Help: Need ROM MT6572 (fake GT-i9500) | BRICKED!
xeon135
hi everyone...
i'm newbie here and i have bricked my phone a few weeks ago and need ROM to reflash it...
thanks in advance..
the specifications i copied from MTK Droid Tools before got bricked as described below:
Hardware : MT6572
Model : GT-I9500
Build number : JDQ39.I9500XXUAMDE
Build date UTC : 20131219-040923
Android v : 4.2.2
Baseband v : MOLY.WR8.W1315.MD.WG.MP.V1, 2013/05/22 10:08
Kernel v : 3.4.5 (liuxiuyun@mht-10) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 SMP Thu Dec 19 12:07:29 CST 2013
Uboot build v : ----- should be root shell
LCD Driver IC : 1-nt35510s_mipi_fwvga
a few of captured device specification link
list of ROM i have try link
coolicool
Local Warehouse in Europe
can you take some pictures of your smartphone? so we can make sure what model it is of your smartphone then you can look for the right rom.
tommy0815
working with droid tools and no having backup...shame on you man :/
only thing you can do is go to needroms and search for a rom and just try.
xeon135
thanks for your reply...
my phone is a fake sam*ung S4 GT-i9500 (china phone), 5 inch screen with 854x480 resolution... with the specification as described above...
a lot of picture when you google it, if only need just the picture.[DOUBLEPOST=1391869905,1391869711][/DOUBLEPOST]
yes... what a shame...
i flash it because "root problem" and "GPS Lock" problem...
i have try to post on www.needrom.com and there still no answers yet...
i have download and flash more than 30 ROM and no one suit until now... :(
xeon135
i bought it from a local store.. personal actually...
i try more than 30 ROM before i post here...
the 1st ROM when it bricked is here
this is the data i saved before got bricked.
in fastboot mode, written MT6589, but from CPU Odentifier and MTKDroid Tools detected as MT6572 as follows
Hardware : MT6572
Model : GT-I9500
Android v : 4.2.2
xeon135
I have seen your Custom Build Version.
I found this on Google: click
Now we have more details for search
EDIT:
and that looks very fine: click
thank you for your response rumpelstilzchen
at the first link... mentioned that device using double SIM, but mine using 1 SIM...
all the specification looks same as mine...
at the scond link you give ROM I9500-M6572, and i already try to flash my device with it... and still no luck...
:([DOUBLEPOST=1391880506,1391880372][/DOUBLEPOST]
did you already tried this one?
i9500
thank you... but i already try to flash with that ROM (mt6572_s4_sendegel_no6589_FlashTool)
still no luck :(
this is the list of ROM i try:
tommy0815
and why you don't go to your local dealer and ask him for a backup?
Edit: because i think the main reason why you didn't find the correct FW is your LCD driver. I actually didn't find any Version with this driver!
xeon135
if he can give some help... then i won't post here...
thats my problem... i have found ROM that have same LCD driver, my phone boot up, sound heard, button functioned (vibrate when touched) but the screen still black, the best condition since bricked...
some proof...
xeon135
ok...than format your phone with flashtool and flash this rom again...i think it will work
well.. i did... change scatter, change kernel, etc...
still no luck... i hope someone will give "miracle ROM link"... or someone with same spicified phone upload the exact same ROM...
what a weird phone and ROM version i think...
as you said, I actually didn't find any Version with this driver... :(
xeon135
sorry but i think we are talking about diffrent things. Please tell me how you format your phone!
is that so?
sorry then...
well.. i format it with SP Flash Tools, exactly SP Flash Tool v3.1344.0.212.
choose the scatter >>> format >>> take the battery out >>> put on USB Cable...
wait a little bit until OK (with the green circle) pop out..
#CMIIW
tommy0815
please try this again:
please load the scatter from the rom (which works a little bit) in flashtool than format in flashtool the whole flash!
aftr that use "download" to flash complete Rom INCLUDING the preloader!
