Xiaomi Kaffeemaschine ? - Matratze / Reiskocher / Regenschirm / VR / Zahnbürste usw
Chocoball
Endlich kann ich Xiaomi auf dem Klo benutzen. Aber dieser Version ist noch ohne Bluetooth und B20. Pro Rolle 3.7 RMB (47 Cent) und 99 RMB (12,65 Euro) für 27 Stück.
http://news.mydrivers.com/1/549/549275.htm
Amazfit kommt mit neuen Fitnesstracker mit 1,23 Zoll IPS LCD Display, Gorilla 3 Glass, bis 50 Meter Wasserdicht und 12 Tagen Laufzeit. http://news.mydrivers.com/1/549/549205.htm
Yeelight Decklampe funktioniert mit dem Mi AI Speaker. In 2 Versionen, Diameter von 48 und 65 Centimeter. http://news.mydrivers.com/1/549/549260.htm. Die 65 Centimeter Version hat eine Ambilight Leucht dazu.
s_a705f3c40a96451da2e4a4e3321063ef.jpg s_b8dfbeefa6ff4e3fbfc50261546ee117.jpg
J
johndebur
Xiaomi Aqara Überwachungskamera:
https://home.mi.com/detail?gid=100366
169元!小米Aqara智能摄像机(网关版)发布:180°宽广视野 mydrivers
$ 169! Millet Aqara smart camera (gateway version) Published: 180 ° wide field of vision
This morning, millet all raised the first 120 debut, it is Aqara smart camera (gateway version), the public price of 169 yuan.
Aqara smart camera by the millet ecological chain enterprise green rice joint creation, the main intelligent linkage alarm, 180 ° wide field of vision, 1080P HD picture.
The use of 1080P fisheye lens, wide angle reached 180 °, in addition to flat on the table, but also support the adsorption to the wall or roof.
Thanks to the addition of the gateway function, it can connect to the home, door and window sensors, Aqara wall switches and other ZigBee sub-devices, to achieve home security and other automation scenarios.
For example, once someone broke into the body, the door and window sensors are detected, it will immediately issue an alarm and shoot push 12 seconds small video, small video will automatically be stored in the millet cloud, anytime, anywhere view.
s_7a8109b77d624340bb3c11cc896371f2.jpg s_35fbad5a7dda43609deb8d507f2ffbbe.jpg s_12e7c67b77924cde83e4e39d68df169c.jpg s_d2d5d137289d450a990c9c16990e9713.jpg
Xiaomi taschenlampe:
Was haltet Ihr davon ... Xiaomi taschenlampe:
Willst Du eine ehrliche Antwort?
Die hat zwar den Akku schon eingebaut und ist gleichzeitig eine kleine 3350 mAh Powerbank, aber nun, ich halte sie dennoch für hippen Firlefanz mit mal gerade trüben 240 Lumen. Weder eine 'richtige' Taschenlampe noch eine 'richtige' Powerbank. Irgendwas dazwischen halt. Wahrscheinlich eher für solche 'Design-Girlies' gedacht, wie sie in den Werbefotos gezeigt werden.
Für die 10 Euro (79 RNB) würde ich jederzeit eine robuste 'Männer'-Convoy mit 1000 Lumen vorziehen. Oder noch 7 Euro drauflegen und gleich eine BLF A6 kaufen.
Binser
Ahh, sie kann also meine sanftere, weibliche Seite ansprechen! :)
Na das ist doch gut. Dann kann ich mit Hilfe dieser Lampe von meinem Machogehabe etwas mehr Abstand nehmen.
Da würde ich als erstes mal bei den Foren-Shops nachfragen, weshalb es da nie Angebote und Gutscheine gibt. ;)
Steht in der Beschreibung. Nennt sich Vacuum Beschichtung. Dabei wird nicht mit Elektrolyse gearbeitet, sondern das zu beschichtende Material im Vacuum verdampft und aufgetragen.
j880001
