Dakele big cola 3 in deutsch ? gibt es wo eine rom ? Miui?
J
johndebur
So hab nun ein paar Romse von der Seite heruntergeladen. Vielleicht hat ja auch Color OS, deutsch mitdabei. Ist ja von Oppo und die verkaufen auch nach Europa. Die andere ROm ist von Dakele selbst, falls es am Besten funktioniert.
Und dann noch Lewa OS, kenn ich jetzt noch nicht, hat vielleicht auch die gewünschten Sprachen?
habe die .zip Dateien original gelassen, muss man eventuell in update.zip umbennenen
http://www.romzj.com/rom/30674.htm
大可乐3 最新更新 flyme4.2 文艺范 去除虚拟键盘.zip
Latest updates flyme4.2 large Coke Fan Art removing virtual keyboard .zip
Googel Übersetzung von dem Rom
ROM presentation
Known bug:
1. Interest screen gestures can not be used
2. The shortcut can not be used in flashlights, flashlight can download their own third party
3. It is recommended not to use flyme suspension ball comes, some will be some problems, although I did not find
(Eliminating the virtual keyboard, in addition to the virtual keyboard, in addition to the virtual keyboard, Ma Ma say important things to say three times)
Tips:
1.flyme default flat bright screen during a call. When you call the phone tilt or cover the proximity sensor will be black, if need bright screen, the phone just to get flat on the line.
2. Accept these painted with bug feedback is welcome, but not welcome alleged sprayer saw really annoying.
Flyme Meizu Android kernel based on tailor-made for its smartphone operating system, designed to provide users with excellent interactive experience and intimate online service.
Meizu Flyme system is reflected in the design of software deeper, one of the core competitiveness of the Meizu phones, Meizu is known as the "soul of the product lies." [1]
Let the big screen more useful Flyme evolved to Flyme 4.0. Natural as a teacher, to all things centered, absorb the color of the seasons, which is integration into the Wabi-sabi style, such Flyme 4 more color, more color.
Interactive level, Meizu basis "big screen interaction" on further reconstruct the screen area up and down the functional modules, allowing for the content on half of the screen display area, the lower half of the touch area. From a functional level, the more system-level integration and better system functionality to the security center, access control, reading centers, allows users to use 4:00 Flyme, more convenient and peace of mind. [2]
http://www.romzj.com/rom/33866.htm
大可乐3 ColorOS 2.1 全新ui 全面更新 轻装上阵.zip
Big Coke 3 ColorOS 2.1 new ui comprehensive update without reservation .zip
Google Übersetzung
ROM presentation
Based on the latest production ColorOS 2.1
After power-on reset once suggested that the first mobile phone
Update again, without reservation only to meet you
1. Add root privileges
Do not mess delete system files and upgrade license management program generally does not appear to restart the reactions of individuals 2.
3. To fix the camera. The camera uses official
4. Add the black gestures, will increase the power consumption after opening, please use discretion
http://www.romzj.com/rom/30949.htm
大可乐3 乐蛙 OS 15 4 18 体验版.zip (LewaOS)
3 large Coke Le Frog OS 15 4 18 Trial Version
Google Übersetzung:
ROM presentation
Le Frog OS is based on Android OS localized development, user experience, core applications, hardware adaptation, etc. a lot of secondary development and optimization.
Known Bug:
1. The information screen can not wake up.
2. This rom in TCL, based on a model adapted HotKnot function can not be used.
Content adaptation:
1.ROOT Management Update
2. Add the keyboard lights function
http://www.romzj.com/rom/30200.htm
大可乐 MC003 (移动4G版) 最新官方ROM 卡刷包.zip (ist aber China Mobile 4G, also TD-LTE und TD-SCDMA)
Big Cola MC003 (mobile 4G version) the latest official ROM card brush package
Google Übersetzung:
ROM presentation
1, extract produced based on the latest official stable version 2.0.15
2, complete the official original
3, adding only complete ROOT privileges
4, support for official ota update
For groups:
1, the pursuit of stable original official ROM
2, like the original
3, do not chase the new, often do not want to brush machine, long-term use
Hier alle Roms im Ordner:
https://drive.google.com/open?id=0B_zcMr2cMNjZdXJQUXFTUlBpSjQ
psychofrog
@johndebur
Danke für deinen Einsatz!
Leider kann ich mit dem kelui nur die original datei von needrom flashen! ( zumindest scheint es so, daich ja nichts lesen kann!) aber danach alles neu einstellen muss!
möchte ich irgendeine andere datei flaschen, bricht er ab! (flyme miui ...)
solange ich nicht verstehe was da steht bin ich am Ar,..!
anscheinend gibt es kein CLW oder TWRP für diese handy?
das ist echt verrückt!
Das handy ist noch mmer auf alter software! nur jetzt erkennt es mtkdroid nicht mehr und jegliches root programm auch nicht! usb debug ist on! der pc kennt es als MC003 !
psychofrog
Ich steig echt nicht mehr durch! Oder seh den Wald vor lauter Bäumen nicht?
