Jiayu G5 - MT6589 7,9mm dick NFC ? 2GB Ram 32Gb Rom 4,5" retina display
J
johndebur
ob das nun das fertige Design sein wird , weiß ich nicht. Sieht aber dem iphone ähnlich. Naja wird ja wohl noch Zeit sein bis das kommt. :) Soll auf alle Fälle nach dem G4 kommen.
4.5英寸OGS屏幕2G运存 佳域G5发布 - MTK手机网
[资讯交流] 佳域G5产品详细解读 - Powered by Discuz!
4.5 inches the OGS screen is 2G memory on a good domain G5 released
Quite similar renderings from the official view, the best domain G5 back IPHONE5 of borders and the back cover made of stainless steel to create 128 × 63 × 7.9mm body size, 7.9 mm thickness of ultra-thin levels. Hardware aspects, good domain G5 and G4 are equipped with MTK MT6589 quad-core processor, clocked at 1.2GHz, built-in PowerVR SGX544MP graphics processor, has 2GB large memory on and 32GB of storage space body, but does not support extended SD card. The G5 screen size 4.5 inches, using OGS full fitting process as well as wide viewing angle IPS display technology, 326PPI reach the retinal level, the external screen will still be using the the Corning second generation glass protection screen. The camera part also reach a higher level, Vice 3000000 + 13 million pixel main camera.
Other aspects of good domain G5 with non-removable battery design, standard capacity of 2500 mAh polymer lithium ion battery to support the gyroscope \ distance \ light \ gravity \ magnetic sensor \ wheat double noise reduction \ WIFI \ Bluetooth \ FM \ GPS and other commonly used functions, support for NFC, USB OTG function.
Once again, we find a good domain G5 who has shown signs of G3's feeling G3 after a "full-featured" smartphones, all the others have, and G5 own good domain for the first time based on The Android 4.12 depth custom UI, and follow-up support OTA upgrade. There is no way of knowing the price of the good domain G5, G5 may in turn become a the "Cock silk God Machine" style of mobile phone based on good domain, another view from the recent good product planning domain, G5 is likely to have to wait G4 listed The formal launch.
Good domain G5 detailed interpretation of [information exchange]
Good domain G4 positioned as the popularity of quad-core smartphone the good domain G5 positioning G4 upgrade, two phones hardware configuration is quite some difference, but the appearance of workmanship, G5 will be all-stainless steel metal body (frame border is made of stainless steel material, the battery cover is made of stainless steel), more sophisticated workmanship, process more demanding.
G5 cottage Apple 5 phone friends say, want to clarify. G5 really draws iphone 4 stainless steel frame and the back of the iphone 5 design style, but the G5 to draw the the Apple style elements at the same time, itself a lot of design improvements, such as the screen size is 4.5 inches greater; positive physical buttons, all touch-sensitive buttons; battery is removable. G5 overall metal style draws on the design of the Apple phone, but we have given a lot of good field elements.
G5 overall thickness of only 7.85 mm, is very thin. In order to achieve a thin body, the good domain specifically tailored ultra-thin camera, the OGS process thinner screen. However, to guarantee the long standby time, G5 battery special design.
G5 with a thickness dual battery compatible design, large battery capacity of 3000 mA, thin battery 1850 mA, two batteries compatible with the back cover. Using a thick version of the battery, the battery cover slightly protruding fuselage plane some.
About long 130 wide 63.5 G5 measurements size of 7.85 mm thick (the thickest point of the the thick electric version of the fuselage to 9.85 mm), G2 is a long 124 63 10.6 mm thick, the G5 the overall size and G2 or less, slightly longer than the G2 considerable width, thinner, and at the same time increased to 4.5-inch screen, has a very good feel and portability.
G5 R & D is now coming to an end, the time-to-market G5 G4 released a little later than please everyone's attention!
J
johndebur
Das Handy wird wohl aus Edelstahl gefräst werden und soll extrem dünn werden. Der Plan ist ja 7,85mm Dicke. Außerdem soll es laut Jiayu keine Iphone kopie werden, sondern es wird noch viel besser. Nun ja mal sehen :) Außerdem hat das Handy eine speziell designte kamera, um die dicke zu gewährleisten.
Die grübeln noch darüber ,wie sie die Batterien intergieren werden. So wie ich es verstehe, bekommt das Handy zwei Batterien, eine 3000mah und eine 1850mah Batterie?? Ob da überhaupt Platz dafür ist. lol
So wie es aussieht stehen die Pläne ( R & D) für das handy fest und es wird erst nach der Veröffentlichung des G4 kommen.
