Meizu MX4 Pro - Exynos 5430 5,5" 2K display (2560 × 1536) 3GB Ram 32GB Rom LTE 5/20MP Cams 3350mah
J
johndebur
Angebliches Bild vom Display. Entweder ist es ein Sharp Display oder eins von JDI.
魅族MX4屏幕曝光:继续奇葩? mydrivers
Meizu MX4 screen exposure: Continue wonderful?
That the MX3 5.1 inch 15:9 screen, it is very special, MX4 normal at?
We should remember that the forum had been revealed before J.Wong, MX4 use 5.5-inch screen with a resolution of 2K level, the whole size of the data maintained MX3, if not achieved, then switch to 5.4-inch screen.
Yesterday, industry analysts Pan Jiutang said, MX4 has started stocking the single, which shows the aircraft's design has been finalized. There are users on the microblogging broke the news, MX4 uses a 5.4-inch screen, Sharp production. PS: 15:9 rhythm?
Although it is unclear authenticity, but it seems very consistent with the characteristics of Meizu. Before J.Wong also seek the views of users, see MX4 is 15:9 or 16:9, you think?
In fact, had come before the JDI 2K over a 5.4-inch screen, the size of 126.67 × 69.59 × 1.12 mm, on the left and right borders are 1.0 mm.
In the case of fixed-length cell phone, 15:9 indeed wider than the 16:9 screen, horizontal display more content, especially in reading pages of text when very favorable. Of course 16:9 is also good, horizontal screen when watching video more appropriate.
This is said MX4 panel
J
johndebur
Noch ein paar BIlder vom Display
0fdc853b20aa44e39d229379bccfd0d5.jpg cab52c2222754994a6275b6929aa3525.jpg f094056857cd47c08f73ba4387651b84.jpg
魅族新旗舰MX4屏幕再曝光!mydrivers
Meizu new flagship MX4 screen again exposed!
Meizu MX4 screen has been a lot of concern kerosene, will continue to be like that continue MX3 wonderful it? Likely.
Following the last exposure, and now once again sent a spy kerosene MX4 two screens, but the post was soon to be harmonious, which also increases the authenticity of the information.
If you look at the exposure of the panel, we do not see anything, but it still gives some kerosene message, the screen is 5.4 inches, the ratio is still 15:9 before, the resolution will be reached 2K level.
If the above is true, then the screen should be used MX4 Sharp tailored it.
Kerosene how to see?
Ausgelebt
Outfluencer
bin da etwas geteilter Meinung, wenn man das Handy in der rechten Hand hält ist das super, ich jedoch halte das Handy meist links und bediene mit rechts, da ist die Lautstärkewippe links besser aufgehoben(Daumen)
J
johndebur
Angebliches Bild vom display
疑似魅族MX4屏幕面板曝光:超窄边框 mydrivers
Meizu MX4 screen panels suspected exposure: ultra-narrow border
Millet phone 4 was released, the new flagship Meizu also to the bar?
Weibo user @ buns machine just to play on the microblogging suspected exposure Meizu MX4 screen panels and design, which can be speculated that some of the MX4 related information.
Pictures from the front panel of the exposure point of view, MX4 MX3 front appearance seems there is not much difference, but the border will be more narrow. From the design point of view, then, the screen surface may MX4 AF film coated with a layer, you can play the effect of anti-fingerprint, anti-scratch ability is impressive.
Also the design although the exposure a lot size, but because the picture is incomplete, we can only see the machine frame is 2.2mm (both sides are 1.1mm), other dimensions and can not be determined.
Of course, this in the end is not Meizu MX4's design also open to question, although this is typical of Meizu style, but does not rule out another Meizu products may, after all, at least four new Meizu prepared this year.
Fragt sich ob die Displaygröße tatsächlich = Gehäusegröße ist? Kann ich mir ja fast nicht vorstellen??
mrkörnchen
...ab und zu mal hier
Naja, das LG G2 hat ja da schon gut vorgelegt, wie man einen großen Screen möglichst kompakt verbaut. Hatte neulich das G2 in der hand. Ist das bisher einzige 5" Gerät, dass ich nahezu problemlos mit einer Hand bedienen konnte. :)
Das wäre natürlich super :) Wenn ich mir mein Mi3 ansehe, da ist das Gehäuse definitiv etwas breiter als Display ;)
J
johndebur
Die Produktion startet angeblich im September.
或九月发布 魅族MX4超高屏占比面板曝光 Pconline
Meizu MX4 ultrahigh-screen or publish accounting exposure panel in September
[Information] from Meizu MX3 PConline release has been nearly a year, the new generation of its flagship MX4 is also speculation turns to the cusp, especially after rival just released annual flagship Meizu pressure greater. Recently, some users suspected MX4 released spy photos of the front panel, you can see the screen MX3 larger aircraft compared to the proportion of the screen also has a new breakthrough. Sources said Meizu first conference will be held in September, the supplier may have to wait until November.
From the exposure map view, fully in line with the front panel style Meizu consistent design style, the ultra-narrow screen frame while the jaw is very narrow, meaning that the proportion of MX4 screen should be to build a high proportion of more than 80%. In addition, design drawings, the current panel is already in the testing phase is completed or has been tested, it seems far away from mass production.
It is well-known industry analysts Sun Changxu broke MX4 will be in volume production in September, and we are currently not received any relevant news conference about Meizu, if released in September, then the machine is likely to sell in the open directly after release.
Configuration, MX4 will be equipped with 5.5-inch screen, the ratio is still the maverick 16:10. Processor is Samsung's latest eight-core processor, support for 4G, running memory 3GB, body memory is 16GB, 32GB and 64GB three versions available, support for fingerprint identification. And this will be abandoned before Meizu austenitic 304 stainless steel, will use better materials and better technology. In addition to MX4, Meizu equipped with MediaTek will release eight-core 4G chip low-end entry-level model, which can be considered in the product strategy not a small change.
J
johndebur
Die Ultimate Edition vom MX4 mit Fingerscanner wird 2998 yuans (361€) kosten, die Standard Version 2498Y (300€) und die Mini Version 1998 yuans (240€).
Angeblich wird der homebutton für den Fingerscanner quadratisch ausfallen.
魅族MX4再曝光:抛弃小圆点? mydrivers
Meizu MX4 longer exposure: abandoned small dots?
Now there is news that, MX4 Pro (J.wong said MX4 There are two versions) dots because fingerprinting join officially declared the end, because the opportunity is equipped with fingerprint recognition, which the Home key will turn bias rounded rectangle (tends square).
In addition, the message also claimed that the curvature of the back cover of Meizu MX4 not as obvious as in the past, and aviation aluminum alloy frame will be extended to cover the formation of a small arc, clever and cover form a whole, rather than simply a in the box.
For MX4 design, sources said the change is very large, and past generations are not the same, exactly on par with the iPhone level 6.
It is reported that, MX4 have the standard version (do not have a fingerprint recognition) and high version, equipped with a 5.4-inch 2K screen, equipped with Samsung Exynos 5430 processor, as for the price Well, sources said, MX4 Ultimate is 2998 yuan, while the standard version 2498 yuan, as MX4 mini version is priced at 1,998 yuan.
