Xiaomi Mi Pad 2 - Intel Atom x5-Z8500 7,9" (2048x1536) 2.24GHz 2GB Ram Android 5.1 / Windows 10
J
johndebur
Angebliches Bild von einem neuen MiPad, das eventuell neben dem Redmi Note 2 Pro am 24.11. vorgestellt wird? Soll angeblich ab 1499 yuans kosten (220€)
Könnte auf jeden Fall zu Xiaomis Ankündigung passen ,daß was sehr dünnes kommt?
1499元起 小米平板2价格首曝 双系统 mydrivers
1499 yuan millet flat 2 price first exposure dual system
This evening, Lin Bin, president of millet on the microblogging drying out of a "new finale" renderings . From the size point of view, it should be the previously rumored millet flat 2.
From the image point of view, a new generation of millet plate appearance has changed considerably, as is likely, and iPad is equipped with a metal shell, overall more mellow.
Configuration, GeekBench database before we had found a product called "Xiaomi MI PAD 2" of the product, it is equipped with the Intel Atom x5-Z8500 quad-core processor, clocked at 2.24GHz, with 2GB of RAM, running a Android 5.1 system.
In the case of the configuration has improved, and is equipped with metal housing, the cost of millet 2 flat compared to the first generation of products is bound to increase, so the price may have a little more expensive.
According to sources, millet flat 2 may be divided into low and high equipped with two versions, the former price of 1,499 yuan, while the latter is 1799 yuan.
In addition, a new generation of millet is said tablet will also support dual system(Android + Win10), before millet 4 brush Win10 is to pave the way to a new generation of millet flat.
http://news.mydrivers.com/1/457/457500.htm
http://news.mydrivers.com/1/457/457487.htm
s_522de005459e44a1bb6898d1ba7c813b.jpg s_fa8ecd9ed9c94d6cb9f0a32246ac0c42.jpg s_15c72ae4de7a4bb1b6a6c6bc5252fbd4 (1).jpg
Xiaomi Rucksack gibt es jetzt auch schon:
http://item.mi.com/1154400038.html
http://news.mydrivers.com/1/457/457461.htm
149 yuan shipping! Millet shoulder bag came: not very type Logo
s_1b32d089a39747c09913578a6786edca.jpg s_3d863a3df9dd45a6a639e1bb1939a20d.jpg s_28b25cef0edb4b3897043c7d9d20b5cf.jpg
JensK
Hmm, aber die haetten zu ihrer "Hirse" auch mal was von der Display Groesse und Aufloesung schreiben koennen. (oder hab ich nur Tomaten auf den Augen und habe es nicht gefunden?). Wenn ich das Bild mit dem Pad in der Hand approximiere, schaut das ja wie 7" aus. Das ist fuer mich kein Tablet und kein Phone, sondern einfach nur gewollt, aber nicht gekonnt.
rilerale
Wenn es stimmt mit dem MIpad2, HABEN WIIIILLLLLLLL !!!!!!!!!
Warum eigentlich haben mir doch gerade ein Cube i6 gegönnt und unter Qualen das Teil Platt gemacht und Win10 pro drauf gequält. Wer sagt eigentlich das Win 10 auf einem Tablet besser ist als Win 8.1. 64bit geht nicht da irgendwelche Treiber im tiefsten Innern von Win10 auf dem Intel nicht gehen, usw. und sofort.
Ähh warum jetzt das Mipad 2 ??? Achja da steht Mipad drauf.
Es ist schon komisch ich rege mich über Apple auf aber schiele jedesmal wenn Xiomi was vernüftiges rausbringt. Okay in letzter Zeit wird ja alles mögliche rausgebracht. Gibt es eigentlich schon eine Xiaomi Klobrille oder besser eine Xioami Ferguson mit Bluetooth????
muhamed
Kein microSD und kein GPS, dann oft 250€ 64GB und schon macht das Z3 Tablet Sinn.
EU Warenhaus noch nichts gefunden...
cliffgull24
