iPDA Wm 7 - ipad alternative?
J
johndebur
SIMPAD: ein neues Pad mit GPS. Ob das aber mit Simeinschub ist ist fraglich stand da jetzt nicht. hat kapazitiven touch und Android.
http://midbbs.cn/html/product/2010/1117/3227.html
Specifications
210mm × 160mm × 13.9mm, weight 550g
Processor
RK2808, dual-core processor, 3D acceleration
Memory
128M/256M/1GB
Storage
2GB/4GB-32GB
Display
8-inch ultra-thin LCD screen, two-point flat-screen touch / pure capacitive multi-touch screen (optional)
Resolution
800 × 600
PMP functions
MP3, WMA, FLAC, APP, OGG, H264, AVI, rmvb, MP4, MKV, FLV, DIVX and other formats to support 720 full-color high-definition video playback
Network
WIFI (802.11B / G)
Port
USB 2.0 transfer, 3.5mm stereo headphone jack, support 2GB-32GB t-flash card
Component output
YPbPr 1080i/720P TV-OUT
Handwriting
Full-screen handwriting
Support, IPAD books, 3D page
Office Software
office applications such as third-party software support needed
Sound effects
Stereo power amplifier; audio output interface; built-in Mic; call stereo headphone jack
Camera
1.3 million pixel high-definition camera
FM reception
Supports synchronous signal transmission
GPS Navigation
Built GLONAV7560 600M ARM9 600M DSP (optional)
Battery
4500mAh high capacity polymer lithium battery
Standby
Use more than 5 hours, 8 hours standby
Program extension
With android application software market, now more than 200,000 applications for free download
J
johndebur
Droipad - Androidpad im iphone 4 Design. naja hat aber kapazitiven touch :) Ist auch aus metall und bei 500g gewicht auch nicht gerade leicht.
http://shanzhaiji.cn/mobile/20101119/21555.html
Play really large capacitive screen Droipad iPhone4 Tablet PC
Configuration no surprise, but the appearance of a high degree of imitation iPhone4 really shocking, more shocking to this screen is to use a 7-inch 800 x 480 capacitive touch screen 5, the spirit of the cottage on its head.
Glossy screen, round Home button, metal jewelry box, four sides of angular, iPhone4 such as works of art like the compact design is complete in the interpretation of this plate out. The relationship between the use of this material is beyond the weight of flat 7-inch flat panel generally a lot, probably in around 500g, full weight, single-hand grip for a long time be a bit difficult.
As for other features and TCC8902 other series is not much different, 3D hardware acceleration, 1080P decoding, external 3G expansion, etc., but due to the addition of capacitive touch screen, the game will feel great improvement. Also built-3000mAH lithium battery, battery life can still be.
J
johndebur
Review vom Freescale iMX515 Apad8 :
http://shanzhaiben.com/45/n-4745.html
video:
http://www.tudou.com/programs/view/oWGWcNISfsM/
An sent Apad will use Freescale chips APad8 iMX515 A8 reached the market, A8 chips, 515M memory, android2.2 system configuration rapidly attract such a high public eye, as if about to set off a storm A8.
APad8 using an 8-inch 4:3 screen, mimicking the shape of IPAD, of course, IPAD smaller than the first, onlookers were unaware of the truth of the probability of mistaken IPAD can be quite high. And the market is relatively common in the widescreen 7-inch, 10 inch flat shell imitation compared ipad public mode, APad8 is undoubtedly the leader in this Parody.
The key function of a positive return, the top button and menu still switch, home button, button basic operation of the system to meet the needs of andorid slightly unfortunately no way to turn off the screen through the keys. Right side of the TF card slot for the machine, 3.5mm headphone jack, power data common interface that does not use universal MINI USB interface, the interface looks like is also anti-IPAD. TF card slot does not use spring design, inserted about 2mm or so will remain in the machine outside.
This machine uses the Cortex-A8 based Freescale iMX515 chips, with 512M memory, and uses android2.2 operating system, such a high hardware configuration, in the current domestic plate already stand out. Through the trial, I think its basic system operation and the daily application of a strong performance in the show, does the domestic flat into a new level. System was not a trace of muddy fluid, a lot of running around after the remains have 300M of memory available, all thanks to this chip and 512M memory configuration, with "strong" to describe is not an exaggeration.
