Teclast X16 Pro Tips & Tricks
Binser
ich habe mal aus diversen threads diese Tips und Tricks Sammlung für das Teclast X16 Pro Dual Boot Lollipop/Win10 mit Intel Prozessor zusammengetragen:
Quellen (hauptsächlich):
http://forum.xda-developers.com/windows-8-rt/general/teclast-x16-pro-power-t3277973
http://techtablets.com/forum/forums/teclast/x16-pro-x16-power-forum/
+++Do you know how to enter the UEFI? Is a USB keyboard needed? I would like to be able to boot from a pendrive and backup the system with Clonezilla.
You just need to press (multiple times is better) the DEL key as soon as the Tablet turns on. You can use the Keyboard Cover if you have one or a USB Keyboard to get into it.
+++How-To Remove Android:
- Prepare a bootable USB Stick using your preferred Windows 10 distribution. (Rufus works fine on UEFI systems)
- Boot from USB (you can use built-in Windows Settings to do so - UEFI Firmware Settings - or you can manually switch to the BIOS menu by pressing the DEL button immediately after you turn on the tablet)
- When you reach the "Install" screen do not proceed. Press SHIFT + F10. A command prompt window will be opened.
- Execute these commands "diskpart", "select disk 0", "clean", "exit".
- Close the command prompt window.
- Well Done! You have successfully wiped your eMMC You can now proceed the installation. You won't see any partition now and the installation process will create new windows partitions for you.
+++Hi, how can windows clean install ? I have delete windows Partitions include the MSR Partition.
now i got an error after start install like wrong format ? it is possible to install windows new without delete android ?
You can't. I have already tried.
+++How to root:
I was able to successfully rooted my new TecLast x16pro and I want to share with all of you looking for root.
1.First Install the latest Intel adb drivers for your Teclast X16pro device : https://software.intel.com/protected.../385047/494732
Here you can download the root file ..
https://drive.google.com/file/d/0ByU...c3WF9hSjQ/view
it is same file as for x98pro.
2.Enable USB debbaging in developers option.
3.Boot to safe mode by holding down the power key and then tap and hold in the power menu option "Power off" for 2-4 sec. until you see the safe mode option.
4.Now connect USB cable to your pc and Teclast mini port.
5.Start X98_PRO_5.1.1root.exe and fallow the instruction.
6.After restart you should have superuser install and you need to just update binaries.
+++Default OS selection:
If you uncheck the top left corner tick at the os selector it will
Remember your choice ande doesnt pop up again
You have to keep pressing vol+ during start up to change selection after that
+++Repartitioning:
I have used Gparted and my Teclast is now 7 gig android and 52 gig windows.
All excellent working.
After booting in to x64 gparted I was able to change my partition sizes.
Make sure you create gparted with LILI usb creator.
I’ve been struggling with this for a week, finally got everything perfectly working. I’m running latest Windows 10 x64 home and original Android. I have windows at 53gb and android at 7gb.
I booted into gparted and cut the data partition of android down to 7gb from 20gb, giving windows another 13 gb to work with.
I then copied the persistent, config and factory partitions to the left side of the newly unallocated free space.
Then I relabeled the partitions to the correct labels of the original ones.
Then I deleted the 3 partitions (persistent, config and factory), because they were in between the free space for windows and the newly created free space I chopped off of the android data partition.
I booted into android , I saw the android spinning for about 2 minutes, then it rebooted. Then it went straight into android, no problem. Then I rebooted, attached my win 10 x64 usb stick freshly downloaded from microsoft as well the connected my wireless keyboard and mouse, By pressing f7 I choose usb as a boot option, it booted into the windows installation screen.
I installed windows, then the drivers and everything is perfecto.
Q: I tried the gparted but it only saw my flash drive...
A: You have to burn the newest AMD Gparted ISO and then select proper drive in the upper left GUI
+++Power Supply issues:
Enclosed "TL-U35" DC 5V/3.5A 2.5mm*10mm (Avoid to use it, it is the cause of all issues such as GPU crashes and Touchscreen instabilities)
That's a crappy power supply that causes many issues and probably also some damage to the tablet, so I recommend to avoid using it.
You just have to search for a 5V/2.5A (or higher amperage) power supply that already has a 2.5mm jack or you'll have to cut the cable and replace it as I did.
You can also use a USB to 2.5mm cable to use a standard USB Charger (again 2.5A or higher) but if the USB cable isn't able to handle 2.5A without any voltage drop (e.g. when internal wires aren't thick enough or when the cable is too long, it is recommended to use a 18AWG Cable that isn't longer than 1.2m) you could experience charging issues.
+++ISSUES and FIXES
Android only:
Audio bug/issue:
Issue:
Audio quality via headphones with Android is really poor, especially with less than 50% volume.