Ich glaub es liegt nur an den root rechten? aber ich kann es mit nix rooten!
J
johndebur
ja das ist die handy Bezeichnung. Wird also richtig erkannt. Wenn du nicht weißt was da steht einfach Foto vom Display machen und übersetzen lassen. Oder einfach hier posten, dann kann ich ja helfen.
Root sollte ja bei den Roms dabei sein, nur wenn die sich nicht installieren lassen ist das blöd. :)
Wenn dann wird dort auf der Seite empfohlen mit dem Root Wizard PC Programm oder der Android .apk zu roooten. Ob das funktioniert , weiß ich nicht. Das Problem ist, das die software auf chinesisch ist.
Die ROm Seite verlinkt hier her: http://www.shuame.com/root/
hmm gibts wohl auch auf Englisch: http://www.shuame.com/en/root/
Muß man viel rumklicken und sich die chinesischen Schriftzeichen vorher übersetzen lassen. Will jetzt auch nichts falsches empfehlen. Wenn es um rooten von Mediatek Cpus geht, dann gibt es hier ja auch einen thread mit Experten. :)
hmm war glaube ich dieser thread: http://www.chinamobiles.org/threads/mtkdroidtools-erfahrungen-tipps-tricks-download.37769/
kann ja nochmal googlen , ob ich eine recovery finde.
Ah ja gefunden. Hier wäre eine recovery. Ob das nun die originale ist oder was anderes, weiß ich nicht. Bin jetzt auch gleich mal weg. kann es ja später heunterladen, wenn du probleme hast.
http://tieba.baidu.com/p/3803810415 (dort ist auch eine Anleitung)
3 large Coke official Recovery: http: //pan.baidu.com/s/1mgwxcbI
ist wohl die originale
habe auch noch diese ANleitung gefunden: http://www.shuame.com/faq/beginner/14319-dakele-mc003.html
und hier gibt es eine alternative recovery: http://www.yzmg.com/news/show-90727.html Wird vermutlich chinesisch sein. habe aber selbst schonmal mit Google Übersetzung diese übersetzt. Könnte da auch helfen.
psychofrog
Schön langsam geb ich auf!
Handy ist jetzt gerootet!
Recovery ist das gleiche das schon drauf war! der drittanbieter lässt sich nicht installieren!
ich würde gerne wissen wie die chinesen das auf ihr handy kriegen!
viel anders als jetzt bei mir gehts ja nicht mehr!
im recovery kann ich mitlerweile wipe machen und über sd karte rom (nur das originale von needrom geht) installieren!
verrückt!
psychofrog
das rom von needrom läuft bei der installation durch!
alle anderen brechen mittig ab oder starten erst gar nicht!
p.s
Kann es sein das die über fastboot flashen? ( so wie die one+one? )
vielleicht kannst dich da noch schlau machen! ( mein pc mit übersetzung! ohje;-( )[DOUBLEPOST=1453793750,1453792231][/DOUBLEPOST]@johndebur
Kannst du das vielleicht noch online stellen?
von dieser seite
http://www.dakele.com/rom/index.htmlbur
das miui ! wenn es auch für das big cola 3 ist!
psychofrog
@jahndebur Danke!
Herr Doctor Phone hat keine idee?
Der boot ist immer noch gesperrt! ??
Was haben die chinesen für einen Clockworkmod / TWR / Philz?
Ich würde gerne chinesisch lesen können oder die hätten einen englisch Thread über ihr benütztes recovery!!!!
( und ich bin zu löd für diese übersetzungs geschichten! ;-)
der originale Keleui lässt nur immer diese eine rom durch! alle anderen starten nicht oder brechen sofort ab!
psychofrog
Hallo Leute!
Ich brauche nochmal eure hilfe!!
Ich bin kurz for dem ziel!
Ich könnte jetzt über scatterifile ein recovery oder original aufspielen! (könnte!)
leider kriege ich das teil nicht in den download modus! (welche tasten muss ich hier drücken? akku kann man ja nicht rausnehmen!)
danke Leute!
p.s dieses ganze scatter chinesen files muss mann umbenennen in irgend etwas deutsches! dann wird auch was akzeptiert!
MantisWu
Hi
ließ dir mal die Tutorials fürs Sp Flashtool durch.
Du musst das Handy einfach ausmachen und kannst dann, wenn du die richtigen Treiber hast, das Ding anschliessen und dann flashen.
Aber ließ aif jeden Fall ein Tutorial du kannst das Handy auch zum Briefbescherer machen wenn du da was fladch flasht. Vor allem mit dem Nvram gucken.
Grüss
Matthias
psychofrog
Ja leute so mache ich es auch immer!
Hatte schon elephones und jetzt redmi note 2!
aber dieses dakele will einfach nicht!
darum wirds verkauft!
danke an alle für die unterstützung!
goll
