iPDA Wm 7 - ipad alternative?
J
johndebur
Neptux Winpad, hat leider nur resisitven touchscreen und ist mit nem N450 Atom ausgestattet. Hat dafür einen 80GB internen Speicher.
Läuft mit Windows 7 und soll um die 1800 yuans kosten.
Ist allerding noch ein prototyp, insofern könnte sich ja noch was ändern.
http://shanzhaiben.com/81/n-4781.html
The tablet describes the configuration before the first look at it, using the Intel Atom N450 processor, NM10 chipset, 1GB RAM, 80G SSD hard drive, 10 inch resistive LCD screen. Machine size 270x170x17.5mm, weight 860 grams, the standard is 2800mAh battery. Highlight is the use of the 80G SSD, lighter machine. As a resistive touch screen, so this Winpad listing price is relatively cheap, given the price of business 1,800 yuan.
Simple panel, black frame, a single radio button on the panel. And 10-inch 1024x600 screen.
The interface provided, respectively, DC IN, headphone jack, 2 standard USB, TF card slot.
The rear is also very simple, using the aluminum bottom shell. NEPTUX do not know which local brands, the majority or the white card appears.
Such as the iPad the top like a black plastic area to receive Wifi signal. Edge is the location 2 speakers, sound quality more generally.
Prototype provides: Electronic Technology Co., Ltd. Shenzhen Hongrun
Miss Li 13728802290 QQ: 1297168735
3_201012111438442ZRAO.jpg3_2010121114384417MCu.jpg3_201012111438447c1y1.jpg3_201012111438446P96X.jpg3_201012111438448tu75.jpg3_201012111438445sxWD.jpg3_2010121114384436eG6.jpg3_201012111502451rbkX.jpg
J
johndebur
leider nur resistiver touchscreen , aussehen ist ja nicht schlecht: Jinbo INpad:
http://midbbs.cn/html/xinwendongtai/201012/13-3438.html
Jinbo INpad is an 8-inch 4:3 screen A8 Tablet PC, 8-inch screen, 4:3 aspect ratio and based on ARM Cortex-A8 800MHz Freescale imx515 chip architecture is attractive in terms of hardware this product a place where people, from the original operating system upgrade to the existing Android 2.1 Android 2.2, you can directly support Flash 10.1 version, for those who play the web game is very convenient. Having the advantages necessary to introduce the inadequacies of the matter, Jinbo INpad used 8-inch screen resolution 1024 * 768 is not reached, the actual resolution is 800 * 600, touch the way they are single touch resistive;
J
johndebur
Hier ein pad mit 1ghz A9 Prozessor. Steht jetzt da leider nicht hersteller oder wie das Ding heißt. macht aber einen guten Eindruck. könnte eventuell irgentein tablet von malata sein ?
http://art.m8cool.com/113-27245.aspx
video im link:
http://www.tudou.com/programs/view/Dd3IdvReIO0/
CPU dual-core ARM Cortex A9 processors 1G
Memory 1G DDR2 533HZ
Built-in 16GB flash memory, support TF card expansion
10.1-inch 1024X600 screen resolution capacitive touch panel
Interface USBx1, miniUSBx1,
3.5mm headphone port, microphone x1, Bluetooth EDR 2.1,
Data base port. 3G WCDMA slot
Android 2.2 operating system
Internet WIFI GPS
Other built-in gravity sensor 130W light sensor camera
Support 1080P HD playback, 10.1FLash hardware acceleration
The Tablet PC's hardware configuration is quite tough, rather than ipad to is advantage. In the following we will show you the details of it.
This plate uses the latest NVIDIA developed specifically for the small 2nd generation Tegra (Fig. Core 2) processor, clocked reached unprecedented 1GMHZ, the machine interface is very rich. Equipped with a Micro SD card reader, a USB2.0 interface, a Mini USB port and a 3.5mm audio output interface.
In the bottom of the fuselage, is reserved for the base expansion interfaces, extensions can be allowed through the Docking with HDMI, RJ45 network and other extended interface to further improve availability.
In the Tegra chip, Geforce GPU graphics processing units and HD Video and Image Processing Unit Processing Unit were all independent. The instructions provided from the official point of view, HD Video processing unit can support 1080P HD decoding; Image processing unit allows users to more easily and smoothly the browsing and editing photos, and give the user a more perfect operation experience WEB2.0 Internet; Geforce GPU is support for OpenGL ES 2.0, 3D games can be brought anytime, anywhere to enjoy the visual impact, and for Flash 10.1 is fully compatible format, then breaking the tablet PC in the limitations of streaming media applications, and many sites display an incomplete defect.