Overall, the video capability is satisfactory, some even 1080P format can win, although the need for software solutions RMVB format, but can do 480P format, normal play, the video has to meet the needs of most people.
VIII Summary
Endurance test: the case open WIFI 3.5 hours of use maximum brightness until the automatic shut down, turn off the WIFI case until the maximum brightness of 5.3 hours using the automatic shutdown.
Advantages:
1, a powerful hardware configuration, nothing wrong with a strong performance.
2, the screen shows good results, a 4:3 screen gives a good reading experience.
3, the touch screen touch very well.
4,2.2 operating systems, performance improvement and FLASH are obvious practical function.
5, boot faster.
Disadvantages:
1, there is great stability of the system optimization space.
2, WIFI weak performance.
3, 3D performance is not strong enough.
4, the machine interface, not universal.
5, no hard solutions RMVB.
6, 800 * 600 result, many programs can not run full screen.
7, no screen close button
Parameters:
Processor CPU: Freescale freescale iMX515 800MHz ARM Cortex A8 core
Operating System: Google Android 2.2 Froyo support Flash10.1
Memory RAM: 512MB DDR2
Memory ROM: 4GB
Extensible Storage: 32GB TF card, maximum support
Display: 800 × 600 8-inch LCD screen LCD
Three buttons: Power On / off key to open the front side of the Back button to return to the menu button Menu Home Desktop
Input device: a single point of resistive touch screen
Sensor: 4 to gravity sensor (sold separately debugging support for individual games)
Video capture: camera position reserved
Audio input: built-in microphone
Audio Output: 3.5mm standard headphone jack built-in speaker
Peripheral support: Standard 30pin interface (multiple data lines extended support)
Power adapter: 9V 1.5A
Built-in Battery: 3900mah (open wifi internet conservative 4 hours, looking for more experience data)
apad8 neben m701:
J
johndebur
Wopad , tablet mit 7" kapazitivem screen und multi touch. Soll 1000 yuans kosten. ist allerdings noch ein prototyp.
http://shanzhaiben.com/54/n-4754.html
Entered the era of early experience of 7-inch screen capacitive multi-touch Wopad
Currently, some domestic manufacturers have began to advance into capacitive screen, recently we saw a 7-inch flat-panel Wopad, multi-touch capacitive screen has become a standard. According to the manufacturer says, this Wopad W7001B official sale price is 999 yuan.
Since this machine is an engineering prototype, you can see above the surface of the touch screen will be a small fraction.
The distribution side of the interface and operation of all buttons, such as power / sleep button, menu and back button. The right is a row of interface, respectively, a standard USB interface, can be used to connect the keyboard, mouse, U disk, etc., a Mini USB, for connecting computers. An HDMI interface to, TF interface, and headphone jack.
Machine's size 195x119x14.3mm, weighing about 380 grams. Configured Rockchip RK2818 chip, clocked at 600MHz, has an auxiliary DSP decoder chip, the maximum can decode 720P video. 256M DDR2 memory, and 4GB memory, 7-inch 800x480 screen, multi-point capacitor, the battery capacity of 3200mAh, Android2.1 version.
3_201011221729241DMXx.jpg3_201011230939481WmWn.jpg3_201011221729242r8RN.jpg3_201011230951131lDNw.jpg3_20101122172924811t9.jpg
_________________________
und noch ein kleines 6" tablet von Hiton?:
http://shanzhaiben.com/53/n-4753.html
but today to introduce a 6-inch flat panel, but also a 16:9 screen, 800x480 resolution,
Machine uses a plastic case, the configuration is more common on the market TCC8902 chips, ARM11 core, 720MHz frequency. 256M comes standard with 2GB FLASH memory and storage space, you can plug TF card expansion space. TCC biggest advantages of the chip video and audio on up to 1080P format movies, and can be connected to the TV HDMI, there are relatively good sound quality.
