Goopad mini - 1,4GHz dual core 8" 1024 x 768 Jellybean 8GB Rom Alu
J
johndebur
sowas gibt es auch von FSL ( http://fushilaipad.taobao.com/ ) wenigstens fällt da der homebutton nicht ab :p
7寸超清屏 MTK双核富士莱760真机惊艳曝光 - 山寨笔记本网  平板电脑资讯站,平板电脑,iPad,平板电脑批发,山寨iPad,iPad皮套,山寨笔记本,山寨本
FUSHILAI 760 dual-core chips MediaTek MT6577, MT6577 Cortex A9 dual-core processor, clocked at 1.2G. PowerVR SGX53 graphics processor; MTK6577 compared with MT6575 single-core platforms, MediaTek MT6577 design architecture can significantly enhance the performance of the browser with a variety of applications up to 40%, this program has added support for 3G networks, deploy 3G/HSPA modem , as well as quad-band EDGE. With the MT6575, MT6577 still contains support for Bluetooth, WiFi, GPS positioning system in the terms of memory FUSHILAI, 760 RAM 1GB, ROM to 4GB.
J
johndebur
moment ich schau mal :)
also laut shanzhaiben enthält der deckel hinten alu, was genau kann ich leider nicht sagen . Denke mal ist innen Plastik und außen rum Alu ?
Allerding habe ich gerade auf der taobao Seite gesehen, daß es erst im März erhältlich ist.
Pre-sale 10 760 has been selling exhausted, officially listed in March, please be patient! Thank you for supporting us, and I wish you all a Happy New Year!
http://shanzhaiben.com/49/n-6449.html
Very FUSHILAI 760 fuselage design features, the fuselage with piano paint, ultra-narrow frame design, the back cover with a double inside plastic craft, aluminum alloy shell and plastic material, not only the appearance of a sense of fashion, is conducive to the signal receives more comfortable in hand, personally think that it is better than the matte texture on many. The whole corner sleek, curved side design makes feel further enhance grip easily loose falling solve the problem.
P
PainAshes
offensichtlich weißt du von vielem bescheid. hast du ahnung was ein e-book reader aus china kostet ? welche seite finde ich das
J
johndebur
lol naja ich nutze eigentlich nur google, baidu und google translate. kann ja mal gucken was sich so findet :p
du meinst diese E-ink dinger? denn tablets können ja auch ebooks lesen
P
PainAshes
dann frage ich mal so; wenn tablets das auch können ^^ was kostet ein das "billigste" tablet muss nicht gerade quallitativ und von der leistung gut sein
J
johndebur
würde ja nicht das billigste kaufen, am Schluß hat es dann so wenig Arbeitsspeicher, daß man keine PDfs etc öffnen kann oder das Umblättern zur Qual wird, weil der Speicher voll ist :)
Also hier wären reviews und berichte zu chinesischen E-ink ebook readern:
飬ֽҳ-йشߵƵ
und die Übersetzung:
Google bersetzer
hier kannst du nach tablets suchen und mit dem Konfigurator z.B nach preis sortieren.
http://product.pconline.com.cn/tabletmid/
die billigsten tablets sind dann die hier , also alles unter 700yuans ( 85€ ):
http://product.pconline.com.cn/tabletmid/p9207/
da gibt es welche für 299 yuan (36€) und 399 yuans (48€)
das hier kostet 299€ http://product.pconline.com.cn/tabletmid/icoo/510232.html
oder das:
http://product.pconline.com.cn/tabletmid/ko/525712.html
oder
http://product.pconline.com.cn/tabletmid/icoo/530122.html
etc. aber glaube kaum das man damit glücklich wird :grin:
P
PainAshes
naja ich kann gut mir schlechtverarbeiteten produkten umgehen, welches könnte ich also jetzt günstig kaufen ?
R
rWx
Was ist denn mit dem Chuwi V8 aus dem Verkaufsfred? Das kostet 75€ und hat sehr gute Specs!
Wie billig soll es denn noch sein?
Soso! :see_stars:
Nen Bekannter hat irgend so ein Billig 7 Zöller aus China für glaube 50$, das Display ist grauenhaft und der Akku hält maximal 45 Minuten!
Du willst ebooks lesen ... da sollte mindestens das Display was taugen!
