Review Video:
Daten:
5.5" inch capacitive 5-Point Multi Touch Screen
Display 1080x1920 pixel resolution - FULL HD Display, IPS, OGS (?)
MTK6752 64 bit Octa-Core SOC @1.7GHz
GPU: Mali-T760
Android 4.4.4 KitKat
2GB RAM / 16GB of internal memory - TF-card support
Quadband, unlocked, 3G / UMTS / HSDPA+ / WCDMA / 4G LTE
2G GSM - 850/900/1800/1900MHz
3G WCDMA - 850/ 900/1900/2100MHz
4G FDD-LTE B1/B3/B7 - 1800/2100/2600MHz
Wifi, Bluetooth, GPS, A-GPS, BEIDOU, g-sensor, proximity sensor, light sensor, magnetic field sensor, gyro sensor, notification LED (red/green)
OTG - USB on the go
OTA - Firmware update over the air feature (?)
Hot Knot
Off-Screen gestures
Main camera: 13 MP output, autofocus, LED flash, F2.0 (?)
Front camera: 13MP output (5MP real?), F2.4
3780mAh battery?
Dual Sim - Dual Standby
Weight: 146g / 8,05mm thick
Von hier:http://en.efox-shop.com/umi-emax-mtk6752-17ghz-octa-core-55-zoll-fhd-bildschirm-android-44-4g-lte-smartphone-g-302566
Kamera Testbilder / Geekbench Batterie Test: http://colonelzap.blogspot.de/2015/06/phone-available-here-efox-shop.html