It sounds like there is some kind of filter applied to it, which cuts down every low section of an audio track.
This causes a choppy, stuttering sound with the volume going up and down. (hard to describe…)
Also more silent sounds are even more quiet and highs are very peaky.
Occurrence:
e.g opening a YouTube video with a voice and music in the background at 30% volume
Solution:
Issue seems to be software related as it works fine with Windows. Let’s hope Teclast will fix this issue.
Workaround: Try using USB or bluetooth headphones.
Large icons:
Issue:
Default density is set to 280, which makes everything on screen very large.
Occurrence:
Noticeable on home screen or Play Store
Solution:
Change dpi to a lower value; e.g. 200: -> Change dpi without root
Rear camera unusable:
Issue:
Rear camera is not focusing at all and is making “click” sounds when using.
Occurrence:
Default and third party camera app set to rear camera.
Solution:
No fix so far. As before: probably due to a poorly developed rom.
Update: Zooming actually repairs the auto focus for a little while.
Windows only:
Display driver issues:
Issue:
Display driver crashes randomly.
Also mouse freezes in some games.
Occurrence:
Crashes every time I run a 3DMark benchmark.
Trying to play games in native resolution causes weird mouse behaviour.
Solution:
Updating the Intel graphics driver may solve this issue.
Update: Newest intel drivers didn’t fix it for me.
Poor touchscreen responsiveness:
Issue:
The touchscreen is not very responsive.
Occurrence:
Double-tapping a folder or fast typing is very difficult and sometimes not possible at all.
Solution:
Try Phillip Cline’s amazing fix. It works very well!
Both:
Touchscreen bug:
Issue:
The tablet randomly recognizes multiple touch presses at the screen.
Occurrence:
Plug in the power supply and touch and hold at the status bar or navigation bar to get the effect. Or try some different drag and drop gestures.
Solution:
I had no issues when powering it with a different adapter (2A).
Power supply:
Issue:
Power plug keeps disconnecting, which stops charging. No charging via USB.
Occurrence: –
Solution:A different charger works better for me.
Also a 2.5mm DC to USB adapter makes charging via USB possible.
tommy0815
ich gehe davon aus das Du Besitzer eines solchen Tablets bist?
Bist du zufrieden mit dem Gerät?
Das stand auch in meiner engeren Auswahl :)
Woher hast du es bezogen?
tommy0815
@ColonelZap
sorry das hatte ich gar nicht gesehen. Ich hatte neulich hier im Forum bereits nach diesem Tablet gesucht, aber keinen Thread gefunden.
Es gibt eben nur DIESEN Thread bisher! Weiteres OT dann bitte per PN
Binser
Es ist noch zu früh - ich arbeite noch dran. Windows habe ich jetzt einigermaßen eingerichtet, nun bin ich ab heute bei Android.
Was man ja oft nicht bedenkt: Zwei OS heißt doppelte Arbeit beim Einrichten (500+ Apps unter Android, 600+ Software Pakete unter Windows - *nachdem* ich schon zwei Tage aufgeräumt habe!!! - bitte jetzt keine dummen Bemerkungen LOL).
Ethernet adapter wurde nicht erkannt - da habe ich erst einmal gestaunt als Win 10 gesagt hat: Geht nicht!. Wollte das Tablet schon in die Ecke schmeißen, aber für Windows habe ich nun einen Treiber gefunden (dem Post beigelegt), und unter Android ging es mit dieser App:
https://play.google.com/store/apps/details?id=com.jrm.trueonline.ethernet
Da es kein Recovery gibt, werde ich jetzt versuchen Xposed über Rashr oder Flashify zu installieren.
Binser
So, weil ich ja Boot Schwierigkeiten habe, bin ich mal meine Partitionsabbildungen von Drive Snapshot durchgegangen, und habe versucht, die Partitionen nach ihrem Zweck zu benennen und auch mal einfach aufzulisten.
