T-Mobile HD2 English Discussion Thread
Full Battery
Hello all
Etowaltk issued a new device with Android 2.2
It's called HD9
It seems that it's the same our capacitive HD2 (same specifications)
So how can we get this Android ROM to flash our devices?
I think Petteri will be thankfully make this as he always does.
Petteri
Jeremy told me, doesnt work in moment, because some drivers doesnt work...but they still want to create an update! :)
ddlewis
Petteri gut
Ich folgte Ihre Schritte zu einer T-Mobile HTC ROM Dual-SIM-HD2 zu installieren.
Meldung jedesmal, wenn ich auf dem Bild sehen
ddlewis
T-Mobile htc hd2 dual sim
Ich habe versucht, das Telefon einschalten, aber es ist völlig tot ist.
Ich möchte ihm das Feuer, aber es schmerzt mein Herz ...
Beratung wenden Sie sich bitte
LowMan
ddlewis. Update process does not work on Windows 7 64 bit (I can see You have Win7, I do not know which version).
To flash the phone I have used my old Windows XP machine.
I never got it running on my Win7 64bit machine.
g.romano81
Wifi remote access on Dual Sim T-Mobile HD2
Sorry for asking again but I didn't have any answers!
I have some problem when using Wifi remote Access on my Dual sim T-mobile HD2.
It's easy to use this program but when I digit my IP address on my PC browser it doesn't reach the device.
Could someone help me?
Pettery, do you use this software?
P.S. What about the new ROM? Is it ready?​
LowMan
Re: Wifi remote access on Dual Sim T-Mobile HD2
I do not understand what Your problem is.
Do You want to connect Your HD2 to internet and share the connection with some PC ?
So internet access on PC via HD2?
regards
LowMan
g.romano81
I want to view my hd2 device (files inside it and storage card) from PC.
Sorry if I'm not so clear
regards
LowMan
petertrol
LowMan
Is this possible??
g.romano81
Do you know the function of Wifi remote access?
I would like to use it but it doesn't work on my T-mobile HD2
LowMan
Is this possible??
petertrol
i would like to use my tmobile as modem in order to conect it to a PC for having internet access through the phone, is that possible? how? Thank you.
g.romano81
What about the new Multitouch ROM for T-Mobile?
hey Petteri
I think everybody is waiting for more than 1 month the new ROM!
Is it ready?