J
johndebur
ja hab ich auch gesehen, wird aber in japan hergestellt :) Bzw ist es ein japanischer hersteller.
hier noch mehr bilder und review:
http://midbbs.cn/html/pingcedaogou/201011/27-3312.html
http://midbbs.cn/html/pingcedaogou/201011/27-3312_2.html
____________________________________
und hier noch ein Hipad, das laut Hersteller konkurrent zum Apple Ipad werden soll. Hardwaretechnisch klingts ja ganz gut.
Soll auch Preislich günstiger sein. Das Hipad soll es dann in einem Monat geben.
http://shanzhaiji.cn/mobile/20101128/21691.html
Xin Hua Yang claimed to rival Apple iPad next month and listed Yahu HIPAD
He said that this new technology, compared to Apple IPAD, more powerful, more beautiful appearance, cheaper and thus more competitive. Xiamen Xin Hua Yang Lin, chairman of Zaide told reporters, after nearly a year of painstaking research and technology development, the introduction of the elegant Fox "HIPAD" Tablet PC, Freescale Freescale 1.2G A8 core CPU processor, the CPU architecture with the United States Apple uses the same IPAD A8, and "HIPAD" the CPU speeds up to 1.2HZ, even better than Apple's IPAD's 1.0HZ. This compares with the mainstream of China's Tablet PC market in terms of flat-panel models, is a major breakthrough.
_______________________________________
und hier noch highlights der China hi -tech Messe aus Shenzen:
http://shanzhaiben.com/46/n-4746.html
Wopad ( kostet 1000 yuans ) mit kapazitivem screen:
Shenzhen Institute Borch demonstrated a Wopad, 7-inch screen tablet PC capacitor, using the program Rockchip RK2818, 256M memory, and 4GB FLASH, equipped with the Android2.1 system, the overall speed is faster. As a result of a capacitive screen, touch screen feel better, can support more than 5-point touch, which is now one of the few a capacitive touch screen tablet. Show the manufacturer's price is 999 yuan.
Adson Lucky Star MID:
Lucky Star booth Aspect
Shenzhen Lucky Star a MID products on the stand, model M98A, the manufacturer's retail price is 988 yuan. RK2818 is used in the program, 256M RAM, 2GB FLASH resistance and 7-inch 800x480 screen, a 3000mAh lithium battery configuration, product general in nature and did not find particular highlight.
________________________________________
Irgentein ipad ähnlicher klon mit Win 7 :
Here are 2 9.7-inch screen iPad housing and the appearance of flat, has not yet listed. The first is WIN7 system equipped with, it seems that not only can iPad ARM CPU, also use Intel's CPU. Using the power of the Atom Z510 processor, clocked at 1.1GHz, thermal power is only 2W, power and very low power consumption, 1G memory, 16G/32G SSD hard drive options, configuration, 3500mAh battery. Manufacturer's price is 3,100 yuan, the price feels a little expensive.
noch ein 9.7 inch pad mit Android
Another X86 appearance and the appearance of the above similar difference is that, using the ARM freescale iMX515 the main chip, Cortex-a8 core, 800MHz frequency, the current chip is relatively hot, you can upgrade to Android2.2, used 9.7-inch screen, is still only a prototype, mass production and price unknown.
_________________________________________
noch ein android pad
Yifang Digital Beijing took a 7-inch and 8.4-inch flat panel, or Rockchip RK2818 programs, highlights of the 8.4-inch plate, using a 4:3 ratio, 800x640 resolution screen. Machine is very thin, the price announced yet, but the non-mainstream screen size is relatively rare, other configurations are not much different, is the use of Android2.1 system.
__________________________________________________
ein Foxconn tablet:
This is a 7-inch OEM Foxconn Tablet PC, mainly exported to foreign countries, the screen resolution is 800x600, 4:3 aspect ratio, 256M memory, and 4GB FLASH memory, using Android2.0 operating system. Master chip does not indicate, guess might be to use the main chip king is 4760, ARM11 core, based on the MIPS architecture, 660MHz dual-core chips. The current manufacturer's price is 249 U.S. dollars, equivalent to more than 1600 yuan.
