J
johndebur
hier mal ein video, das das HD720 screen zeigt.
youku video
und das g3 im vergleich zum G2
bbs.ejiayu.com link
bbs.ejiayu.com link
youku video
[Information exchange] good domain G3 HD playback test
__________________Good domain G3 HD playback test
Original video files Download: http://115.com/file/anp9f7pw
Good domain G3 HD video playback tests. Rar
The main purpose is to do this test show g3 HD 720p screen. Some students pointed out that the slide is not smooth, really behind several drag the progress bar did not respond, wade a hand camera video in one hand and then slide the screen to prevent collision chaos phone placement also keep the camera position, so the operation is not very convenient and does not click in place caused.
bbs.ejiayu.com link
[Information exchange] good domain G3 and G2 screen contrast
[Copy Link]
G3 720P retinal screen to the naked eye is almost no pixel viewing area much larger than the G2, the Internet, see the first choice for high-definition movies! The following is a screen photo comparison of G3 and G2.
bbs.ejiayu.com link
I would like to thank some friends a reminder, wade in a statement about today's high-definition video test performance 720P HD screen effect, rather than highlight the video decoding capabilities. Necessary to point out that, indeed, even better than G2, G3 putting effect may be video-recorded sound effects difficult to demonstrate.
Another classmate pointed out that the slide is not smooth, really behind several drag the progress bar did not respond, wade a hand camera video in one hand and then slide the screen, to prevent the touch chaotic mobile phone placement To maintain the camera position, so the operation is not very convenient, does not click in place caused.
G3 does not support HDMI, 1080P decoding in fact is not particularly meaningful. A 1080P movie file size easily 20G, so large files play on the phone to take a lot of memory card space, even if the c10's memory card to copy a 1080P file estimates also time-consuming for a long time, but the hard solution 1080P file cpu long time to work at full capacity, power consumption fever is really scary.
Wade personally think 720P video perfect support to meet the actual needs, G3 720P resolution screen play 720P video resources just to do a point-to-point as a high-definition movie lovers. Wade the experience of 720P and 1080P video contrast 42-inch screen TV playing, the smaller the gap between the actual sensory effects. Another 1080P actually only refers to the resolution of film resources, depends on the compression encoding, bit rate, file format specific, saying that a certain device supports 1080P playback, in fact, can be a special one specific bit rate video file to the performance of the decoding smooth sex.
G3 hardware performance and the ability to decode, is determined by the 6577 pairs core CPU and 531GPU, this compared with other similar hardware vendors' products, in fact, there is not much difference. On the performance of the conjecture, we can refer to the products of the same type of hardware vendors. The good domain is unique, is to provide a more personalized appearance of the product, better service, higher hardware configuration and cost-effective.
