Windows 10 Tablet gesucht
Andycat
wie schon wieder .......solch einen Beitrag hatten wir schon vor kurzen.....
Musst mal die suche quälen......[DOUBLEPOST=1450339663,1450339540][/DOUBLEPOST]sooo hier..............
http://www.chinamobiles.org/search/3793386/?q=win+10+tablet&o=date&c[node]=141+297+144+163+164+239+241+3+58+15+27+14+54+155+158+222+223+224+276+249+182+183+184+277+267+156+177+159+278+250+309+310+311+312+313+157+178+160+279+268+165+179+166+280+269+209+210+211+281+251+167+180+168+282+270+188+189+190+283+252+191+242+243+244+284+253+169+181+170+285+271+185+186+187+286+272+228+229+230+287+254+225+226+227+288+255+192+193+194+289+256+197+198+199+290+273+203+204+205+291+257+245+246+247+292+258+200+201+202+293+274+218+219+221+294+259+213+214+215+295+260+206+207+208+296+275+176+175+344+345+346+4+52+111+118+119+120+121+122+143+62+123+124+125+126+63+136+137+138+139+140+96+95+97+98+99+100+20+19+90+91+92+93+94+40+195+196+307+308+101+103+104+79+127+132+131+133+134+135+80+82+70+71+72+73+129+142+231+232+233+234+304+262+314+263+264+265+266+306+299+315+235+236+237+238+305+298+316+261+74+75+83+86+87+88+76+89+145+146+147+149+150+151+148+152+153+154+10+55+25+56+130+26+57+8+128+16+48+45+65+11+34+12+17+110+212+248+38+39+319+334+347+349+350+351+352+331+353+355+356+357+358+324+359+361+362+363+364+332+365+367+368+369+370+327+371+373+374+375+376+325+377+379+380+381+382+323+383+385+386+387+388+333+390+392+393+394+395+320+338+340+341+342+343+337+396+398+399+400+401+329+402+404+405+406+407+321+408+410+411+412+413+335+414+416+417+418+419+326+420+422+423+424+425+336+426+428+429+430+431+328+432+434+435+436+437+322+438+440+441+442+443+330+444+446+447+448+449+389+450+452+453+454+455+456+457+459+460+461+462+464+465+466
Mike89
http://www.chinamobiles.org/search/3793386/?q=win 10 tablet&o=date&c[node]=141 297 144 163 164 239 241 3 58 15 27 14 54 155 158 222 223 224 276 249 182 183 184 277 267 156 177 159 278 250 309 310 311 312 313 157 178 160 279 268 165 179 166 280 269 209 210 211 281 251 167 180 168 282 270 188 189 190 283 252 191 242 243 244 284 253 169 181 170 285 271 185 186 187 286 272 228 229 230 287 254 225 226 227 288 255 192 193 194 289 256 197 198 199 290 273 203 204 205 291 257 245 246 247 292 258 200 201 202 293 274 218 219 221 294 259 213 214 215 295 260 206 207 208 296 275 176 175 344 345 346 4 52 111 118 119 120 121 122 143 62 123 124 125 126 63 136 137 138 139 140 96 95 97 98 99 100 20 19 90 91 92 93 94 40 195 196 307 308 101 103 104 79 127 132 131 133 134 135 80 82 70 71 72 73 129 142 231 232 233 234 304 262 314 263 264 265 266 306 299 315 235 236 237 238 305 298 316 261 74 75 83 86 87 88 76 89 145 146 147 149 150 151 148 152 153 154 10 55 25 56 130 26 57 8 128 16 48 45 65 11 34 12 17 110 212 248 38 39 319 334 347 349 350 351 352 331 353 355 356 357 358 324 359 361 362 363 364 332 365 367 368 369 370 327 371 373 374 375 376 325 377 379 380 381 382 323 383 385 386 387 388 333 390 392 393 394 395 320 338 340 341 342 343 337 396 398 399 400 401 329 402 404 405 406 407 321 408 410 411 412 413 335 414 416 417 418 419 326 420 422 423 424 425 336 426 428 429 430 431 328 432 434 435 436 437 322 438 440 441 442 443 330 444 446 447 448 449 389 450 452 453 454 455 456 457 459 460 461 462 464 465 466
Danke aber da hab ich schon geschaut habe da nichts passendes gefunden deswegen habe ich diesen Beitrag gemacht.
flocker
Andycat
Muss gestehen das ich meist nur Win 10 nutze......Ist schnell und flüssig.....