_________________________________________________________
Dropad iphone 4 ähnliches tablet, erste demo:
http://shanzhaiben.com/47/n-4747.html
Four views of Shenzhen Science and Technology recently released a Dropad, how it all looks like iPhone4, of course, the system can not be iOS, or we are familiar with Android2.1, using the program is TCC8902,. Configuration no surprise, but the appearance of a high degree of imitation iPhone4 really shocking, more shocking to this screen is to use a 7-inch 800 x 480 capacitive touch screen 5, the spirit of the cottage on its head
Conclusion: The biggest highlight is the iPhone4 plate appearance and capacitive screen, and holding that such a iPhone4 keep returning to the streets, but quite high. No wonder Steve Jobs refused to do seven inches of the plate, because the 7-inch flat-panel already is dominated by the Android.
Contact the manufacturer:
Company: Shenzhen Four Italian Technology Co., Ltd.
Contact: 15510511877 0755-83907820 Zhaojing Li
Website: www.saayi.com E-MAIL: zhaoyawen001@hotmail.com
J
johndebur
dickes Tablet von BYD, sind ja bekannt dafür Autos zu klonen :) Nun ja hat nen 1 ghz prozessor. Allerdings ist das tablett noch ein prototyp, hat im Moment einen resistiven touch screen. Ob es einen kapazitiven touchscreen bekommt ist noch nicht sicher.
Läuft mit Android 2.2
http://byd.com/
http://shanzhaiben.com/66/n-4766.html
The unusually strong Alice flat configuration, using the Nvidia Tegra 250 chipset is a dual-core ARM Cortex-A9 processor, clocked at 1GHz. 8.9-inch screen is used, 1024x600 resolution LCD screen, Android2.2 operating system.
512M and 1GB of memory are both optional, maximum support to the 32G FLASH storage. Bluetooth, G-sersor, Front 300 million pixel camera, 2200mAh lithium battery, almost 8 hours of working time.
It also functions with a light sensor (Light-sensor), according to the intensity of ambient light to adjust the screen brightness of the light and shade. Interface, there is a TF card slot, a mini HDMI, a micro USB, back also with a stent.
However, it is not clear the screen is to use capacitive screens, the screen resistance, the specific time of sale and prices have more news to give you the report.
Hier noch ein langer Ramos W9 review mit lauter Bildern:
http://midbbs.cn/html/pingcedaogou/201012/02-3347.html
Summary, are you: W9 MID as the Blue Devils in the second paragraph of flat products, as opposed to generation of W7, there are lot of progress, both in system speed, or have relatively large increase stability, for use the Internet to read news, play microblogging, QQ chat, QQ online games, and so have been very good, of course, if you want perfection, want to use this large-scale 3D game play, it would not be right for you.
und noch das e人e T2 tablet, funktioniert ohne touchscreen, sondern mit nem Magnetstift, so wie ein WACOM tablet.
http://midbbs.cn/html/pingcedaogou/201012/02-3346.html
e man e the introduction of flat-panel business T2, have been sold for some time, we come to know this machine under, using the Google Android 2.1 operating system and the Freescale ARM Cortex A8 processor, but the screen is not touch screen, using a smart suspended magnetic pen Wacom electromagnetic screen combination, which achieved a unique selling point, the original handwriting handwritten, 7-inch 800 * 480 resolution, 256M of RAM and 2G of memory, WiFi and 3G (extended through USB port), thick 11mm, weight 440 grams, life time of 10 hours, compatible with most 8G SD card expansion, but unfortunately using the 2.5mm headphone jack, let's come back a closer look at specific features:
f the home fans MID​
J
johndebur
Nette Design Idee, Windows 7 - netbook mit klappbarer tastatur wird es zum tablet. Sieht nur recht dick aus.
http://www.shanzhaiji.cn/mobile/20101204/21790.html
1.6GHz Win7 system flat to see the magic of Shenzhen Ed Letter
The creativity of cottage manufacturers in Shenzhen is growing, the recent letter from the Shenzhen Science and Technology Ed brought us a rotating touch-screen laptop, open a notebook, close the computer to transform into a tablet, The real one machine, the following will open the veil of this mysterious tablet.