[资讯交流] 佳域G5产品详细解读
[Information exchange] the Good Domain G5 detailed interpretation
Good domain G4 positioned as the popularity of quad-core smartphone the good domain G5 positioning G4 upgrade, two phones hardware configuration is quite some difference, but the appearance of workmanship, G5 will be all-stainless steel metal body (frame border is made of stainless steel material, the battery cover is made ​​of stainless steel), more sophisticated workmanship, process more demanding.
J
johndebur
also wenn dort von "release" gesprochen wird, heißt das nicht:
"ihr könnt das jetzt kaufen", sondern "wir produzieren das jetzt mal".
hab ich das so richtig verstanden?
release ist einfach Veröffentlichung, kaufen kann man es noch nicht, wurde eben nur der Öffentlichkeit vorgestellt. Kaufen kann man es , wenn der Hersteller es produziert hat und es im Laden verkauft, zB hier:
"released" ist halt recht doppeldeutig, kann auch sein ,daß die blogschreiber auch selber Google translate hernehmen, oder von anderen Blogs kopieren. Da wird dann ein Eintrag schnell falsch :)
würde da eher "unveiled" schreiben
daily.grind
alles klar, dann wird das wohl im detail an der übersetzung liegen.
unter release hab sonst immer "verkausstart" verstanden.
aber wie du das übersetzt passt es dann wieder.
also gehts ersmal nur um ne öffentliche präsentation.
obwohl ja eigentlich noch kein prototyp gezeigt wurde,
sondern nur die daten bekannt gegeben wurden, oder?
J
johndebur
naja im grunde heißt es ja verkaufstart. Aber bis jetzt gibt es nichts zu verkaufen :) Jiayu hat halt in deren Forum einfach eine Rubrik mit den neuen handys eingeführt und dann ein paar Photoshop bilder hinzugefügt. Mehr auch nicht. Außerdem heißt es ja , daß es erst nach der Veröffentlichung vom G4 kommen soll. Aber einen Prototypen vom G5 gibt es ja noch nicht einmal.
Im Moment beschweren sich eh viele im Jiayu forum, daß Jiayu einfach nur rumklont, statt was selbst zu entwerfen :grin:
daily.grind
auf welche geräte beziehen sich denn die klon-beschwerden?
also klar das g4 orientiert sich am apfel,
aber hatte das g3 auch ein klares vorbild?
das g2s sieht dem zp500+ relativ ähnlich,
aber klonen die großen hersteller/brands tatsächlich untereinander
oder haben sie eher gemeinsame vorbilder?
das die renomierteren chinesischen brands schon von unbekannten
kleinen firmen (meist schlecht) kopiert werden hab ich schon gelesen.
was sind denn eigentlich die "newcomer" brands mit den bewährtesten qualitäten?
hero, zopo, jiayu und...? (huawei und zte zähle ich mal eher zu schon etabliert)
J
johndebur
erstmal hauptsächlich auf das g5, das angeblich dem IP 5 sehr ähnllich sieht. Manch einer im jiayu forum ist auch besorgt, daß es Jiayu ähnllich ergehen wird wie apple selbst, denn laut Gerüchten sollen die Verkaufszahlen ja nicht so gut sein. Keine Ahnug, ob das stimmt.
G5 back good cottage ugly.
Is the good domain to the back of the cottage infamy forever? ?
[Information exchange] IP5 is this back, can be considered one of the reasons of poor sales.
aber der admin im Jiayu forum , hat ja schon versichert ,daß es viel besser wird als irgendein iphone :grin:
naja muß man erstmal auf Fotos warten.
vermutlich oppo find 3?
was sind denn eigentlich die "newcomer" brands mit den bewährtesten qualitäten??
keine Ahnung, da ich noch kein handy von den herstellern in der hand hatte. :) Sind ja auch zum Teil keine newcomer, da es die hersteller ja auch schon lange gibt
vielleicht noch Umi , Gionee, TCL, Haier, Coolpad, Lenovo etc ?
daily.grind
danke für die ausführliche antwort.
ich bin kurz davor mich für ein G2S zu entscheiden.
ne alternative wäre das ZP500+.
fällt dir da noch ein gerät ein mit vor allem vergleichbaren maßen
und built quality und einigermaßen aktueller hardware.
leecher88
wow klingt ja mal sehr sehr geil und hoffe dass es ein viel geileres Design hat als das Iphone 5
das G3 ist ja schon ein Hammer !!!