Die Windows 10 / Android Dual Boot Tablets mit UEFI sind ja noch relativ neu auf dem Markt, da könnte es vielleicht mal jemand interessieren / weiterhelfen, eine solche Partitionsauflistung verfügbar zu haben. (In Englisch, weil ich in dieser Sprache meistens Schreibe, denn ich bin hauptsächlich im Englisch-sprachigen Web unterwegs - aber ich glaube trotzdem sollten alle den Inhalt verstehen können):
GPT Disk 64 GB on Teclast X16 Pro - Partition Breakdown
HD1-1.sna RAW Size: 100MB
HD1-2.sna Boot EFI Partition (FAT), Label: ANDROIDIA, Size: 100MB
HD1-3.sna RAW, Size: 30MB
HD1-4.sna RAW, Size: 30MB
HD1-5.sna RAW, Size: 1MB
HD1-6.sna RAW, Size: 16MB
Hd1-7 Virgin Android Ext4 Partition Teclast X 16 Pro.SNA, Size: 3840MB probably Android system files (since it is smaller than HD1-9 which should be data and user apps)
HD1-8.sna Ext4, Size: 256 MB, 35 MB used - probably cache after examining raw HEX
HD1-9 Virgin Android Ext4 Partition Teclast X 16 Pro.SNA, Size: 20480MB (probably data and user apps, since this is the biggest Android partition)
HD1-10.sna RAW, Size: 1MB
HD1-11.sna Ext4, Size: 8 MB, 4 MB used - probably boot after examining raw HEX
HD1-12.sna Ext4, Size: 10 MB, 4 MB used - probably recovery after examining raw HEX
HD1-13 SYSTEM FAT 32.sna, Size: 128MB Label: SYSTEM, EFI vsystem Microsoft
HD1-14.sna RAW, Size: 16MB
HD1-15 Virgin Win10 C Partition Teclast X 16 Pro.SNA, Size: 34122MB, Windows 10 Main C Drive NTFS
HD1-16 Recovery NTFS.sna, Size: 500MB Label: Recovery
Binser
Die obigen Spekulationen lagen ganz schön daneben!
Ich habe jetzt einen sehr einfachen Weg gefunden, wie man die Partitionen bestimmen kann. Mit der ausgezeichneten Testdisk Software, die mir schon sehr oft in schwierigen Fällen bei der Datenrettung geholfen hat.
Hier ist was Testdisk mir anzeigt:
TESTDISK
Disk /dev/sda - 62 GB / 58 GiB - CHS 7603 255 63
Current partition structure:
Partition Start End Size in sectors
1 P Unknown 2048 206847 204800 [android_bootloader2]
2 P EFI System 206848 411647 204800 [android_bootloader]
3 P Unknown 411648 473087 61440 [android_boot]
4 P Unknown 473088 534527 61440 [android_recovery]
5 P Unknown 534528 536575 2048 [android_misc]
6 P Unknown 536576 569343 32768 [android_metadata]
7 P Unknown 569344 8433663 7864320 [android_system]
8 P Unknown 8433664 8957951 524288 [android_cache]
9 P Unknown 8957952 50900991 41943040 [android_data]
10 P Unknown 50900992 50903039 2048 [android_persistent]
11 P Unknown 50903040 50919423 16384 [android_config] (enthält telephony folder mit Daten)
12 P Unknown 50919424 50939903 20480 [android_factory] (enthält leeren telephony folder)
13 P EFI System 50939904 51202047 262144 [EFI system partition]
No FAT, NTFS, ext2, JFS, Reiser, cramfs or XFS marker
14 P MS Reserved 51202048 51234815 32768 [Microsoft reserved partition]
15 P MS Data 51234816 121116671 69881856 [Basic data partition]
16 P Unknown 121116672 122140671 1024000 [Basic data partition]
Also eigentlich alles was man wissen möchte. :freu:
N2k1
Da beide Partitionen im ext4-Format vorliegen, kannst Du sie doch einfach mounten.
Oder alternativ (eine Kopie) mit dem Programm aus dem Anhang "entpacken".
Binser
Danke, aber mehr oder weniger ist die Sache bereits erledigt: Siehe hier.
Dieser Thread ist mehr ein Tutorial über Tipps und Tricks, und da wollte ich halt die Partitionsaufteilung drin haben, weil die für Dual Boot Tablet ja recht neu ist. Ich hätte schließlich nie gedacht, daß so ein Gerät 16 Partitionen hat.
N2k1
Da ich keine Unterhaltung mit Dir beginnen darf, dann also doch hier:
Hast Du in den dargestellten Screenshots eine Verbesserung erkannt?
Mal abgesehen davon, daß es sicherlich 'nen Grund hat, daß da die "Platte" dazwischen war.
Hast Du Dein Gerät geöffnet?
Binser
Wieso darfst Du keine Unterhaltung mit mir beginnen?
Ich habe mein Gerät nicht geöffnet: Ich bin kein guter Grobmechaniker :)
Ich weiß nicht worauf Du Dich mit "Screenshots" und "Platte" beziehst.
N2k1
Tja, wenn man etwas aus der Erinnerung schreibt: "So i remove the brown thin aluminum sheet and the black duct tape."
War keine Platte - sondern wohl nur eine dickere Folie.
Aber ich sehe nicht das, was er beschreibt:
As you see the CPU with thermal mod always throttle at 85°C but can go higher in frequency at 2.23GHz.
Gleich im ersten Bild steht bei "Maximum" 2,4 GHz ...