The effect of making a very beautiful map, a look, like the Sony's cool bags, but bigger than Sony's 8.9-inch screen, 1024 * 600 resolution.
Behind the design is very simple, battery positions below. Battery capacity is designed to 3400mAh.
Win7 operating system pre-installed, when a flat plate with the time and no difference between regular X86.
CPU: Intel Atom N450 1.6GHz
Memory: 1GDDR2 667MHz
HDD: 120G
Display: 8.9 inch capacitive touch screen, 1024 * 600
Built-in camera
Graphics: Integrated Intel GMA 3150
Size: 261 × 147 × 25.5mm
Battery: 7.4V 3000 mA battery
From the configuration point of view, a typical Internet configuration, but the highlight is the appearance of this machine, magnesium alloy metal shell heat better, unique rotating screen design, the other model used in private to avoid "collision." Dell Inspiron Duo just started to accept reservations, cottage version is the first step on the road, and soon you unique access to the Internet to see additional plate of the machine, and this is good Inspiron Duo sold in China do not have listed, and directly back to the home operator the.
1435291.jpg1435297.jpg1435292.jpg1435296.jpg1435294.jpg1435293.jpg1435298.jpg1435290.jpg
hier noch ein testbericht vom Huawei Ideos S7 - 7" screen , 1ghz Android tablet.
Das test model hat laut midbbs ein resistives screen, allerdings kann man das tablet auch mit einem kapazitivem screen bekommen.
http://midbbs.cn/html/pingcedaogou/201012/04-3368.html
7-inch giant screen for the first time Huawei evaluation MID handsets S7
Huawei Smakit S7 (hereinafter referred to as Huawei S7) shape similar to flat, 7-inch 480 × 800 pixels resolution screen, 1GHz processor and 512MB of memory, equipped with Android2.1 version of the operating system,
This time, sending models using resistance test screen, the operating experience on the scaled down, but learned that the user can customize the capacitor upgrade to a more useful screen.
Huawei S7 body size 209mm × 108mm × 15.5mm, plus the weight of the battery reached a 500g (yes, a pound ... ....) The appearance of such a domineering, but for the top with two classic dial key and End keys, no one will think it is the mobile phone.
S7 Huawei Qualcomm Qualcomm Snapdragon QSD8250 processor, clocked at 1GHz, but out of consideration of power to do a certain amount of down-conversion processing, the frequency at about 768MHz or so. 256ROM 512RAM memory combinations can be considered quite satisfactory.
Huawei S7 Android system brings a wealth of useful features and powerful scalability. Huawei S7 supports Wifi, GPS navigation, etc., also built a large number of practical tools and fun games.
Advantages:
1,7-inch giant screen, do not explain
2,1 GHz processor and other powerful hardware configuration, support 720P Play
3, rich multimedia home enthusiast MID
Disadvantages:
1, missed calls and other information suggest inadequate
2, interface, general fluency
093QS4H23.jpg092U61b91.jpg093QW3Z9.jpg093QW6326.jpg093QV46320.jpg093QU3P45.jpg093QQ0R19.jpg093QT4E10.jpg093QT4E10.jpg093QT3485.jpg093QUX13.jpg093QVC38.jpg
hier noch ein Mini tablet mit keyboard von OQO. Hat nur einen 4,8" screen, läuft aber mit Windows. Ist laut midbbs der weltweit kleinste PC :)
Schaut nach nem witzigen gadget aus, man darf nur nicht auf den preis gucken, denn der ist alles andere als witzig. Aber 28000 yuans sind doch ein schnäppchen :p
http://midbbs.cn/html/pingcedaogou/201012/04-3367.html
World's smallest PC OQO Model 03 portable computer evaluation
Just got this product, I hardly carry it with Windows 7 operating system that linked together, 4.8 inches of it only about twice the size of an ordinary cell phone, even better than a lot of MP4, PSP even smaller, so a product's advantages in the portability of natural Needless to say. To make users more intuitive understanding, we compare it to an ordinary bank card camera, as shown below. This family of fans from the MID
This machine is the slide design, open the screen on the physical keyboard that emerges is one of the characteristics of the machine, the relative market can touch a lot of action in terms of tablet PCs, with the OQO keyboard touch input portable computers easier to operate. In addition, the design of the keyboard is backlit, in a dark blue will be issued under the keyboard light, easy to input, which has to a certain extent make up for defects smaller keys.
