VKWorld VK6735 Review: Better than a Doogee Y100 Pro?
Sotair
Kaffes Nikotides
Thanks a lot for both the review and unboxing vids. Maybe it would be a good idea to provide some basic information and a written summary, too. Maybe in a short + / ÷ neutral / - conclusion like below
Price: about 109 $
Specs:
OS Version: Android 5.1
CPU: MTK6735 Quad Core
Processor Speed (max): 1.0 GHz
RAM: 2GB
Internal Memory: 16GB
External Memory: Support up to 32GB
Display
Resolution: 1280X720
Touch Screen: Capacitive, Multi-touch: Support 5 Point
Network:
Frequency: 2G: GSM 850/900/1800/1900MHz, 3G: WCDMA 850/900/1900/2100MHz, 4G: FDD:2100/1800/2100/2600
Other connevtions: GPS, Bluetooth, FM Radio and Portable Wi-Fi Hotspot (3G Tethering)
Sensors:
Proximity, Accelerometer, Gravity, Light
Battery:
Battery Size: 3000mAh
Continuous Usage Time: About 4 Hours
Battery Standby: About 200 Hours
Wi-Fi: 802.11 b/g/n
Cams:
5 Megapixel Front-Facing Camera + 13 Megapixel Rear Camera
Video Resolution: 640x480 Front / 864X480 Back
Other Features: Smart Wake, Hotknot
Ports:
2 SIM card slot – 1x Micro SIM (WCDMA/GSM/4G), 1x Normal SIM(WCDMA/GSM/ 4G)
1 Micro SD card slots
3.5 mm Audio out port
Micro USB
Languages: Multilanguage, German supported
Dim./ Weight: 142 x 72 x 8 mm (L x W x D) // 136g
Review summary:
+ Good battery life
+ Good baseband reception (2g/3g/4g)
+ Backcover design (just plastic, but good grip)
÷ Display quality
÷ Performance (Antutu score ~20500)
÷ Camera (back 13mp, front 5mp, colors look washed out)
÷ Lower midrange SoC, but smooth handling & no lags
÷ Mono-Loudspeaker
- Bad WLAN downstream (should be checked again)
- Screen to body ratio (fat bezels :))
zijin_cheng
Price: about 109 $
Specs:
RAM: 2GB
Display
Network:
Sensors:
Battery:
Wi-Fi: 802.11 b/g/n
Cams:
Ports:
Micro USB
Review summary:
+ Good battery life
÷ Display quality
÷ Mono-Loudspeaker
That's a great idea. However I am preparing a written review that will go up as soon as i'm done. Thanks for the tip though!
closebor
