Coolpad 9976A - 7" WUXGA dual sim NFC 2GB RAM 8GB Rom 4000mah
J
johndebur
Noch ein Vergleich zwischen dem Coolpad 9976A und Huawei mediapad x1:
laut PConline ist das Coolpad besser verarbeitet :)
细节至上 7寸酷派大神鼻祖地位已被撼动? PConline
Übersetzung
Details of the first 7-inch Cool Great God originator position has been shaken?
[Experience] PConline 7-inch large-screen phone as originator, Cool Great God once appeared to attract the attention of many users and craze, in addition to selling 7-inch screen, a solid body work, powerful performance and entertainment are all Cool God is winning big killer. And recently also launched the same glory is the glory of X1 7-inch screen, a great challenge to the god of cool style. Here we see if the god Cool 7-inch screen originator position has been shaken?
Spread Analysis:
Cool great God is priced at 1,888 yuan, while the price of 1799 yuan X1 glory. A difference of 89 yuan, consumers may think the same 7-inch large-screen phone, select glory X1 will be more cost-effective. Cool Great God more than 89 yuan, but in screen design, exterior cameras also done with the materials, workmanship also used CNC aircraft-grade aluminum metal was used in the high-end flagship, sound Dolby 7.1 surround sound aspect and dual speaker design . Cool 1888 yuan visible god of cost thus be reflected. As a 7-inch screen phone originator status Cool Great God still very competitive.
4402443_1.jpg 4402443_2.jpg 4402443_3.jpg 4402443_4.jpg 4402443_default1.jpg 4402443_img_1651copy.jpg 4402443_img_1652copy.jpg 4402443_img_16512copy.jpg 4402443_IMG_1651456copy_thumb.jpg 4402443_initpintu.jpg 4402443_initpintu_2.jpg 4402443_initpintu_3.jpg
J
johndebur
Das Coolpad Great God wird es bald auch mit 2GHz MT6592T CPU geben, nennt sich dann 9976T.
Es ist auch etwas dicker. Anonsten was noch alles anders ist, ist noch nicht bekannt.
酷派大神升级版来袭 采用2GHz高频率八核 mtksj
Cool Great God struck using an upgraded version of the high frequency eight -core 2GHz
Yulong Coolpad great efforts to build the Two Tools " ax ", the giant screen of eight nuclear power of God no F1 so bursting with popularity , but also hit a remarkable achievement, one of the big -screen control into severe selection , the machine incorporates 7 inch screen, eight -core and 2G memory on a mainstream concern , such as the current configuration, the price is higher than F1 thousand dollars, has recently purchased the spot without an appointment . Now we have good news came , the Ministry has been suspected Cool almighty god of the upgraded version of the new network through certification.
The new machine is similar to an internal number and the Great God - Cool 9976T, both just not the same suffix to "T" suffix products usually represent support TD-SCDMA network, but the 9976T is still a new machine to support China Unicom 3G. Cool photo and did not find the net with a difference 9976A 9976T , is still one of the fuselage , SIM card slot , SD card digital design of the fuselage on the left side , only slightly different thickness , the data show 9976T measurements are 185 * 104.5 * 7.8mm, great God was 7.6 mm , and perhaps former battery capacity will be greater.
The most obvious upgrade the processor should be part of the original Great God uses the 1.7GHz frequency MT6592 primary eight-core , emerging 9976T is equipped with 8 -core 2.0GHz processor main frequency should be the MTK MT6592 high- frequency version , MTK6592 2G frequency current domestic use only a handful of products , which will undoubtedly be an upgraded version of the god a big selling point.
Other specifications have been released in line with the great God, and there is 7 inches 1920 * 1200 resolution screen , 2GB of memory to run and 5 million / 13 million pixels dual camera , Android 4.2 system , support for memory expansion . Great God some of the features may also be applied to the upgraded version of the body, such as LTPS screen + full fit three generations of Corning Gorilla Glass , Sony stacked camera and Dolby sound , etc. , will have to upgrade the rest to be further digging .
Union and other manufacturers in China Cool , Cool , and a 7-inch Huawei launched the first cross-border tablet phone , shortly before the glory Huawei X1 is listed as a direct rival to the great God , snatched the limelight a lot of the former , using the MTK current performance great God upgraded version of the strongest processor may become a new electricity supplier Cool weapons , this giant screen phone battle will certainly be more exciting.
J
johndebur
Nein außer die haben noch diesen LTE chip mit eingebaut. Aber da muß man noch auf die restliche Hardwareinfo warten, was noch alles anders ist :)
J
johndebur
Auf der CITE wurde das Coolpad Great God mit LTE Modem vorgestellt. Es unterstützt FDD-LTE + TD-LTE.
联发科LTE渐行渐近 酷派大神4G版CITE展出 mtksj
MediaTek LTE version is coming Cool Great God exhibited 4G CITE
If 64 is also relatively distant from the general public , so 4G is like an irresistible trend of blowing, remove giant collective force 4G, that small manufacturers are not far behind to launch 4G mobile products , recently the ongoing China Electronic Information Expo proved 4G hot . Yulong Coolpad 4G Specifications on the most active , is expected this year will launch 30 models of 4G products , the estimated 40 million units shipped , there have been a variety of LTE new listing.
The CITE 2014, Cool addition to publishing S6 Unicom / mobile version , there is a special LTE products on display , the machine is a cool version of the Great God 4G, a continuation of the original eight-core MT6592 / 4 inch high-definition screen / 2G RAM and the same high standard supports LTE networks.
Information display , Cool Great God 4G version still uses the MT6592 eight-core processor , but it can support TD-LTE and FDD-LTE network , it should be added MediaTek latest LTE MODEM (MT6290), which is earlier MediaTek executives said AP + MODEM mode , allowing rapid product upgrades to existing 3G 4G. According to the news industry, MediaTek MT6290 is now in volume production, no doubt very soon we will be able to see the program 's built-in MTK 4G smartphone market.
Cool Great God 4G also worked in a recent edition of Unicom Partner Conference exhibit frequent exposure mean big God 4G version will soon be listed , will become the first built-in MTK chips listed on 4G phones is still unknown.
http://tech.china.com/pic/fabuhui/11151140/20140410/18442621.html
18442621_2014041110385313133800.jpg 18442621_2014041110385021947100.jpg 18442621_2014041110385045979900.jpg 18442621_2014041110392192161100.jpg 18442621_2014041110422333015800.jpg
thor2001
Die sollten lieber dafür sorgen, dass man LTE und WCDMA auf beide Slots (um)schalten kann.
Android 4.4 wäre auch nicht schlecht, wenn man liest, dass das für die Umis noch diesen Monat kommen soll.
Grüße
dinox
Hi
Guys, I need help.
I ordered from merimobiles this phone. Momentary I have Elephone P6S.
I saw review http://www.chinasmartphonereview.com/coolpad-9976a-a-7-inch-phablet where wrote main camera is impressive, but now I saw review on http://www.areamobile.de/tablet/coolpad-halo-test where wrote camera is bad.
Please tell me what is true, if camera on Coolpad 9976A is not better than on Elephone P6S I would like to cancel my order.
Maybe better choice for camera quality is to buy ZTE Nubia Z7 2K or Max, or ZTE Nubia X6....But they are expensive.....
I need dual sim smartphone not below 5,5 inch with great main camera and battery. Price not over 400 euro.
Help me
Adistan
