Hiphone 4GS / Goophone 4GS mit 960x640px display ?
J
johndebur
soll angeblich so ein Retina display haben.
3.5吋960x640px触屏 Hiphone 4GS强上市-新机-山寨机网
Goophone 4GS ȷ N8V3i ׿2.3 960*640 ؼ۴-Ա
3.5-inch 960x640px touch Hiphone 4GS strong market
he past, mostly in high imitation iPhone, the interface shape and make efforts, there is little imitation machine can use the "original" or similar to the original material. There are several machines on the market battle quite sound, such as the so-called peak and valley (Goophone) 4GS fruit Gooapple 3G and Google are all holding a machine to OEM speculation. However, it is said that Hiphone / Gooapple / Goophone 4S is indeed used in the original Apple iPhone 4 touch screen, then the original is not original it is not good guess, just say that the phone is indeed a 3.5-inch 960x640px multi-point capacitive screen with the following we will appreciate .
Peak and valley Goophone 4GS use MediaTek MT6573 platform, clocked at 650MHz. With memory is 512MB, which more fierce.
The Hiphone / Gooapple / Goophone 4GS screen resolution is indeed powerful, more delicate screen display, 3.5-inch 960x640px multi-point capacitive screen really is not a blind cover, and 512MB of memory are double cottage in the relatively rare, 1700, said the price was of course is the most expensive cottage, currently MT6573 mobile phone more and more,
111F92424C.jpgT25ah.XdhaXXXXXXXX_305253602.jpgT2zq4.XglXXXXXXXXX_305253602.jpg111IILH7.jpg111FH5K35.jpgT2RW4.XfNXXXXXXXXX_305253602.jpgT2LG8.Xd0XXXXXXXXX_305253602.jpgT2laB.XchaXXXXXXXX_305253602.jpg
J
johndebur
hier noch ein video von shanzhaiji ( ist das goophone nicht gooapple )
Goophone 4GS shanzhaiji link
GooPhone 4GS - 3.5 960x640px youku
Apple's original screen temptations Goophone 4GS comprehensive video presentation
Gu Feng (Goophone) 4GS fruit Gooapple 3G and Google are all holding a machine to OEM speculation. However, it is said that Hiphone / Gooapple / Goophone 4S is indeed used in the original Apple iPhone 4 touch screen, then the original is not original it is not good guess, just say that the phone is indeed a 3.5-inch 960x640px multi-point capacitive screen with the following we will appreciate .
The Hiphone / Gooapple / Goophone 4GS screen resolution is indeed powerful, more delicate screen display, 3.5-inch 960x640px multi-point capacitive screen really is not a blind cover, and 512MB of memory are double cottage in the relatively rare, 1700, said the price was of course is the most expensive cottage, currently MT6573 mobile phone more and more, if you must be a contrast, then only ZHUOFENG i04 (1099 dollars), the difference is a screen, we can compare to buy.
Price: Goophone 4GS Valley High with N8V3i Andrews bee * 640 2.3 960 1650 yuan special promotions capacitive screen (now back to 100 just 1550 yuan) Goophone 4GS taobao link
DoofyMC
Ja, ABER ACHTUNG, das ist die Version für 189,00 USD ohne UMTS/3G/WCDMA!!!
Hier ists für 289,47 US-Dollar mit kostenlosem Versand per DHL verfügbar:
http://www.aliexpress.com/product-fm/505630232-Free-Shipping-Goophone-4GS-MTK6573-930MHZ-512MRAM-512MROM-3-5-inch-5-Points-Touch-Android-2-wholesalers.html
Ich habs mal bestellt für meinen Bruder, der mein Original iphone 4 so toll findet. :grin:
DoofyMC
das wär das ultimative schnäppchen.
aber ich hatte damals nachgefragt, und da hieß es definitiv "No 3G support".
Diese Artikelbeschreibung ist fehlerhaft. Im Titel steht ja sogar DUAL-SIM, was es garantiert nicht hat.
=> http://www.etowalk.com/Goophone-4GS-Android-2.3-Dual-Sim--Dual-Standby_401489_-1.html
Hier ist der richtige Artikel zu 299,00 US-Dollar:
=> http://www.etotalk.com/goophone-4gs-android-234-gingerbread-3g-wcdma-video-call_p2769.html
Den unterschied zwischen
etoTalk und etoWalk hab ich eh noch nicht verstanden...
