T-Mobile HD2 goes ANDROID
Peppo
Funktioniert bei euch das GPS?
Does the GPS is working?
Ich bekomme keinen Empfang mit GPS?
I do not become a fix with GPS?
GeoBroker
@ Full Battery: You need a 2,5mm Flash Cable.
You can also ask the user "rumpelstilzchen" from this forum. I took a cable from him and it has worked. I think it's cheaper than the cable from etowalk and the delivery time is much faster (one day for Germany to Germany).
look here: http://chinamobiles.org/showthread.p...-nach-Handytyp
If you use my complete package, there is no password. Here is my post with the last ROM for the "new sreen" : http://www.mediafire.com/?fcyek08f19ewi7k
@Petertrol: I´m still waiting for a ROM for you. I´m sure, that you had readed my post: "Today I recieved a ROM from etowalk. But I think is the same that I shared. Now eto is online at skype, and I´ve asked again for a "old screen" version. So this is the answer 2 minutes ago:
"i see, we will ask the factory to give us the old screen rom and upload it to you as soon as possible
So today I´ve written once more, because I want to help you.Regards
Doppelpost zusammengefügt nach 8 minutes:
Hi servus,
ja das GPS funktioniert bestens. Das Bild ist von eben. Schau mal unter "Einstellungen-Standort und Sicherheit" ob das GPS unter dem Menüpunkt "GPS-Satelliten" eingeschaltet ist.
Petteri
*lol* die 180 Grad Drehung klappt einfach nie bei allen Anwendungen... (MP3) .... Aber läuft doch geschmeidig.....wie das V5 beim HD9!
petertrol
[video=youtube;tDv3DRjya2g]http://www.youtube.com/watch?v=tDv3DRjya2g[/video]
Here you have my problem with screen. Its not calibrated, im using geobrokers rom, i think i need old screen rom version. But i have discovered a hiding engineer mode, with the phone off, you have to turn it on with the volume down key pressed, and theres an option of screen calibration but it doesnt work for me aswell, i dont know what more things i have to do to have it working. I wait for a new rom to see if i can solve the problem.
The only thing you can do is hope etowalk will get a rom for you for the old screen, but since they do not sell phones with the old screen since they switched the model to Android, I do not give you much hope for that.
Full Battery
Hello guyz
thnx for GeoBroker and his brave trial
but i wnat to ask some
can't we flash the HD9 V5 to the HD2?
we agree that it's the same hardware
petertrol
Looking i cant find a solution for android, somebody could help me to go back from android to windows mobile?? i have flash file but whats the way to do it and what i need? is there any tutorial or somebody could help me, please??
Full Battery
Hi guyz
I noticed that after flashing this android version the signal of my mobile is weak and the reception of the wi-fi is weak too.
another thing that the speakers are low
I know the speakers of the device can do more but I think that ther's a problem in the drivers or the software of the radio and the speakers
all other things are great.
GeoBroker
hi,
I use tethering on my win7 laptop. I think in the Help of Android they had written: only Win Vista, win7 or linux. So I cannot help. On win7 with usb connection it works good and easy
Regards Rainer
Full Battery
I managed to flash the HD9 V5 to my HD2.
but GPS and G-sensor are not working
screen is working and wi-fi
sound volume is v.good
does anybody have a solution?
GeoBroker
so, I can´t help you. because the ROMs doesn´t work at my T-Mobile HD2. The screen does not respond. Sorry
derklotz
Moin GeoBroker,
würde mein T-Mobile HD2 auch gerne auf Android flashen, nur bin ich nicht so der Crack in solchen Sachen, soll heißen die Flashanleitung ist mir bisschen zu kompliziert.
Ich weiß nicht ob ich das hinbekommen würde, habe bedenken das nachher garnichts mehr läuft.
Hättest du Interesse für einen kleinen Obulus mir mein HD2 zu Flashen?
Können das ja mal über PN bequatschen.
MfG
derklotz
bemurmx
HTC HD2 leo
Hi! this work in the HD2 leo?
ROM Version: K102_ESN_S00_V1.0.1
ROM Date: 7/21/2010
Radio Version: 1.07.10061
Protocol Version: DV3.0
CPU: QUALCOMM(R) 8250B
Speed: 1024 MHz
RAM Size: 448 MB
Flas Size: 512 MB
Data Bus: 32 bit
Storage Size: 150.59 MB
Display Resolution: 480*800
Colors: 65536
Bluetooth MAC ad...3610007a2edd
Thanks! greetings!