In addition to the physical keyboard, this product is one of the highlights of the resolution, although only 4.8 inches of screen, but the aircraft has reached the maximum resolution of 1024 × 600, this 10-inch flat panel products and a lot of the same resolution, in such a small the use of the product 1024 × 600 resolution, either text or image browsing display, display very well.
This machine has a compact body, portable advantage is obvious, after weighing, stand-alone weighs only 0.393Kg, even with the power adapter, the whole weight of only 0.655Kg, carry no burden.
The bottom of the machine where the interface more, followed by a headphone jack, HDMI high-definition interface, the bottom of the speaker, power supply interface and USB2.0 interface. It appears that this product not only in operational terms to provide a great convenience, to do the same in the extended area very well.
Remove the battery body, we found the back of the aircraft built in 3G card slot, this is designed to meet the maximum demand for access to the Internet anytime and anywhere. In addition, the aircraft in the upper right corner of the wireless signal enhancement is also equipped with the antenna, the same as the user provides a convenient access anytime, anywhere.
OQO Model 03 (the lowest net purchase 12,999 yuan) version of the hardware configuration leaders
Frequency of 1.86GHz processor Intel AtomZ540
Memory 2GB DDR2 memory
Intel GMA500 integrated graphics card
4.8-inch multi-touch display screen 1024 × 600 resolution
Solid State Drive 64GB SSD hard drive
Battery 9.25Wh
Weight Weight 0.655Kg
Windows ® 7 Professional pre-installed system
The official price of 23,888 yuan
0916494T11.jpg091649544511.jpg09164911177.jpg09164941604.jpg09164a05213.jpg091649B932.jpg09164929150.jpg
Dahmer
Persona non Greta
ja das Huawei ist sehr interessant,ich habe gerade einen händler angeschrieben,ob er seine Pad's mit res. oder kapaz. touch verkauft,mal sehen was kommt
J
johndebur
neues vom Wopad mit kapazitivem screen und Rockchip CPU.
Von der performance her, klingt es so wie das haipad nur eben mit kapazitivem screen.
http://shanzhaiben.com/69/n-4769.html
CRC recent listing of a 7-inch Android Tablet PC, using the domestic Rockchip RK2818 host processor, compared to the previous generation RK2808, RK2818 the biggest change is that the memory upgrade to DDR2, increased the GPU acceleration chip. In addition RK2818 with video hardware acceleration, supports some 3D effects, support up to 1024x600 resolution.
CRC's this Wopad7001, is one of the few first upgrade to the capacitive screen products.
This WOPAD7001 main processor is used in RK2818, ARM11, clocked at 600MHz, 256M RAM, 4GB storage. 7-inch 800x480 capacitive multi-touch screen, 3200mAh battery, Android2.1 system, the whole weight of 380 grams. Now we come to experience up close.
Operation keys concentrated in the top of the machine, respectively, Reset, Power / Sleep, Menu, and ESC.
Concentrated in the bottom of the interface provides a standard USB, to foreign press keyboard / mouse / U disc / 3G card, a mini USB, DC IN, 3.5mm headphone jack, HDMI and TF card.
Bottom shell is used in metal, the metal will shield Wifi signal, so the top of a piece of black plastic area for receiving Wifi signal.
RK2818 can extract the maximum 720P video format, and supports common video formats, AVI, RMVB, MKV, MOV, MP4, etc., to an HDMI cable to connect from the HDMI interface to receive the LCD TV to watch.
Tried a 1280x544 "Kung Fu Panda" Trailer, clear and smooth playback.
However, the game feels RK2818 capacity is very common, similar to the 3D Golf, 3D This 3D billiard game, or "Settlers" This large-scale 2D games run very smoothly. But like Asphalt 5 such a large 3D game, in the prototype did not run successfully.
