Leagoo Lead 1 - 5.5" HD OGS IPS, Wake Gesture, KitKat 4.4.2, Metallrahmen
s7yler
Youtube.com/s7yler
Leagoo Lead 1, OGS HD 5.5" Wake Gesture, KitKat 4.4.2, 5MM Metal Frame, MTK6582 1.3Ghz.
Habe es von hier: http://www.dhgate.com/product/leagoo-lead1-5-5-quot-hd-ips-lcd-android/117320220.html man kann es auch bei efox hier bestellen http://www.efox-shop.com/leagoo-lead-1-mtk6582-13ghz-quad-core-55-inch-1280-720-ips-screen-android-442-3g-smartphone-g-293011
UNBOXING
MEGA REVIEW (26 Minuten + Pros & Cons)
Kamera Samples:
http://peecee.dk/uploads/072014/IMG_20140726_124204.jpg
http://peecee.dk/uploads/072014/IMG_20140726_124101.jpg
http://peecee.dk/uploads/072014/IMG_20140726_123717.jpg
http://peecee.dk/uploads/072014/IMG_20140724_125738.jpg
http://peecee.dk/uploads/072014/IMG_20140724_125420.jpg
http://peecee.dk/uploads/072014/IMG_20140727_125037.jpg
ROM (pre-rooted):
http://www.needrom.com/mobile/leagoo-lead-1/
Official ROM (30/8)
http://www.needrom.com/download/leagoo-lead-1-2/
ROOT Metode (drück "Spoiler" in die rechte Seite - ist in englisch)
Thanks to de vetnek for the method! written by s7yler, this is how I rooted the Leagoo Lead 1. All normal tools will fail like vRoot, Shuame, Kingo, Towelroot, Framaroot
0. Enabled "USB debugging" in "Developer options" on the phone
1. Went to http://www.kingoapp.com, downloaded and installed the windows program "Bootloader unlock for Sony"
2. Ran the program on the PC, connected the phone and pressed unlock. It then rebooted the phone to fastmode, then it hanged!
3. Then I pulled the battery out (but I let the USB cable be connected still! and the "Bootloader unlock for Sony" program running still on the PC, I then inserted the battery again and hold volume up plus power down. Then I choose Fastboot and the bootloader program proceeded and ended finishing.
4. After that I downloaded Kingo root tool, installed on PC, ran it, connected phone, let it run through the whole process, where it will reboot and check a lot of times. But it will then end with Roof failed! (after all tries is run).
5. Then I installed Mobile Uncle Tools 2.9.9 (just the newest) and went to MTK engeering mode (MTK) and then swiped to the part called "log and debugging" tab an select "User2root", and the selected Root.
6. Then I checked with Root checker, but it would say not rooted!
7. Then I ran MTK droid tools, connected the phone! and MTK droid tools will show ROOT and green square!
8. Then I went to tab 2 in MTK droid tools, and send the SuperSU into the phone, after that I could se a lot happening on the screen of the phone, so everything was installed. All went ok.
9. Rebooted the phone
10. After that I now had SuperSU, Mobile Uncle and Root explorer installed, now I again ran "Root Checker" and this time it would display ROOT in green!
11. Done!
Handy Spezifikationen: (Von Web kopiert!)
5.5 inch IPS OGS Screen 1280 x 720 pixels
MTK6582 Quad core CPU, 1.3GHz
GPU: Mali-400 MP
Cameras 5.0MP front camera, 13.0MP back camera with flashlight
Operation System: Android 4.4.2
Dual SIM Card Dual Standby
RAM: 1G / ROM: 8GB
Network: GSM900 GSM1800 WCDMA GSM1900 GSM850
Wake Gestures
CPU: Quad Core
Feature: with Touch Screen with MP3 Video Player With Ebook with WiFi with GPS with Bluetooth with Email Dual Sim Card MMS
Pros:
Bildschirm ist ganz schwarz (mehr als z.B. bei Elephone P2000) wenn aus
Es ist ein IPS OGS Bildschirm mit sehr guter Betrachtungswinkel
Der Preis ist sehr gut
3D Spiele laufen sehr gut! (z.B. Modern Combat 5)
Doppel-Tippen auf dem Bildschirm zu wecken, oder zeichnen Sie z.B. ein C um direkt in die Kamera zu gehen.
Autofokus in die Kamera ist sehr gut, man kann auch die Lautstärke-Tasten als Kamera Auslöser Taste benutzen.
Die 3 Touch Buttons haben Rücklicht
Material und Design ist sehr gut
Das UI ist Flüssig und sieht gut aus (Leagoo UI).
Hat Android Kitkat 4.4.2 (mit ein Leagoo skin)
Wirelesss OTA updates funktioniert!
Cons:
Kein NFC oder OTG
Kein Notifikations LED
LED flash ist nur ein normalen weissen LED. (nicht so hell).
(hat aber Beleuchtung in die Touch Buttons)
Hat nicht so viele Sensoren, z.B. kein Kompass
Der sound über Bluetooth war bei mir nicht so laut
Handy wird bei 3D Spielen wie gewohnt ein wenig warm (35-45 grad laut BatteryBot)
Leider nur ein MTK6582 mit 1GB ram und 8GB rom, aber für der Preis ist das OK!
(Leistung ist aber immer noch sehr gut, und 3D Spiele laufen super)
Nur der Metalrahmen ist 5 mm, Handy ist eher 8.2 mm dick in die mitte
X
x990
Bekomm das Rooten nicht hin. Der Bootloader Unlock klappt nicht trotz Batterierausnahme.
X
x990
Leider hab ich jetzt ein ganz anderes Problem. Habe versucht die vorgebetet FW einzuspielen mit dem SP Flash Tool. Das Handy hat aber das flashen aber nie zugelassen. Jetzt geht das Handy gar nicht mehr an. Aber es wird erkannt. Wenn ich die FW einspielen will kommt aber immer eine Fehlermeldung. Wie komm ich da jetzt weiter?
Es wirkt als ob es in irgendeinem Modus ist wo es nicht mehr rauskommt...
X
x990
Aktuell wird das Handy auch nicht mehr erkannt. Wenn ich es anstecke findet der PC ein USB Gerät das wars. Flachtool erkennt nichts. Hab die V5.13.53.200
Ich hab nichts gemacht und jetzt ist es futsch oder wie?
Es wird nur der MTK USB Port erkannt. :(
X
x990
Anscheinend nicht... Es wurde beim ersten Anschließen auch sehr warm, ist vielleicht was durchgebrannt? Ich mein wir reden von nem 80 EUR Handy...
X
x990
Laut Video brauch ich wohl ein Backup was ich aber nicht habe. Kannst Du mir eins schicken? Oder kann ich die Rom vom needrom nutzen? Die geht anscheinend aber nicht...
X
x990
Also ich lade jetzt die offizielle Rom von Leagoo weil bei der needrom Version kommt immer ein DRM Fehler beim flashen...
X
x990
An wenn kann ich mich wenden wenn es nicht klappt. Aktuell wird das Handy gar nicht mehr erkannt per USB. Da kann ich auch nichts versuchen zu flashen. Wer kann mir da helfen auch gegen Bezahlung.
X
x990
Brauch man einen vollen Akku damit das Handy noch erkannt werden kann. Der ist nämlich alle und glaube nicht das dieser lädt.
sawfish
