Xiaomi Powerbank - 16000mah Alu
J
johndebur
neue powerbank von Xiaomi, die im November erhältlich ist. double 11, heißt wohl 2.11. ?
Kostet in China 129 yuans (16€)
http://www.weibo.com/2202387347/Bu9kl3IoV?mod=weibotime#_rnd1414768028341
真的是它!小米16000mAh移动电源发布 99元 mydrivers
It really is! Millet 16000mAh mobile power released 99 yuan
Recently, millet phone official microblogging announced flagship store in Lynx Special episode during a mysterious new double 11, which sells for 99 yuan.
After this message is issued, netizens have speculated that this new product in the end millet is Gesha. In the opinion of most users, this should be 99 yuan new enhanced version of mobile power, of course, there are some users it may be whimsical representation of a 4G MiFi.
Now, this mysterious new product has been released. It really is a new mobile power capacity reached 16000mAh, a full 50 percent more than the previous version of 10400mAh capacity, and provides two USB ports, an aluminum alloy shell material remains.
The official price is 129 yuan mobile power, but at double 11 period, millet Lynx flagship store price will be 99 yuan starting on sale.
Pictures from the official point of view, this 16000mAh mobile power should be a lot longer than 10400mAh version, but the latter should not be so wide, relatively speaking, is not difficult to carry.
Of course, it is able to bring the aircraft, this we do not need to worry.
s_673eb7372b3446c9a5ae9a0a1daa9b45.jpg s_9842e9dfd549454da57451846cc9ac90.jpg
pengonator
Mal sehen wann die in den Shop zu welchem Preis auftaucht. Wenn diese Powerbank nur 2-3€ teurer ist als die 10.400mAh Version wird die bestimmt der Hit und man muss wieder aufpassen da keinen schlechten Clone zu erwischen. Wenn das Teil verfügbar ist würde ich dann wenn der Preis stimmt auch zuschlagen.
Kenjo
Weiß jemand, was da für Akkus drin sind? Die längliche Form und die mAh -Angabe verwirren mich; ich schätze, man darf mit 6 16850 á 2600 mAh rechnen, oder? (15,6 Ah insg.)
J
johndebur
Noch ne kleine Info was verbaut ist.
99元 小米16000mAh移动电源能带上飞机吗? mydrivers
99 yuan millet 16000mAh mobile power can bring on the plane?
Previously millet announced that it will double 11 flagship flagship store in Lynx starting a 16000mAh mobile power, price 99 yuan, provides two USB ports, housing material is still aluminum, and compact, easy to carry, looks pretty not bad.
Lei Jun microblogging previously disclosed, millet this 16000mAh mobile power supply built five 18650 battery, 3200mAh, each section of the energy density of up to 725Wh / L, the main suppliers LG and Panasonic, than the previous 10400mAh battery only weight more than 20% However, capacity increased by about 60%.
So the question is, can bring on the plane?
According to the Civil Aviation Administration regulations on passengers carrying the opportunity of lithium-ion batteries, spare lithium-ion battery rated power does not allow 100Wh (single). That is, this energy can be carried below.
According to Millet staff @ Li Zhuo Qi explanation, millet 16000mAh mobile power specification is 60Wh, at the bottom of the power supply also made a clear identity, it can pass through security, you can rest assured that use.
So to count the words, this power should be in the rated voltage of about 3.75V (60Wh = 60VAh / 16Ah = 3.75V), output voltage and current is not yet determined.
J
johndebur
Review und wie es innen aussieht:
能充三个半!小米16000mAh移动电源测试 mydrivers Seite 1
Seite 2
Übersetzung
Seite 2
To sum up:
Millet 16000mAh mobile power in the design for the extension of the previous design, all-aluminum alloy material, and some of the original hand chamfered slightly more rounded, coupled with slender shape, more conducive to grip.
Meanwhile, it is also a 18650 lithium batteries, thanks to the density of the 2600mAh upgrade to 3200mAh, increased by only 40% in weight based on the capacity increase by nearly 60%, the price of 129 yuan a comprehensive point of view, the product is more sincerity .
Enhance the capacity and indeed brought more adequate electricity supply, storage capacity measured 16000mAh really should not be underestimated, given the Meizu MX4 filled a full three times also filled 67% of the electricity. In addition, the power output simultaneously supports two USB ports, ideal for everyday travel standby.
Of course, the greater capacity will inevitably affect the charging power supply itself, even with 5V2A charger also requires nearly all full nine hours, so if you are taking a trip, remember to charge before going to sleep on, so as to make the best use, and my heart also practical.
s_0c9e5ea3bc9f4edaa361ef3ccec9df34.jpg s_5fece362b45746e1bd7beb8d9d299b11.jpg s_70d81cdb7ce642d3b1a168769a9eeb2b.jpg s_71ac35e004d44d8192f4b4be4f34b58c.jpg s_138c4eb2dfc94480a9f610e642c79f0b.jpg s_3627bec6b9eb4b128ed7b88649c231d0.jpg s_870062671fac4b4cb18a014d6fd24dcc.jpg s_ef989e060ffa46dea622b9de4853df9c.jpg
Chocoball
Heute ist mein 16000mAh von Tinydeal eingetroffen. Sieht fast so aus wie 2 5200mAh aufeindander und für die Liebhaber, das Gewicht ist 343g gegen 255g vom 10400mAh.
v.L.n.R. 16000mAh - 10400mAh - 5200mAh
Ich warte noch auf meinen 5000mAh dann ist die Familie komplett.
Golden_Monkey
Hast du geschaut ob die Original ist?
Die Bilder bei der 10400mAh verwirren mich, einmal in einer Papierpackung (kenne ich) und eine in einer Plastikverpackung.
Irritiert hat mich, dass die blaue LED hat.
Die Original hat weiße LED. Da, dass Bilder von Kunden sind weiß ich nicht ob die da wirklich gekauft haben.
Würde gerne bestellen aber will eine Originale.
Zudem was für eine Versendungsdienst hast du gewählt?
Chocoball
Welchen Bilder vom 10400mAh verwirren dich? Hast du jetzt eins irgendwo gekauft die blaue LED hat?
Es gibt schon Vergleiche im Internet zwischen Original und Fake.
Beim 10400mAh gab es am Anfang Plastikverpackung und weil Kunden sich beschwerden über die Verpackung (Kratzer auf das Powerbank) hat Xiaomi deswegen die Verpackung geändert.
Habe auch bereits ein Vergleich vom 16000mAh gefunden. Meins ist Original und wenn Fake hatte ich Ida von Tinydeal um eine Lösung gefragt.
KloNom
Ich habe soeben die beste Xiaomi Powerbank Werbung ever gefunden :grin:. Für alle die sie noch nicht kennen:
Edit: Mist, gerade gesehen, dass es nicht die selbe Kapazität ist :grin:
aryo187
Eigetlich wollte ich diese Powerbank auch haben, fühle mich aber grad irgendwie verarscht wenn ich die mir hole.....
Geile Werbung ^_^
