Meizu MX3 - 5,1 display ( 1920 x 1200 p) Samsung Orion 5410 Octacore ????
djvs
Gametot
So nach eine längeren OP lebt mein MX3 wieder.
Habe mir das Display selber gewechselt.
Leider hat es ewig gedauert bis ich es hatte erst beim 3 Händler hat es geklappt.
Anleitung kommt in den nächsten Tagen.
Constrictor
Danke, aber der Touch alleine würde mir reichen . . .
. . . wenn's das überhaupt gibt!?
Mülle
Hui herzlichen Glückwunsch zur geglückten OP :) hut ab vor soviel Mut und Geschick ;) auf die Anleitung bin ich gespannt!!
Ausgelebt
Outfluencer
grad im internet gefunden
Meizu Mx3 4.4.2 KitKat ROM
I'm copy paste this tutorial from forum.xda-developers.com :
The Meizu Mx3 owners may also want to keep their device up-to-date. So we thought of giving you a tutorial of how to upgrade Meizu Mx3 to Android 4.4.2 KitKat. With new version of android operating system on your device, you will have more benefit. Your device will have more feature, more secure, more fast performance, and more cool he…3x. But prior to telling you how to install Android 4.4.2 KitKat on Meizu Mx3 , let’s see what do you want in order to be able to perform the installation. You will have to download 4.4.2 KitKat Meizu Mx3 ROM. You will also have to root your Meizu Mx3 to prepare it for Android 4.4.2 KitKat upgrade. Discover how to root Meizu Mx3 and install Android 4.4.2 KitKat from here. Here are the download links of the files you want to update Meizu Mx3 to Android 4.4.2 KitKat. Just before beginning to upgrade your Meizu Mx3 to Android 4.4.2 KitKat don’t forget to backup your information, as contacts, text messages and the apps installed from Google Play Store who maybe lost when the installation finishes. Now let’s see how to update Meizu Mx3 to Android 4.4.2 KitKat :
1. Install the ROM Manager on your Meizu Mx3 . Get it from Google Play Store, then install the clockwork mod recovery.
2. Connect your Meizu Mx3 to your PC employing the USB information cable. Copy the “ROM.zip” file you downloaded to the SD memory card.
3. Restart your device in the recovery mode using ROM Manager. As soon as in Recovery Mode, go to ROM Manager and select backup/restore to back-up your information.
4. From the Recovery Menu do a total data erase (including Delvik Cache). When completed, go back to Recovery Principal Menu and choose Flash ROM from SD Card. Navigate the location you copied the ”ROM.zip” file and follow the directions for installing Android 4.4.2 KitKat on your Meizu Mx3 . As soon as the installation is over, just reboot your Meizu Mx3 device, and here you go, you’ve just upgraded it to the new Android 4.4.2 KitKat.
Note : Here Is Link To Download the ROM :
The ROM File size is 128 MB, so I split the file into 3 parts :
ROM Part 1 : http://*URL-SHORTENER*/7pyL97
ROM Part 2 : http://*URL-SHORTENER*/ffHU2x
ROM Part 3 : http://*URL-SHORTENER*/l1zKh5
To combine 3 parts files above into 1 file just use WINRAR, then extract the files into ZIP format.
If any problem with the ROM, maybe because the ROM have corrupted during the download process, you can try to re-download the ROM.
Thank you for visiting Meizu Mx3 5679 4.4.2 KitKat ROM
Tutorial Video : Easy Way To Download at downloadsafe.org/sharecash.org =
Mülle
Klingt sehr interessant :goodpost: aber ehrlich gesagt rechne ich für den 28.4 kitKat für das MX3 in Form von Flyme 4.0:dirol:
Manu-M3
Meizu Fanboy
Nein, das muss ich dir aus dem Kopf schlagen. Das sind unbestätigte Gerüchte aus dem Nichts, schau doch mal die Screenshots von Kitkat Flyme an. Die sind eindeutig auf Flyme 3.0. Ich denke nicht, dass Flyme 4.0 auf dem MX3 kommt, bevor das MX4 launcht.
Mülle
Okay ich könnte auch erstmal mit KitKat und Flyme 3.x leben :) dachte nur das die mit Wechsel der Android Version auch eine neue Flyme Version einführen... Naja ich bin auf jeden fall mal auf den 28.4 gespannt...
Manu-M3
Meizu Fanboy
Das war auch oft tatsächlich der Fall, hier vermute ich es allerdings nicht :) Zumindest fände ich es strategisch gesehen falsch, denn dann steht das MX4 ohne ein wirklich neues UI da.
Manu-M3
Meizu Fanboy
Naja, aber ich denke wirklich nützlich wird es da noch nicht sein. Für mich sicherlich keine Alternative zu Flyme, schon alleine wegen dem Design.
J
johndebur
Das MX3 wird wieder günstiger, zumindest in China :)
魅族:MX3大降价了!mydrivers
Meizu: MX3 big price reduction!
Last night, Meizu given notice in the official microblogging, said today on the 10 o'clock to announce some good news. Now, the good news has been announced.
Meizu announced that starting April 23, MX3 prices across the board down 200 yuan, 16GB, 32GB, 64GB present as long as 1,799 yuan, 1,999 yuan, 2,399 yuan, after including the former black and white, white and white.
Meizu said more than 600 stores nationwide, the official online store, Meizu Lynx official flagship store, Jingdong other social channels can be purchased.
After the Meizu price adjustment, MX3 cost further highlight. Not surprisingly, then, is to make way for the MX4G other new advance.
sawfish
