Star ulefone U9592 - 5" HD MT6592 2GB Ram 16GB Rom 2/8MP Cams
J
johndebur
MT6592 Handy von Star:
http://www.ule-star.com/?Product/20.html
■ MT6592-1.7GHz 28 nanometer quad-core speed (low-power Cortex-A7 architecture)
■ 5.0 英寸 HD 1280x720 IPS screen
■ Memory RAM: 2G + ROM: 16G
■ Front 2,000,000 + 8,000,000 after AF selectable (with flash)
■ 3G (WCDMA / GSM)
■ 9.4 毫米 thin body ■ 2800 mAh Li-ion battery ■ Smart Cover comes equipped with Android 4.2.2 system ■ ■ Support for 3G, Wi-Fi CERTIFIED Miracast, EDGE, HSPA +, HSUPA
■ Wi-Fi CERTIFIED Miracast, EDGE, HSPA +, HSUPA
Detailed explanations.
  • Style: PDA touch Size: 140x71.8x9.4mm
  • Product weight: 163 g Hardware platform: MT6592 - 1.7GHz 28 nanometer quad-core speed (low-power Cortex-A7 architecture)
  • Internal (memory): RAM: 2G + ROM: 16G
  • System: Android 4.2.2 OS
  • Mobile phone standard: WCDMA / GSM
  • Support band: WCDMA 2100/850 (HSPA +) and GSM 850/900/1800/1900
  • SIM card: Dual card dual standby Navigation: Built-in GPS chip (GPS + AGPS)
  • Display: 5.0 inches HD IPS screen 16 million color main screen resolution: 1280x720 pixels
  • Camera: After the former 2,000,000 + 8,000,000 AF selectable (with flash)
  • Wireless transmission: 3G, Wi-Fi CERTIFIED Miracast, Bluetooth 4.0, EDGE, HSPA +, HSUPA
  • Modem features: Mobile AP - wireless AP (WLAN hotspot)
  • HSUPA (High Speed Uplink): Supports up to 5.76 Mbps;
  • HSPA + (High Speed Downlink): Supports up to 42 Mbps;
  • Light sensor: Support Proximity sensor: Support Gravity Sensor: Support
  • FM function: Support
  • Java extensions: Support music / video taped: Support
  • WAP browser: Support handwriting input: Support for multiple languages Support the expansion card: TF Card (up to 32GB)
  • Battery parameters: Standard Battery capacity: 2800mAh
  • Talk time: 120-150 (Unit: minutes)
  • Standby time: 120-180 (Unit: Hour)
  • Phonebook capacity: 10000 Group SMS / MMS: Support headphone jack: 3.5MM standard interface
  • Charging Interface: mini usb 5pin Interface
  • Color: Ivory, sapphire blue
  • Included: Smart Cover
Banner.jpg T2.K3wXXlaXXXXXXXX_!!27189466.jpg T2HUZvXdVaXXXXXXXX_!!27189466.jpg T2Qw.xXXlXXXXXXXXX_!!27189466.jpg T2SagxXhXXXXXXXXXX_!!27189466.jpg T29LowXelaXXXXXXXX_!!27189466.jpg
Nomex
wer schnell ist kanns ja noch bei cect bestellen. wäre gespannt wie da der akku ist. und wie immer die preisfragen, was vom original passt
Rosenklotz
Flasht mich irgendwie nicht. Okay, Octacore, schön und gut, aber der ganze Rest? 9,4mm dick, 5" 720p, 2/16 GB... nee, irgendwie unattraktiv für mich.
SnowyNight
die 720p bei 5" ist das einzige was ich wirklich mag..
weil das sicher auch akkuschonend ist...
mein note 2 hatte auch 720p mit 5,5" habe da nie pixel gefunden o.o aber naja ^^ geschmackssache
Rosenklotz
Ich finde die Auflösung und Displaygröße auch völlig OK, aber die braucht keinen Octa, da tut es auch der 6582. Und dann bleibt ja die Frage, welchen Vorteil das Phone mir bietet?
Smuji
Das ist aber nicht wahr. Das teil hat nur eine aufloesung von 854 x 480 pixels
Habe es mir bei mixeshop bestellt, dann haben sie mich heute angeschrieben und mir gesagt dass es ihnen leid tut, dass sie sich vertan haben und das handy doch nur 854x480 pixel hat.
Ich verstehe die welt nicht mehr. Ab und zu findet man das handy im internet mit angeblich hd aufloesung und 2800 mah akku und manchmal nur 854x480 und 2300 mah....
Gibt es verschiedene versionen oder was
