Mediatek MT6592 - 8 Core mit LTE TD-SCDMA und WCDMA ?
J
johndebur
Es gibt nun auch einen 8 Core chip für tablets von Mediatek, nennt sich MT8392. Hier ein erster Benchmark Test und Vergleich:
搭载MT8392芯片 MTK八核平板跑分曝光 mtksj
MTK MT8392 chip is equipped with eight-core tablet running of exposure
MediaTek force flat areas is a foregone conclusion , following the release using big.LITTLE architecture MT8135 , the industry also came MediaTek Comin launch eight-core tablet chip news , the latest news shows , MTK eight-core tablet chip or code MT8392, a piggyback the chip products have emerged Tutu database and have run sub- scores exposure.
This product is no exact model information from mt6592_tablet_p1_v1 models to speculate that this product might be the official test engineering machine , so configuration is also relatively common , its processor clocked at 728-1684MHz ( maximum peak of 1.7GHz), the construction Mali-450 graphics processor , 1G RAM +2 G ROM memory , 5 megapixel camera.
By Antutu V4.0 version to run sub- horizontal comparison shows , MT8392 and MT6592 various grades comparable, comprehensive run of reaching 28,904 points. Based on the above relationship can be as bold speculation or between MTK8389 and MTK6589 like , MTK MT8392 MT6592 can be seen as the tablet version , process technology , etc., or consistent with 6592 , both the CPU main frequency same same , of course, will keep true eight -core MT6592 8 -core synchronous operation or part of the core features intelligent closed due to load different .
MT83XX series now has 8389 (T) / 8312 , such as chip production has to support the call and the price is very advantageous , now seven inches MT8312 dual-core tablet has emerged super low price of $ 399 , there will follow another quad-core MT8382 listed , and now exposed MT8392 and MT81XX series , MediaTek flat product lines are maturing .
Vantaa
Bist in bester Gesellschaft , bin auch verwirrt.
Der LTE Chip MT6290 wird doch erst für Q2 2014 an die Hersteller geliefert., gemäß MTK
Und eine 3D Engine und eine GPU...
Da brauch man einen extra Akku in der Tasche (Hose)...
J
johndebur
Naja angeblich sind die ja auch untereinander Komaptibel, also ein Handy mit MT6592 kann ohne Probleme den "neuen" LTE chip MT6590 benutzen. Vielleicht sind das dann gleiche chips.?
MT6595 and MT6592 , is a complete solution that supports 5 -mode (TD-LTE/FDD-LTE/WCDMA/TD-SCDMA/GSM) multi-frequency
Glaube der MT6590 war eine ursprüngliche Bezeichnung vom MT6592 ?
4G products , in addition to already published true eight-core MT6592, MT6290 's original code 4G baseband chip MT6590 or launched in January of this year
So Google Übersetzungen sind halt auch immer doppeldeutig, da die Satzbauweise so verschieden ist.
Beides von hier: http://chinamobiles.org/threads/mediatek-mt6590-mt6595-lte-chip-8-core-lte-chip.37843/#post-438746
Aber ehrlich gesagt blick ich auch nicht durch :p
R
rWx
Das "Könnte" Prinzip gab es doch schon bei dem MT6589 ... Support Dual SIM Active! Und bis heute habe ich zumindest kein MT6589 Phone mit Dual SIM Active gesehen ;)
