J
johndebur
Wird langsam konfus mit den ganzen Gerüchten um dieses handy, mal heißt es TD-SCDMA mal WCDMA. Naja wird ja am 16.12. vorgestellt
竟然是5英寸720P屏? 荣耀3C大量内部宣传图出现 mtksj
Turned out to be five inches 720P screen ? Figure 3C glory appears a lot of internal promotion
Among the many rumors in the trail , finally appeared more reliable glory 3C core configuration information , called @ Ascend_ Huawei Hass microblogging has exposed a group of glorious propaganda Figure 3C product description , looks should be the internal flow, reveals some of the glory of 3C configuration information . 3C which is surprising even with a 5 -inch screen rather than 4.7 inches , and a glorious 3C configuration changed.
According to this group of pictures you can see the glory of 3C 's screen is 5.0 inches , before rumors of 4.7 inches, followed by 3C rumored qHD resolution is not the HD, 720P resolution of the current situation seems to be more credible. In addition to screen size surprisingly , 3C also uses LTPS ( low temperature polysilicon technology ) display panel euphemistically as "black waterfall screen" , from the previous spy photos found extinguished screen effect is quite good .
The official who had highlighted the aircraft's pictures would be more powerful, have glory 3C Samsung 5MP camera self-timer , F2.4 aperture, Huawei 's own self- technology blessing, support a variety of skin function and several filters, main 8 million pixels camera , using Sony's second-generation BSI technology , F2.0 aperture / 4CM Macro / 28mm wide angle / 1.12μm sensitive area , also equipped with Huawei 's own patented image processing technology , we can imagine there must be photographed surprise.
In addition to the above two points , and the glory 3C equipped MT6582 quad-core processor should be no suspense , as to whether it is 2 +8 G memory combinations and 2300 mA battery capacity is true , I believe that no one is currently not sure of .
