T-Mobile HD2 goes ANDROID
GeoBroker
Hi mbrylski
welcome in the forum.
You can use this ROM: http://www.mediafire.com/?fcyek08f19ewi7k
the ROM has many languages. If you want change your OS, you need a 2.5mm Flashcable.
After installing you can install the "update.zip" for the newest version. For the update you don´t need the Flashcable.
here: http://www.mediafire.com/?pbah444bz31bc7b
Please use my new Thread here: http://chinamobiles.org/showthread.php?27776-T-Mobile-HD2-von-etowalk-jetzt-statt-WM6.5-mit-ANDROID-2.2
Regards Rainer
mbrylski
Hi
I looking for MTK USB Driver for Windows 7. Format the phone memory but I cannot installAndroid.
Please help me.
GeoBroker
so now you have a big problem. All the Android ROMs are for the capacitive screen. And in this case only for the "new sreen" model. It was build from october 2010 till today. I think nobody can help you. You have to go back to Windows Mobile. Are you sure you have the resistive screen? When did you buy the phone, and do you have a link to the shop?
Regards
mbrylski
I buy this phone around three month ago but on allegro (polish auction). Can you give me link to Windows Mobile ?? One more question how to use file FLASH.bin I don’t have access to phone memory. Maybe I can tray other ROM for HD2.
mbrylski
Thanks for time that You spend but I do not see any instructions. Can I use SP Flash Tool. I do not understand German well
mbrylski
I receive ROM for my model from etowalk unfortunate it FLASH.bin file. I found tutorial how to install but when I press 1-4-5 or 1-3-5 buttons nothing happens normally the previous version of android started.
Before installation android it worked properly. Now I do not have the card access is built into the phone and my windows not detect SD.
It is possible to install this ROM by the flash tool or unpack ?
GeoBroker
the flash.bin file ist for windows. But first you have to some work with the flash tool. Here is a manual to go back to windows. It is in German,and it is for the HD 9. But it´s the same way. I can´t translate. MaybeAnhang anzeigen TOPS HD9 Windows Flashen.pdf etowalk can send you a manual in english.
mbrylski
Thank GeoBroker for your help I found English version of this manual however, I can’t receive back access to Bootloader Mode. Right now I have installed Android http://www.mediafire.com/?fcyek08f19ewi7k and when I press 1+4+5 or 1+3+5 I tried many others combination of buttons but nothing happens only android started. After pressing Volume down and Power Button I can turn on Factory mode with several tests.
Any idea how receive back Bootloader Mode
GeoBroker
mbrylski
Hi receive some suggestion on other forum
“A flash.bin file is most likely a Windows Mobile ROM. Bootloader does not work, because when you go from Android to/from Windows, you even replace the boot 'program'. I suggest you re-read Bruno's flash instruction with these two facts in mind, but the short of it is, if you cross from Android to/from Windows, you need the entire set of flash files, including the boot one, not just the core ROM”
According to this suggestion I’m looking for this kind of ROM for my phone T-mobile Multi-touch HD2 Dual Sim 8GB I would like return to Windows Mobile.
juannu
Eboot error
When I try to flash android, after connect the USB cable I receive this error: Eboot error: 16007
Please can somebody help me with my problem?
Thanks and sorry for my English but I´m Spanish
veralzasyf07