J
johndebur
Bild vom G5, angeblich bekommt es den MT6589T
处理器升级至6589T 佳域G5已经送检 mtksj
Upgrade to 6589T processor G5 has good domain censorship
Good domain G5 which aspects are more attractive, recently appeared again G5 official website of the Forum, the aircraft from the original 1.2GHz quad-core processor upgrade to the 1.5GHz MTK6589T, and official sources have confirmed this phone has submission, which means the official listing G5 from getting closer.
Release good domain G5 is good domain phones another attempt after the transition, the biggest highlight of this phone is the back cover and the frame are made of stainless steel metal building, inside the fuselage with a metal frame, and the thickness is also very slim, only 7.9 mm, should be playing one after another following the G2S boutique models. In addition to a slight curvature of the outer corners, G5 entire body are designed to be very flat from the previous exposure of the real machine diagram, the aircraft's main camera does not protrude from the body to maintain a parallel, which in less than 8 mm models is extremely rare, and significant progress on the craft.
As for the argument the party concerned, good domain G5 hardware configuration also attractive enough, the aircraft will be powered by the MT6589T clocked at 1.5GHz quad-core processor (the original is MT6589), memory specifications for 2G RAM +32 G ROM's combination of high capacity, support the expansion. Not part of the screen did not follow the tide of more than 5-inch size, but chose a moderate 4.5 inches, but the resolution is up to the 720P level, the use of touch-screen technology OGS fully fit, the display is still worth the wait. In addition, the Council and the good domain G5 or G4 uses the same thickness and electrical design, thin electric version size is 130 * 63.5 * 7.9 mm, the battery capacity of 1850 mA, thick electric version of the same width and height with thin electrical thickness to 9.85 mm, the same relatively slim, but the battery capacity will reach 3000 mA. After owns the former 3,000,000 13,000,000-pixel dual high-definition camera, support battery replacement, dual card dual standby, and we are concerned about the OTG function.
Good domain G5 officially listed price and the same time, still there is no specific answer, but before the good domain handsets integrated pricing, this will be positioned "boutique" level of product forecasting prices will PFP, concerns the G5 good domain Friends of the machine something to look forward.
hotwebnet
ich glaube das die 1850ma keinen Sinn mehr macht, wer einmal 3000ma in seinem G4 hatte möchte nicht mehr jeden Tag an die Steckdose............
klvogel
Ich denke ein Launchdatum im Oktober-November klingt realistisch
Hier einige neue Bilder vom Prototyp.
Es soll ein 1.5Ghz MT6589T verbaut sein sowie 2GB Ram und eine 13MPX Kamera.
Ich werde auf jeden Fall eins kaufen hatte ein G3 war mir leider zu groß momentan habe ich ein UMI X1
2000.jpg153607zjt4i22tofotd9wu.jpg153629xhi45snhncpzscx5.jpg153635g7g88aky7glyg7g8.jpg153640kqm5uuxeq8xzeu8c.jpg1536147kj9s7uevkuv5119.jpg1536215rbw2gh348mfpwy4.jpgimages.jpgjiayug5-2.jpgJiayuG5-1.jpgJIAYU-G5-2-f2.jpgphotos-jiayu-g5-quad-core-1-2-ghz-dual-sim-android-4-1--3.jpg
Orange22
Endlich mal ein China Smartphone das nicht aus Plastik ist und noch in eine Hosentasche ohne wie eıne grosse beule aus zu sehen:)
hotwebnet
AW: Jiayu G5 - MT6589 7,9mm dick NFC ? 2GB Ram 32Gb Rom 4,5" retina display
Ich habe das JY -g4 und würde es nicht mehr her geben. Also nur für ein g5 also werde ich es mir bestellen wenn es da ist.
Gesendet von meinem JY-G4 mit Tapatalk 2
CuongHoang
Es soll eine Version auch mit 3000 mah geben. Das hab in gizchina.com gelesen! Und eine 64GB Rom (weiß nicht mehr wo ich das gelesen habe), naja ob das stimmt?
Entweder wird das Jiayu G5 mein nächstes Phone oder eins mit dem MTK6592, weil ich mit minem ThL W100 absolut zufrieden bin.
klvogel
Wie ich im jayu forum gelesen habe soll das komplette gehäuse aus edelstahl bestehen bis auf 2 kleine teile hinten am backcover und natürlich das glas vorne.
Wollen wir mal hoffen das es nicht wieder zig verzögerungen bei der herstellung gibt.
Das bild habe ich auch im forum gefunden das sieht schonmal nicht schlecht aus
closebor
