GeoBroker
Hi petertrol,
so I like Android. Now ist works good and fast for this model. I want to upload a new video on my youtube channel soon.
Now my answers:
You can adjust the resolution of the camera. I mad a foto with normal setting. and the picture is 2560x1920px. And then you can set higher quality. Then the resolution is the same -
. So it´s not so good
I have no call problems. every call and sms is going from SIM1 and every data is going from SIM2 automaticly, if you choose this in the settings. Everybode hears me good.
The rSignal strength ist better than on WinMobile.
GPS is easy to use. And it works fine. I test it with google navigation, google map and some tools from the market calles "gps test"
Wifi is good and easy to use, too. I think the same as under WM.
But be carefull. Use the energy settings to switch on/off the wifi, bluetooth, gps or other things. These applications need a lot of power. So on my homescreen is the energycontrolpanel.
regards
Rainer
Now my answers:
. So it´s not so goodI have no call problems. every call and sms is going from SIM1 and every data is going from SIM2 automaticly, if you choose this in the settings. Everybode hears me good.
regards
Rainer
Soll ich!?
