T-Mobile HD2 English Discussion Thread
g.romano81
Ok thank you. I'll wait if you find something at home. I can't find OpenGL at this link http://chinamobiles.org/downloads.php?do=file&id=334
I need OpenGL and sdkcert for Dual sim T-mobile HD2. Are they necessary or yet included in the ROM?
Nor really, because the openGL drivers are different to every hardware... let me look at home or try my upload here: http://chinamobiles.org/downloads.php?do=file&id=334
laborja
Hi, I need help, I was moving the program enginner mode found in the windows and turn off the GPS but not how to turn it back on, someone can help me?
Petteri
??? Where you have found this Program!? I don`t know what exactly you mean! Never heard about such a program on this phone!
cph777
Hi all,
I'm trying to load a new firmware, but i cannot do it, i followed the instructions of Petteri, but no luck.
I see the same issue with a couple of other users at the German-language forum, anyone has an idea? The issue i have and i hope that it will be solved is with the camera, it is like there is no red in the pictures. Another user had it reported at the German-language forum
LowMan
OpenGL
Hi everybody,
I have recieved my phone yesterday. I was using Samsung Omnia and dual SIM HTC T3333 before. Both with Manila. I like this interface a lot, so I would like to have it on my new T-mobile as well.
I installed cab from this forum and it is running - well almost ...
I need this OpenGL support :)
There are some facts that I am already disapointed a little:
- no place for SD card (I have my GPS app installed on SD card, so I was able to move it around easly)
- size of the phone is not 1:1 like original HTC HD2 (car holder does not match)
Can You help me with OpenGL support ?
best regards
LowMan
Petteri
I need this OpenGL support we haven`t found any running devices, there should be any openGL running from A1-, but i couldn`t test!
There are some facts that I am already disapointed a little: - no place for SD card (its internal card) (I have my GPS app installed on SD card, so I was able to move it around easly) -
size of the phone is not 1:1 like original HTC HD2 (car holder does not match) Thats True, like i often explained here
This all you can read in testreports...
LowMan
Yes, seems I did not read carefuly enough.
Well, installing GPS on internal card right now anyway - I will see about the performance and post info here.
@Petteri - You are running SPB Mobile Shell + MobileSense right? How does that combination works with Dual Sim? Normally SPB Mobile Shell does not allow to choose which card to dial from.
Of course I can hack registry and change dialer back to Windows default ...
Petteri
Sure, SPB doesnt support Dual Sim, i laid down an Phone Icon on UI and phone by standard keypad! The default....
LowMan
OK, GPS is running. I use Automapa which polish GPS software - supports most of Europe.
I would like to try out throtlle lanucher and couple of other softwares. I would like to know how to hard reset the phone if I install something that breaks the phone. If I have it connected to power and press green+windows+red (start) I got question about restoring to manufacturers default. It requires me to press VOLUME DOWN. If I try that it does not reset. Any ideas ?
Maybe mine is not exacely the same, since I can not get the update process as well. It says: update failed (it does not even try to update the phone).
Good thing: I am almost done with installing Manila 2d on this phone :)
petertrol
Hi, im looking for a program for remapping the hard keys of the phone. I think there are a couple that works for hd2 i dont know with tmobile dualsim. Somebody has done it in the phone? any good apps? Thank you again
LowMan
As far as I have found so far (I have capacitive T-Mobile version), keys are as follows:
Green phone (not remapable), Home and Windows ARE THE SAME KEY !!! (remapable in Menu -> Settings -> Personal -> Keys), Back (nor remapable), red phone. So there is only one key for remapping - that sucks :(
Added after 4 minutes:
I got Manila 2D running on the phone. I still have some small issues with graphics and additional tabs.
I will post instructions and cabs later (when most of Manila is working). It is much faster then SPB Mobile Shell + Sense UI combination :)
I still can not update phone with newer ROM from here and still do not know how to hard reset the phone without starting Windows (there MUST be a way). That would speed me up a lot, since I would not need to be so careful not to brick the phone. Help anyone?
I got the phone updated :) Turn out You can not do that on Windows 7 64 bit.
I have used Windows XP 32 bit and it woked ... almost.
I got the same problem like some users in German forum - calibration is completly out of scope.
How to recalibrate the screen ? Volume Up + Windows + Red but what next ???
Anyone??
nedcom
dear Petteri
i have a clone hd2 t-mobile 16gb built in, the rom is the standard rom, i would like to flash it with a new rom with touchflo 3d and all the fun stuf, how can i flash it, and what is the best rom regarding the speed for this mobile.
thank you all
nedcom
hi to all...
dear petteri,
as i have viewed the forum, and see the problems and solutions regarding hd2 dual sim, thank you petteri for your afford and time, to help the hd2 owners. NICE JOB.
is there is any hope to make an arabic rom? or at least a arabic font and a keyboard to write and read sms only.
thank you..again
veralzasyf07
