Pinphone - Problem with SIM
boozie1956
Hello.
I have a very strange problem with my brand new PINPHONE. Everything works fine, am still adjusting all settings and playing around.
BUT once I do CALL or receive a CALL I cannot hang up, or use the screen in any way (the different options that appear).
Have done HARDWARE reset and RESET by code 1122!!!!!!!
NOTHING ............ the screen is DEAD while call is active.
I do not know what the reason could be, as the screen works perfectly with the rest of menus and no problems up to now except while calling like mentioned.
Hope somebody has a BRILLIANT idea.
You have to drag the little cirle on the screen to the end call icon. good luck
boozie1956
If you drag the little circle on your display to the end call icon it will end the call. good luck. Maybe you can help me I am trying to connect to the internet via my service provider and had no such luck. Any thoughts?
If you have the option to have those settings send to you by your provider, get the settings for a Sony Ericsson K850i :)
