Jiayu G3C - MT6582 1GB Ram 4Gb Rom 4,5" IPS HD720 display 3000 mAh
J
johndebur
hier mal ein video, das das HD720 screen zeigt.
youku video
[Information exchange] good domain G3 HD playback test
Good domain G3 HD playback test
Original video files Download: http://115.com/file/anp9f7pw
Good domain G3 HD video playback tests. Rar
The main purpose is to do this test show g3 HD 720p screen. Some students pointed out that the slide is not smooth, really behind several drag the progress bar did not respond, wade a hand camera video in one hand and then slide the screen to prevent collision chaos phone placement also keep the camera position, so the operation is not very convenient and does not click in place caused.
__________________
und das g3 im vergleich zum G2
bbs.ejiayu.com link
[Information exchange] good domain G3 and G2 screen contrast
[Copy Link]
G3 720P retinal screen to the naked eye is almost no pixel viewing area much larger than the G2, the Internet, see the first choice for high-definition movies! The following is a screen photo comparison of G3 and G2.
bbs.ejiayu.com link
I would like to thank some friends a reminder, wade in a statement about today's high-definition video test performance 720P HD screen effect, rather than highlight the video decoding capabilities. Necessary to point out that, indeed, even better than G2, G3 putting effect may be video-recorded sound effects difficult to demonstrate.
Another classmate pointed out that the slide is not smooth, really behind several drag the progress bar did not respond, wade a hand camera video in one hand and then slide the screen, to prevent the touch chaotic mobile phone placement To maintain the camera position, so the operation is not very convenient, does not click in place caused.
G3 does not support HDMI, 1080P decoding in fact is not particularly meaningful. A 1080P movie file size easily 20G, so large files play on the phone to take a lot of memory card space, even if the c10's memory card to copy a 1080P file estimates also time-consuming for a long time, but the hard solution 1080P file cpu long time to work at full capacity, power consumption fever is really scary.
Wade personally think 720P video perfect support to meet the actual needs, G3 720P resolution screen play 720P video resources just to do a point-to-point as a high-definition movie lovers. Wade the experience of 720P and 1080P video contrast 42-inch screen TV playing, the smaller the gap between the actual sensory effects. Another 1080P actually only refers to the resolution of film resources, depends on the compression encoding, bit rate, file format specific, saying that a certain device supports 1080P playback, in fact, can be a special one specific bit rate video file to the performance of the decoding smooth sex.
G3 hardware performance and the ability to decode, is determined by the 6577 pairs core CPU and 531GPU, this compared with other similar hardware vendors' products, in fact, there is not much difference. On the performance of the conjecture, we can refer to the products of the same type of hardware vendors. The good domain is unique, is to provide a more personalized appearance of the product, better service, higher hardware configuration and cost-effective.
J
johndebur
Jiayu Garantie. Naja Daraus geht hervor, daß das handy Gorilla glas , magnetischen Kompass und gyroscop bekommt.
Jiayu forum link
Notice of the exchange of information on good domain to increase the G3 configuration, and after-sales service policy adjustments
In order to create more cost-effective products to provide users with more benefits, and promote after-sales service more efficient, based on our consistent principle of the small profit margins, good domain will increase the G3 configuration, and after-sales service policy adjustments, the following notice:
A good domain G3 to add the following function configuration:
1.1 Magnetic sensor (compass)
1.2 touch screen with Corning Gorilla glass.
1.3 equipped with a gyroscope.
2, in order to do service more efficient, better for the user to provide quality services, after-sales service policy to the following adjustments:
2.1 cancel Depot postage reimbursement policy. Phone hardware failure during the warranty period, non-user human factors lead to the Depot to replace or repair borne by the phone to return the postage of the good domain sales departments, the good domain is responsible for the phone to return the postage to the user, ie, users with the best domain to assume one-way postage. At the same time, the good domain these users will be presented to high-end mobile phone film of one (worth $ 20), a silicone sets ($ 10). Above measures mobile phone fault plane returned to the manufacturer only for the warranty period, non-human factors, human factors caused by cell phone breakdowns, not this column, the user must bear the return postage.
Explanatory note: National Warranty provisions and does not require manufacturers to assume Depot postage. Depot postage subsidy policy before the good domain is already higher than the national Warranty Regulations and industry standards, be considered to give the user an additional welfare. In the implementation process, postage reimbursement policies difficult operation, is very complex to implement, is not conducive to work efficiency. This good domain to modify this policy, and postage reimbursement of 15 yuan to gift accessories gift worth 30 yuan, the majority of users can be understood. Also please note Depot postage policy even if modified, is still high for the National Warranty provisions and relevant policies leading domestic counterparts manufacturers.