3_201012061510444aUAp.jpg3_2010120615104439bCu.jpg3_201012061510442Kpg0.jpg3_2010120615104411Xcmd.jpg3_20101206151044100Cth.jpg
Achja seit November gibts das Aigopad N700 in CHina zu kaufen. Kostet 3000 yuans. Das ding läuft ja mit nem Nvidia tegra 2 prozessor mit 512 MB Ram, wiegt 380g. Zusätzlich hat es nen accelometer, digitalen Kompass, 3G funktion, Telefonfunktion, HDMI output und 32 Gb Speicher. Schlecht finde ich es nicht und das Design sieht ja auch gut aus :)
http://notebook.it168.com/a2010/1110/1124/000001124109.shtml
http://www.slashgear.com/aigos-tegra-2-aigopad-n700-android-tablet-arrives-16114300/
As a wireless broadband with 3G technology, with sharing, exchange and other characteristics of the second generation of tablet PCs, N700 on voice calls, multi-tasking, large memory, long standby, five designs have reached the world's leading level, called the current flat panel products, "the king of."
Independent 3D engine in the built-in support, the Patriot N700 Tablet PC support "Zombies," "crazy bird", "skirt blowing" and other classic 3D games, 7-inch multi-touch capacitive screen, three-dimensional gravity sensing design, the player will play a more wonderful time to get the full range of body and mind relax.
Electronics President and CEO Patriot Qu Jingdong, said the function of N700 application of the Patriot more in line with the Chinese consumer behavior, cost is also high, the media price of 2999 yuan.
J
johndebur
hier nochmal ein paar neue MIDS , bzw Pads.
Gpad 802:
http://midbbs.cn/html/xinwendongtai/201012/10-3417.html
http://www.newpad.cn/archives/1714.html
firma: http://www.szltp.com/
TCC8902 optimist Gpad 802 program 8-inch Figure reward real machine
8-inch screen has a 4:3 ipad of origin, 800 * 600 screen resolution.
Interface layout, USB, memory card, audio output, REST hole, HDMI, power input.
Recently upgraded again launched an optimist Gpad 8 inch Gpad802 and Gpad 803, which Gpad 802 has arrived, merchants offer 1,190 yuan. Another Gpad 803 prototype can be built 3G module, is still not yet listed music optimist Gpad 802 8-inch 800 * 600 resolution screen, the processor is still TCC8902 program, 256M memory, support for HD playback and HDMI output 1080P .
1_101210110230_1.JPG1_101210110230_7.JPG1_101210110230_5.JPG1_101210110230_3.JPG1_101210110230_6.JPG
Marvell Armada :
http://shanzhaiben.com/79/n-4779.html
Recently, a listing of a 7-inch flat panel, looking at the appearance of or directed at the iPad to go, the appearance of this iPad tablet, is the use of Marvell Armada 166 chip, based on the ARM11, clocked at 800MHz, 256M RAM, 2GB memory, 7 inch 800x480 screen resistance, 2100mAH battery, support Wifi, external 3G, G-sensor, total weight is 365 grams, is Android2.2 system pre-installed.
Trial Summary:
Armada 166 low-end chips for tablet PCs, and currently popular on the market RK2818, TCC8902, Infront micro-IX220 at the same level. Armada 166's weaknesses is that video playback, as there is no built-in DSP chip solutions can not be hard-720P HD video. Try this machine from the situation, can play 480P video below, but does not support RMVB video formats. Android2.2 system is a bright spot in the machine, 2.2 system, there will be some speed increase, but because it is not A8 core, so the latest FLASH10 video still can not play.
Prototype provides: Electronic Technology Co., Ltd. Shenzhen Hongrun
Lee Group 13728802290
3_201012101206571pATu.jpg3_201012101205511xUsG.jpg3_201012101205513zvld.jpg3_201012101205514B8o9.jpg3_201012101205515OaQ9.jpg3_2010121012055122c7d.jpg
Wurde das Kinpad hier eigentlich schon erwähnt?
[video=youtube;6UkQLo4d1dw]http://www.youtube.com/watch?v=6UkQLo4d1dw[/video]
J
johndebur
ich glaube nicht, da müsste man sich mal durch die 30 Foren Seiten durchblättern ;)
macht aber einen netten Eindruck :)
