Info] PConline machine running points Andrews has become commonplace, and this year does not rely on Android machine to run sub-assertive about their performance, seem embarrassed Nachulaimai. In the run of the test App, Ann Bunny famous. Tree attracts the wind, very Duo Anzhuo machines for security Bunny made some "optimization." The "optimized" What is it? For example, to detect security Bunny running on overclocking it, open accelerator friends, and even modify the security Bunny itself, in a nutshell is cheating. To address this situation now, Ann Bunny AnTuTu X released a special edition, effective anti-cheating claims can run points.
An Bunny release AnTuTu X Special Edition Anti-Cheat
According to Tutu's publicity, AnTuTu X and the original security Bunny at the interface and use, and there is no difference, but with a number of methods to disguise, not the device is detected by Tutu, seeks to restore the true performance, Some prohibit equipment Tutu run, it will be up and running. Here are some methods of cheating An official cited Bunny, Tutu called AnTuTu X can effectively prevent cheating Andrews machine using the following method, we look.
First, the mobile phone factory built-modified Tutu
Most of this kind of cheating is high imitation and appear on the cottage type of phone, in order to deceive consumers, modify Ann Bunny APP client hardware configuration to obtain a false statement and false test results. This type of phone has a common situation that you can not uninstall the built-in security Bunny software, or can not install the official version of the software.
Second, the benchmark for temporary security Bunny and other performance enhancements
This type of phone is to increase the security Bunny recognition software in the system, such as GPU frequency normal maximum operating frequency of 480MHz, the recognition software to run security Bunny, it will automatically increase the frequency to 500MHz or more. By adjusting the voltage, short overclocking does not cause fever and unstable devices, but can certainly increase the magnitude of the final score, consumers see fluency scores and practical daily use will be some differences.
You can see the run Tutu, when the frequency becomes 532, significantly higher
Third, identify the firmware increases performance picture frame loss
After running through some chips and some other identifying security Bunny Benchmark, test screen automatically dropped frames, and the system displays the feedback was successful. For example, when running 3D test, the system received feedback from 10 pictures per second, but in fact only 5 per display, so that the test results will be improved significantly.
Fourth, forced to modify test resolution
Tutu is in accordance with the actual resolution of the phone to run the image, the higher the resolution, the same configuration, the lower the score, because the burden of high resolution will give the system more. In actual operation, the run rate will be lower than the low resolution. We understand that a high resolution will reduce system efficiency, decrease test scores. So there is some vendor identification after running Tutu, the system automatically reduces the resolution.
Now for the run of a "optimization" Cheating is not twelve vendors, hardware Andrews war which would have pandemonium, Lianpao points must cheat, eat with it too difficult to see. An Bunny this release AnTuTu X anti-cheating, is indeed a good thing. However, there are a lot of people has questioned the neutrality of the security Bunny, Bunny An example of an Intel processor to run sub was unstable ( Click here to view ), also came up a while ago, Jinshan Investment security Bunny Message ( Click here to view ). An Bunny can do it in a fair and equitable to what extent? We'll see.
guesa
seid ihr eigentlich sicher, dass es an antutu selber liegt? Die großen Hersteller haben es doch schon vorgemacht, wie man Antutu beeinflusst, indem man beim Start der App kurz die Hardware übertaktet.
Quelle: http://mobiwatch.de/erwischt-samsung-manipuliert-benchmark-tests-auf-dem-galaxy-s4/
Diesen Code hat AnandTech im Samsung Galaxy S4 gefunden. Hier werden gezielt Apps wie AnTuTu und Quadrant genannt, deren Start zu einer Übertaktung des Grafikprozessors führen:
tommy0815
@guesa
du vergleichst Äpfel mit Birnen.....
Bei den Geräten wird einfach die volle Reserve aus dem Gerät gelockt, aber nichts dazugemogelt.
Klar ist das Ergebnis das gleiche das eben mehr Punkte bei rumkommen, aber dennoch ein völlig unterschiedliches vorgehen.
Samsung schöpft nur alle Leistungsreserven aus, sprich was das Gerät unter IDEALBEDINGUNG wirklich leisten KANN.
Wir schreiben hier aber von FAKE Punkten, die das Gerät rein technisch gar nicht erbringen kann!
@Louis777
Nur um das noch einmal klarzustellen, mit der Version V4.2.2 aus Deinem Post #28 schaffst Du es dem Handy diese gefakten 29000 Punkte zu entlocken? Und Dein Upload ist auch ein BACKUP, den Du mit DEINEM HANDY erstellt hast?
Wenn Du jedoch diese V4.2.2 deinstallierts und eine AKTUELLE Version aus dem Play Store lädst, dann funktioniert die Manipulation nicht mehr, es werden die echten Punkte (ca. 17000) und Daten von Antutu angezeigt?
Ist das alles SO 100%ig korrekt? Habe ich das richtig verstanden? Danke :)
Louis777
@Louis777
Du hast mich richtig verstanden!
Louis777
Dann kann ich es wirklich nicht nachvollziehen, wie das auf Deinem Handy funktioniert :( ICH bekomme diese Antutu Version nicht manipuliert, irgendwo anders muß noch etwas auf Deinem Handy stecken, daß das ermöglicht :(
@Louis777 eigentlich wäre die Lösung für die Hilfe für @colonellzap ziemlich einfach.
Du hast doch sicher eine MTK Droidtool Sicherung vom Auslieferungszustand und kurz nach dem Rooten gemacht:)
So kenne ich Dich zumindest.
Stelle doch einfach das system.img (Andoid.IMG) davon hier rein. Dann können wir schauen, was Sache ist.
Es gibt Programme, die diese IMG wieder strukturiert zerlegen.
@ colonelzap
Wir reden schon über den Stand, den es gab und nicht über den, den es gibt:( ?
via mobile T1
Natürlich :) Mein Gedanke ist der, daß da eventuell noch eine andere Systemapp bei dem Handy "im Hintergrund" läuft, die die Manipulation von der Antutu Version ermöglicht. Und so etwas sollte im System/App Ordner stecken, darum bin ich auf den Ordner und seine Apps neugierig :grin:
Ich weiß es ja auch nicht?!? @Louis777 hat uns die Antutu Version hochgeladen, mit der die Manipulation auf seinem Handy funktioniert, wir kennen seine build.prop, bei uns funktioniert die Manipulation nicht, darum VERMUTE ich, daß da eventuell noch eine andere App im Spiel sein könnte?!? Irgendwie muß das ja bei ihm funktionieren und hoffentlich für uns reproduzierbar :)
Das ist eine von Dir bereist mit Superuser nachbehandelte Version. Im /system/app finde ich keine verankertes Antutu Version
Die build.prop
hat die bekannten Einträge
##fake antutu score###
ro.addscore.int=12000
ro.cputype.fake=2.0 MTK6592
ro.mediatek.cpupreq=1600.0 ~ 2000.0 MHz
@Louis777 : hat Du auch eine Sicherung vom /usrdata (oder auch z.B. eine CWM-R)
Gerhard Willi