2.2 users since the date of receipt within 15 days, non-human factors, mobile phone failure, in line with National Warranty policy renewal conditions, good domain will receive one working days after the user returned to the mobile phone user to change The new machine sent. (Note: The special replacement is not listed here, such as the commemoration of the machine quantities to replace the official version)
2.3 during the warranty period, the fault plane Depot Repair, maintenance costs users pay after-sales department and confirmed through telephone contact and payable within three working days, the good domain after-sales department to complete the mobile phone repair and arrangements sent.
More than after-sales service policy adjustment since August 1, 2012 start, everyone knows the, be understanding and inform each other!
brunni2000
中國移動用戶
Das Handy wird immer interessanter, ich bin noch so unentschlossen aber glaube, dass ich es mir auch zulegen werde
Luboo
Bis auf Gizchina habe ich noch nirgends eine andere Angabe als 1GB RAM finden können... mal sehen was am Ende rauskommt ;)
J
johndebur
steht doch hier:
http://shop.ejiayu.com/?article-36.html
佳域G3规格参数:
CPU:MTK6577 1G双核
内存: RAM1G+ROM4G
显示幕: 4.5寸 HD IPS屏
分辨率:1280×720
摄像头: 前200万物理像素,后800万物理像素 AF背照式CMOS
电池:2750毫安
触摸屏:G+G多点触摸
机身厚度:10.8毫米
und wer will kann mithelfen den Nachfolger G4 zu designen, nun wäre die Möglichkeit ein CHinamobiles handy zu entwerfen :)
The national mobilization: the good domain G4 I designed!
http://shop.ejiayu.com/?article-39.html
My G4, I call the shots! Good domain to invite you to design!
In order to better draw the users' opinions, to meet the needs of the public good domain special launch of the G4 universal participation in the design activities, as follows:
1, art, design skills, users can directly design the appearance of the diagram of the G4, graphic renderings, 3D renderings. Appearance or style elements good domain, presented the user, and put a mobile phone in the actual production.
2, all users can participate in the function appearance on G4's own expectations, including but not limited to the look and feel of the phone body material technology, screen size, and function with, but all ideas and suggestions, from the actual situation, do not too vague impractical.
3, the post, please unified release of the G4 Fantasy "zone of the good domain mobile phone forum.
Luboo
Wahahahahaa john, das habe ich noch gar nicht gesehen... geil!!! Sobald unser Grafiker Zeit hat soll er sich mal dran setzen ;) Super Info john, mal wieder ein "thanks" for you :)
Bodybum10
Aus Bochum...
So... Nach Gorilla Glass hab ich mich entschieden, dass wird mein neues Handy... ;) Für den Preis kriegt man glaube ich nichts besseres...
Ist das Gehäuse aus Plastik oder Metall? Weiss da schon jemand was?
YuutoKirifuda
Weiß jemand ob es schon einen festen Preis gibt? Ich habe auf einer Seite mal 210$ gesehen. Wie sieht es mit einem Slot für eine mircosd aus?
Luboo
Micro SD Memory Card (TF-Card), MAX support 32GB @YuutoKirifuda natürlich hat es einen Microcard slot!
Gestern habe ich noch einen chinesischen Kontakt auf die Firma angesetzt, mal sehen was die Dame herausbekommt ;)
Luboo
yep, jetzt hats geklappt, bei mir hat sich im Chrome nur irgendwie die translation abgeschaltet und ich konnte die Validierung nicht ändern, jetzt aber... merci John, dann mach ich mich mal ans checken ;)
Aratonizma
kann man ohne bedenken das phone bei China Made Wholesale , Buy cheap products from China vorbestellen, oder bekommt man dann doch noch nen nachzahlungswunsch? Die Preise für das Phone sind ja so derbe unterschiedlich, da würde sich das echt lohnen schonmal die kohlen auszugeben und auf das handy zu warten.
ich glaub an die 15% zinsen monatlich bekomme ich für mein geld ja sonst nicht geboten ^^
währ schön wenn jemand erfahrungen berichten könnte bzw mit die vorbestellsache aus dem kopf schlangen könnte wenn nötig ^^