Luboo
Sobald einer das Ding hat gleich mal testen bitte! Sounds very interesting... für den Preis garantiert das beste zurzeit erhältliche Phone... wenn denn alles paßt ;)
DoofyMC
Hab das GooPhone 4GS bei aliexpress bestellt. kommt mit DHL nächste Woche an.
DoofyMC
So ich habe es jetzt in den Händen! und werde es testen. mein erstes problem ist schon, dass es ein mix aus iOS ist und android. nur hab ich keine softkeys, mit denen man zum beispiel ins erweitere W-LAN menü kommt.
aber ich werd mich mal durchprobieren...
Daemonarch
Chiclone-Lover
Ein Mix? Ich denke eher Android mit nem Iphone-Theme...
Vielleicht kannste da einfach ne deutsche Android-version drüberklatschen, dann sollte es schon laufen. :hi:
DoofyMC
Also es geht los.
1. Der Versand
Ich habe es bei aliexpress bei Carl Lau gekauft. Per DHL. Ab Versand war es innerhalb einer Woche per DHL Express bei mir.
2. Die Verpackung
Es handelt sich um die Originalverpackung vom iphone. Die Ecken waren zwar nicht mehr ganz eckig, aber das lag am Transport, nachdem der Zoll es aufgerissen hat.
3. Das Zubehör
Wie gewohnt:
- Kopfhörer (könnten auch Original iphone-Kopfhörer sein)
- Sim-Karten-Halter-Öffner oder wie man es auch immer nennt
- USB-Kabel (Original iphone)
- Ladeadapter (Original iphone für China)
- EU-Adapter (Billigteil, aber ist wurst)
4. Erscheinungsbild
Ich habe es mir einem Original-iphone 4 verglichen. Es ist kein Unterschied in Form, Farbe, Größe festzustellen.
Auch die Anordnung der Buttons und Tasten ist identisch.
Der Sim-Karten-Slot ist identisch. (Achtung! MICRO-SIM!!!)
Ich kann leider nicht feststellen ob das Front- und Backcover aus Gorilla-Glas besteht. Ein Klangtest (leicht mit fingernagel drauf geklickt) gibt einen minimalen Unterschied im Ton.
Außen Original Metallrahmen.
Es ist minimal leichter als das Original iphone, aber ich denke es liegt an der Akkugröße.
5. Software
Folgende beiden ROMS sind drauf gewesen:
4gs-ios-tx-1209-02.zip
-> iOS-Style mit Cydia (auf chinesisch) und ganz viel chinesischen Apps!!! Slide to unlock screen identisch mit iphone 4, auch iBooks und Appstoer (kein schreibfehler) sind drauf. aber überwiegend chinesisch.
-> hab ich gleich runtergehauen.
mt6513-a6a_lg-native-v11.11.30-update.zip
-> normales Android 2.3.4
-> Funktioniert tadellos
-> Android Google Market ohne Fehler
6. Besonderheiten
Als erstes muss man schnallen, dass es nur ein Button gibt. Der hat die Funktionsweise "Zurück".
HOME-Button: Die Lautstärke "+" Taste ca. 2-3 Sekunden drücken.
Menü-Taste: Die Lautstärke "-" Taste ca 2-3 Sekunden drücken.
Dann kann man auch schon los legen :grin:
7. Akku
Ich habe den 1350 mAh Akku jetzt mal um 09:30 aufgeladen auf 100% und das Ladekabel entfernt.
Habe den ganzen tag nichts mit dem Handy gemacht, außer mal ein wenig durch die Menüs zu zappen.
W-LAN und GPS waren deaktiviert.
Akkustand 20:00 Uhr: 87%
Werde morgen dann den ersten Feldversuch wagen, und das Handy normal in Betrieb nehmen.
8. Display
Ja es ist 960x640 Pixel! Schärfe war im Vergleich zum iphone nicht wirklich unterschiedlich. :grin:
Das soll es Erstmal gewesen sein.
cliffgull24