J
johndebur
Haipad mit verbesserter bluetooth funktion .
http://midbbs.cn/html/MIDchangshangzixun/2010/1216/3477.html
video:
http://v.youku.com/v_show/id_XMjMwMDMzMTY4.html
Heiner Haipad android implement Bluetooth Tablet (video)
Recorded in the official video, also demonstrates how to turn on the Bluetooth function of the machine, how to transfer files to your phone. And demonstrates how to use the Bluetooth keyboard, mouse, headset, flat panel connected to and Haipad.
Schussi
@ Colonel, Du solltest die Boni-Sachen einsammeln und nicht die Schilder und Verkehrskegel :). Schickes Pad, gebe mal mehr Input.
J
johndebur
hier ein Sony Vaio P klon, ist zwar kein tablet, aber klein und tragbar. Sieht ja gar nicht so übel aus :)
http://shanzhaiben.com/98/n-4798.html
The VAIO P high imitation of the model R169, the overall size of 264x137x24mm, bigger than the genuine, the use of the 8.9-inch screen (1024x600), Atom Z530, frequency 1.6G, Intel US15w chipset, 1G DDR2 memory, 80GB SATA hard drive, 1600mAh battery, standard 130-megapixel camera, weighing 800 grams, the market price of about 2,000 yuan.
The bottom of the figure, the battery is the use of external, unfortunately, the battery capacity is only 1600mAh, which often move with it, life becomes too short.
Remove the touch pad, into the red TrackPoint, the whole body looks very thin.
The left of the interface: power input, USB, headphone jack.
The right side of the interface: SD card reader, USB and HDMI.
3_201012181533571IDuX.jpg3_201012181534431yFWs.jpg3_2010121815345210yyG.jpg3_2010121815342117Jnt.jpg3_201012181534121ZD1Y.jpg3_201012181533501djGZ.jpg
J
johndebur
Hier ein Pad mit richtig guter hardware. Nennt sich PV210, design finde ich erstmal nicht toll. Dafür hat es ne gescheite hardware. :)
Steht jetzt leider kein Firmenname oder hersteller da.
http://www.shanzhaiben.com/index.php?action-viewnews-itemid-4800
http://www.shanzhaiben.com/index.php?action-viewnews-itemid-4801
http://www.shanzhaiben.com/index.php?action-viewnews-itemid-4803
Was verbaut ist:
Samsung PV210 main processor chip is used, Cortex-A8 core, clocked at 1.2GHz, 512M RAM, 4GB storage, 8-inch resistive touch screen with a resolution of 800x600, Android2.2 system, support for the latest FLASH10.1 playback, integrated Wifi, G-sensor, the standard battery capacity is 2600mAh, nominal with 6 hours of battery life. Machine weighs about 500 grams, less than the current commercial price of 1,500 yuan. By the way, can upgrade to a later Android3.0, is still not known, but certainly you can upgrade to the latest release of Android2.3.
hier der Benchmark test, gar nicht schlecht:
hier mal zum Vergleich mein haipad benchmark:
was verbaut ist:
Kann auch Spiele, allerdings gibt es da so das eine oder andere Problem mit dem g sensor. Vielleicht kann das eine firmware update lösen.
The Needless to say, responsive touch screen, run smoothly.
The Need for Speed is designed for TI CPU, in the Samsung PV210 gravity sensor can run, but some failures, such as weight loss has the same direction.
Zusammenfassung:
Conclusion:
Software system is user and the Tablet PC interface, good software to run the system compatibility is the basis of, this flat impeccable in terms of hardware, powerful CPU, sensitive touch response, not more than 1,500 price is very worthwhile. Figure in basic reading and browsing the web and e-magazines and other popular chat tools have done well, but the Android system debugging, there are still no small defect, video playback capability of the short board to become an important reason for its overall performance , on the game performance is the same, as I said before the system can be upgraded to Android2.3, when and if the video games can enhance the optimization, this flat will be a greater achievement.
3_201012221021114MdGN.jpg3_201012221021111kAAS.jpg3_201012212247447HV1j.jpg3_201012212247441OgQZ.jpg3_201012212247444m857.jpg3_201012212247442ZL9P.jpg3_201012212247445hOWl.jpg3_201012212247443pVIi.jpg
ManuKilled
naja, da hab ich aber schon Pads gesehen, die dem original iPad ähnlicher sehen, das von dir da hat ja hinten ne schwarze Kappe und ein fettes M auf der Kappe.
Zudem ist die Menüführung auch nicht sehr schön..
