Jiayu G3C - MT6582 1GB Ram 4Gb Rom 4,5" IPS HD720 display 3000 mAh
J
johndebur
Vom Jiayu G3 gibt es nun auch eine Version mit MT6582 , nennt sich G3C. Das Handy ist am 10.3. zu haben und kostet 769 yuans (90€)
还有佳域G3C 售价同样769元 mtksj
There are equally good domain G3C price of 769 yuan
In mid- February release of the original good domain phone -G4C G4 another version of this C can be understood as cheap (CHEAP) mean , after replacing the processor price advantage , now classic models G3 good domain while also keeping up to new release - good domain G3C, empathy and G4 , GIn mid- February release of the original good domain phone -G4C G4 another version of this C can be understood as cheap (CHEAP) mean , after replacing the processor price advantage , now classic models G3 good domain while also keeping up to new release - good domain G3C, and G4 Similarly , G3C cheaper than the price of the original version , is also replaced the processor.
The original G3 uses a quad-core 1.5GHz MT6589T main frequency , the new domain G3C good debut MT6582 equipped with the latest quad-core processor , main frequency is 1.3GHz, but the replacement part has become a dual-core GPU mali-400, 720P screen driving more handy.
The remaining basically the same specifications and G3 is still 4.5 inches 720P resolution IPS screen , there are two generations of Corning Gorilla Glass protection equipment , 1G RAM +4 G ROM memory , supports up to 64G expansion. Camera, after the former 2,000,000 8,000,000 pixels dual combination , the battery capacity of 3000 mA , supporting WCDMA + GSM dual sim dual standby , running Android 4.2 system . G3 was a smash hit not only because the core specifications mainstream , with the aircraft is equipped with a comprehensive gyro sensor , electronic compass , etc. have a great relationship, and these advantages also extended to the G3C body.
Good domain G3C design has not changed, measurements size is still 135 * 65 * 10.8mm, inside the fuselage frame and brackets are metal building .
Coincidentally, the same price of the aircraft and G4C , priced at 769 yuan , 10 officially on sale this month , how would you choose ?
StardustOne
Ich habe es für eine Arbeitskollegin bestellt, wow, die eingebaute Kamera ist das Beste was ich jetzt bei einem China Phone gesehen hatte. So detailliert und scharfe Fotos hatte ich noch nie gemacht.
Und was auch immer für die WCDMA Abdeckung von den Chinesen zusammengeschrieben und Zusammengeplappert wird, das Phone ist ein echtes WCDMA Quad Band Phone. Es unterstütz sowohl 800, 850, 900, 1900 wie auch 2100 Frequenzen, ist also ein echtes China World Phone. Bye Bye 850/2100 oder 900/2100 Käse Phones, ich kauf mir nur noch World Phones :).
GPS Empfang super, nach ca 1 Min ein Fix mit 8 von 12 sichtbaren Satelliten.