Android interessiert mich auf diesem Tablet nicht so......
Profirudi
Da bin ich gespannt ob das funktioniert. Onda ist für die Android Roms nicht berühmt.
Das nächste Problem ist die schwache WLAN Reichweite. Dort wo meine Xiaomi Handys immer guten Empfang gehabt haben, bricht WLAN dauernd ab. Muss muss schon direkt neben dem Router sitzen das es funktioniert.
@Andycat wie bit du mit dem WLAN zufrieden? Wie ist die Reichweite?
Mike89
Also WLAN Probleme klingen nicht gut da ich das Tablet schon gerne Zuhause über WLAN nutzen möchte.
Profirudi
Ich habe bis jetzt zwei Onda Tablets, zwei Teclast und ein Cube gehabt.
Onda hat einen ganz schlechten Android Rom. Hat schlecht funktioiert und immer Probleme gemacht.
Das Teclast P98 war vom Rom her auch eine Katastrophe. Costum Roms konnten nicht helfen. Das X98 AirII hat ein mieses WLAN, wie alle X98. Das Problem ist bis jetzt nicht behoben.
Das Cube I6 hat ein genau so schlechtes WLAN. Ich vermute das Onda, Teclast und Chuwi bei den Tablets ziemlich identische Hardware und auch Software einsetzen.
Ich habe D-Link, Fritz und TP-Link Router probiert. Es liegt nicht an den Routern, sondern an den Tablets.
Bei den Tablets ist immer die Verbindung abgebrochen, wo ich mit dem Handy guten Empfang hatte. Wenn die Verbindung da war, dann hatte ich laut Speedtest nur ein zehntel der Geschwindigkeit vom meinem Handy.
Handy z. B. Down 6 Mb/s, Tablets 0,7 Mb/s.
Ein Tablet ohne ordentlichen WLAN ist für mich nicht brauchbar.
Habe mir jetzt das Chuwi Hi10 bestellt. Mal schauen ob es besser wird.
Bei den Tablet ist auch bei XDA von WLAN Problemen die Rede.
PS: @wydan Hier siehst du das man auch ohne Kimovil Links Beiträge schreiben kann. Ich hätte hier natürlich auch bei jeden Tablet so einen Mist Link setzen können, aber ich glaube damit hätte ich hier nicht geholfen.
rilerale
Nö kann man nicht sagen, meinst liegt es an der Plattform und Windows 10. Mit dem Cube i6 und dem alten Win8 Treiber geht es mit dem WLAN. Es gab in einem X98 Trend beim großen A einen Verweis auf einen HP Treiber. Damit soll wohl alles klappen. Fakt ist man muss schon ordentlich Händen legen.
Profirudi
Also kann man sagen das die China Tablets noch nicht zu empfehlen sind?
Das kann ich dir sagen wenn ich mein Chuwi Hi10 habe. Wenn das auch nicht geht, kaufe ich mir eines hier.
Ich habe beim Cube I6 Windows 8.1 drauf und WLAN geht auch nicht. Beim Teclast X98 habe ich die Treiber von XDA installiert (die sollten angeblich gehen), aber das WLAN funktioniert auch nicht besser.
Mike89
Dann werde ich mal warten bis du das Chuwi Hi10 getestet hast.
Weil ich interessiere mich für das Chuwi Vi8 Plus aber leider erst noch im pre-sale daher leider noch eine Testberichte.
Profirudi
Wie sieht es bei dem mit Windows 10 aus?
Und bei Android 4.4 mit der Stagefright Lücke?
Ein Update auf Win10 ist sicher kein Problem.
Stagefright - da habe ich keine Ahnung.
Seit dem ich ein Windows Tablet hatte, habe ich Android gar nicht mehr verwendet am Tablet. Weil mit Windows hat man eigentlich einen vollwertigen kleinen PC. Da braucht man nicht für alles extra eine App. Und Video schauen ist auch einfacher, weil z. B. Flash Videos kein Problem sind. Also am Tablet gefällt mir Windows besser als Android oder IOS.
