Meizu M9 - 2010
J
johndebur
da hast du recht, aber das m9 ist ja ein neues handy. Das sollte ja meizu berücksichtigt haben. mein t5353+ kanns ja auch ;)
J
johndebur
bißchen überbezahlt , auch wenn schon einfuhrsteuer etc mit berechnet ist. und dann das schlechte deutsch und nur 7 positive sterne, hmm nee lieber nicht :grin:
tasypemo
Mein Freund war gestern in einem Meizu Laden in Shanghai um mir ein M9 zu kaufen - man kann es nur bestellen mit 3 Monaten Wartezeit!
J
johndebur
Meizu M9II gerüchte.
http://shanzhaiji.cn/mobile/20110304/22973.html
The Meizu boss did not disclose JW also long been M9II out the message of hope to send the next word, but JW said m9II for the recent first half of 2011. For this can be used as "artifact continues," the product manager said the 4-inch Meizu m9II has started to develop, but the specific time to market hard to say.
J. Wong said that for this new machine, only his dream machine, others require at least not conflict with his needs. "4-inch m9II can be achieved 63.5 * 119 * 9.5mm I feel great." J. Wong Post said.
For new machines, sources said engineers have plans to try to join the antenna built-FM, but if the result is not satisfactory, they would have to give up, new products to increase the battery life than the present theoretical m9II m9 more strengthened.
Artifact extension of J.wong dream machine is coming down Meizu M9 Ⅱ
4-inch double M9II shell as injection molding, as m6
In addition, J. Wong maintained that the m9 II 960 * 640 resolution or better, and so that it more secure in the next year. Technology risk, product performance and more comprehensive protection. Maintain the existing resolution, A9 dual-core CPU, 1GB RAM and 1GB ROM, back-illuminated camera, and before the camera flash to add some active noise reduction and other small gyro configuration, providing 16GB/32GB storage options, ¥ 3380 on I think should be more appropriate.
The concern of this new machine has been raised at the forum users a great deal of experience of advice: including consideration of M9II remote control or Bluetooth Bluetooth keyboard and mouse support for OTG function, because the dual-core CPU can support our support through the HDMI interface or LCD monitor TV as a tool for the Internet and games (a proprietary interface) and so on.
luralin
Gesperrt
Meizu M9 folgende Änderungen vorgenommen:
1.upgrading Verfahren ist etwas langsamer
2.die Telefon kam schneller, sehr glatt
3.no ändern im Kernel
4.small Änderung des Lade-Animation
5.solved das Problem des Bildschirms Welken beim Laden der Batterie
6.small Änderung der Animation beim Beenden apps
7.adjusted das "Herunterfahren, Neustart, Silent-Mode"-Tasten "-Stellung
8.some Anwendungen jetzt besser laufen in fulscreen (diejenigen, die vorher nicht tun konnte, so)
9.Einige Anpassungen der unlock Bildschirm, USB-Anschluss sowie weitere Aktionen, jetzt sind sie schlauer.
derai
M8 User
Was willst du damit sagen???
J
johndebur
naja das der Bildschrim nicht mehr welkt ,die Aktionen schlauer sind und die Telefon geglättet wurde.
J
johndebur
angeblich läuft Android 2.3 schon auf dem Meizu M9.
Ob der benchmark test stimmt weiß ich nicht, läuft aber ziemllich gut, so wie es ausschaut. Ende März soll dann die ROM fertig sein.
http://shanzhaiji.cn/news/20110314/23108.html
Meizu M9 running score of 2595 points passed by the end of March to play Android2.3
As we all know, Meizu M9's always a Cup points race with! A very powerful configuration, but the points in the software running above the eye-popping ... but the words used to explain the Meizu boss is: the software does not run sub-optimal for the Meizu M9. The engineers .. escape Meizu Meizu M9 Forum's Android 2.3 to run sub-shots, it is a force!
The run chart divided by the engineers in the official forum Meizu disclosure, the first time we will share the latest Android2.3 system M9! Meizu boss said Android2.3 will be the end of March to meet you, do not know if this will not again is the mouth 忽悠 you that we wait and see!
Loonix
Spokenkieker
Aber bestimmt nicht!
Lass dich nicht davon ablenken das der Verkäufer noch keine einzige Bewertung hat :p
Würde mich nicht wundern wenn der Shop in ein paar Wochen verschwunden wäre.
ufo_mobile
Dieser preis ist verdächtig günstig.
Wenn man sich die preise für ein M9 sonst überall ansieht, kann da wirklich was nicht stimmen. :)
Wobei ca. 500€ für ein M9 auszugeben, kann ich mir auch ein Iphone holen.
