Xiaomi RedMi Note 2 Launch 13.08.15 ?
pengonator
So hier noch ein paar Infos zum Xiaomi Redmi Note 2:
Specification
Model:
Redmi Note 2
Sim Card:Dual SIM Card(MicroSIM ), Dual Standby
Color:White | Black | Yellow | Blue | Pink
Capacity
RAM: 2GB LPDDR3
ROM: 16GB | 32GB
External memory: Max. support up to 32GB Micro SD Card
Multi-Languages
Chinese and English as default
(For Multi-languages ,please refer to the screenshot showed above)
Chipset
CPU: MTK Helio X10
GPU: Power VR G6200
Others: Quad-core 2.0 GHz Octa-core 64-bit, A53 architecture
Quick Charge 2.0
SystemMIUI V7 Android 5.0
Screen
Display Size: 5.5 Inch full HD display
Type: IPS LCD, capacitive touch screen
Resolution: 1920 x 1080 pixels
Screen Color: 16000K Colors
Multitouch: Yes
Technology:400 ppi pixel density
Camera
Rear Camera: 13MP Samsung/OV, autofocus, LED flash, Phase Detection Autofocus function, 0.1s focus speed, and a 5-element lens with f/2.2 aperture.
Front Camera: 5MP
Features: geo-tagging, touch focus, face and smile detection, HDR
Video Capture:1080p@30fps, 720p@30fps
Network and Wireless Connectivity
4G FDD-LTE B1B3/B7(1800/2100/2600MHz) ,
TDD-LTE (B38/B39/B40/B41: 2555-2655MHz)
3G: WCDMA 850/900/1900/ 2100MHz
2G: GSM 850/900/1900MHz
GPS: GPS + AGPS + GLONASS + BDS(BeiDou Navigation
Satellite System)
Bluetooth: BT4.0LE
WiFi: 802.11 a/b/g/n/ac, Support 2.4/5GHz,Wi-Fi hotspot,Dual-And, Wi-Fi Direct
Battery capacity and life
3060mAh lithium-ion battery
Standby Time: About 2~3 days
Sensor
Barometer, Electronic compass, Accelerometer, Light sensor,Gyroscope, Infrared, Hall sensor, Proximity sensor
Size
Dimensions: 152 x 76 x 8.25 mm
Net Weight: 160 g
Package
1 x Redmi Note 2
1 x Travel Charger
1 x Usb Data Cable
1 x Battery
Wie man sieht wird es zwei Versionen geben, eine mit 16 GB ROM und eine mit 32 GB ROM. Der Presale hat auch schon bei einigen Shops begonnen.
geekbuying ~190€ + eventuelle Kosten für die 32 GB Version
honorbuy ~165€ + eventuelle Kosten für die 16 GB Version
Laut honorbuy soll ab 20.8. der Versand aus China beginnen. Ob andere Shops auch schon das Redmi Note 2 gelistet haben und den Presale gestartet haben kann ich nicht sagen und da solltet Ihr bei Eurem Shop der Wahl nachsehen oder dort nachfragen.
Barbudo
Mi-Boy [CH]
@pengonator ich glaub die Basis vers. unterstützt nur tdd lte. Basis und mittlere vers. haben nur 16gb intern.
die prime vers. ist der x10 mit 2.2ghz getaktet u d hat 32gb intern.
pengonator
Das sollte man natürlich vorher abklären wie die Versionen sich von den Frequenzen unterscheiden @Barbudo nur sind das so die Specs wie die Shops sie angeben. Was bei Xiaomi in der Produktbeschreibung steht zu den Frequenzen was das hier. Ja die 32 GB Version hat wohl den 2.2 GHz X10.[DOUBLEPOST=1439660784,1439659197][/DOUBLEPOST]Hier mal ein Teaser zum Redmi Note 2..........
pengonator
Abwarten @Barbudo ich denke in einigen Tagen sollten mehr Infos verfügbar sein da ja angeblich ab 20.8. das Shipping beginnen soll. Da kommt dann schnell raus welche die LTE-Bänder die Versionen wirklich haben.
SnowyNight
16gb 2ghz version so 170~ 32gb 200 ~ also all inclusive ca. zumidnest so seh ich momentan die preise
kann sich natürlich noch bessern
X
x990
Bei Ali bekommt man es zwischen 160-180 Dollar inkl. Versand teilweise ohne Steuern
pengonator
Ja ich denke auch das der Anfangspreis so um die 200€ sich einpegel wird eventuell schon inklu. Steuer. Aber warten wir ein paar Tage und dann wissen wir es genau.
pengonator
@x990 ob inklusive oder exklusive wird sich in wenigen Tagen klären wenn dazu Preise und Daten in den Shops veröffentlicht werden. Jetzt ist das alles noch reine Spekulation.
X
x990
Ja steht doch auch das ab dem 20. geliefert wird aber der Preis steht doch schon fest. Sind alles größere Seriöse Händler.
pengonator
Einige größere Shops haben es noch nicht gelistet. Ich denke je mehr Shops das Redmi Note 2 anbieten dann wird sich auch der Preis flexibler zeigen.
Daemonarch
Chiclone-Lover
Der 615er läuft echt super, hatte das ZTE Blade S6 und da hat er auch ausgezeichnete Arbeit geleistet.
Verstehe diesen hate auf den CPU irgendwie nicht.
Jup, mit der Performance im ZTE Blade S6 bin ich auch mehr als zufrieden.
Noch nie besseres GPS gehabt, und auch das man das Gerät ruckelfrei weiter bedienen kann, obwohl der Playstore im Hintergrund apps aktualisiert, kannte ich bis dahin nie!
Obwohl Xiaomi wohl auch mit dem Helio angemessene Antennen verbauen wird, das das GPS auch gut sein wird.
miehegsi
X
x990
Laut Geekvida ist es erst ab ca. 7.9. lieferbar. Honorbuy hat angeblich das weiße 16GB Model sofort lieferbar. Aber ist dafür ziemlich teuer...
