Suche Smartphone aus Hochwertigen Materialen, Alu, Glas...
Technoolli
Hallo an alle Profis !
Es gibt ja auch viele HTC One Clone aber da gibt es ja auch welche die echt nicht gut sind, jetzt bin Ich irgednwie auch noch auf folgende Clone aufmerksam geworden:
- OrientPhone P6 Plus für 229€:
http://www.orientdeal.com/orientphone-p6plus-6.0-inch-fhd-screen-mtk6589t-1.5ghz-quad-core-smart-phone-2gb-32gb-12.6mp-camera-android-4.2-os-3g-gps-nfc.html
OrientPhone P6+ Android 4.2 Phone Specifications:
BrandOrientPhone
ModelP6+
ColorBlack / White
TypeBrand New
Form FactorTouch screen
Operating System Android 4.2
ProcessorMTK6589T Quad core , Cortex A7 1.5GHz
RAM 2GB
ROM 32GB
Support extend card 64GB
Screen
Touch screenIPS, FHD Capacitive touch screen
Display Size(Inch) 6.0 inch
Screen Resolution 1920*1080 pixels
Display Colour 16000K colors
NetworkingGSM/WCDMA
Frequency2G:GSM850/900/1800/1900MHz; 3G:WCDMA850/2100MHz
Data transfer GPRS/HSPA/EDGE
WIFIYES,802.11 b/g
GPS YES
Languages
Japanese,TraditionalChinese,SimplifiedChinese,Afrikaans,Indonesian,Melayu,Catalan,Czech,Danish,German,
EnglishSpanish,Filipino,French,Croatian,Isizulu,Italian,Swahili,Latvian,Lithuanian,Magyar,Netherlands,Norwegian,
Polish,Portuguese,Romanian,Romansh,Slovaklanguage,Slovenian,Finnish,language,Swedish,Vietnamese,
Turkish,Greek,bulgarian,Russian,Serbian,Ukrainian,Hebrew,Arabic,Persian,Hindi,Thai,Korean,ect.
SIM TypeOrdinary SIM
SIM Slot2
Network StandbyDual Network Standby
Network ConversationOne-Party Conversation Only
CameraDual Cameras, 5.0MP front camera, 12.6MP back camera,with flashlight and auto focus, up to 4096×3072 pixels resolution
FlashYES
Auto FocusYES
Touch FocusYES
Support Format
Audio File Format MP3, WAV, ARM
Video File Format 3GP, MP4, RMVB
Image File Format JPEG, BMP, GIF, PNG
FM Radio YES,earphone needed
TVNO
SensorG-sensor,P-sensor,L-sensor
BluetoothYES
I/O InterfaceMicro USB, 3.5mm Jack, Mirco SD slot,SIM slot
Battery TypeLithium
Capacity2800mAh
Standby Time About 2~3 days
Charger USB, Travel Charger
Input Methodhand write,keyboard
SoftwareNFC,MP3, MP4, calculator, ES file management, stopwatch, calendar, alarm clock, Google play, E-mail, G-mail, etc.
Dimensions / WxDxH 83.2x166x7.6mm
Net Weight232g(with battery)
- UleFone P6 für 219€ + Karte 32GB 27,99€:
http://www.efox-shop.com/ulefone-p6-mt6589t-15ghz-quad-core-android-42-60-zoll-fhd-bildschirm-3g-handy-dual-sim-dual-stand-g-290109
Funktion
Touchscreen
Multi-Touchscreen (Kapazitativ)
Frequenz
Quad Core, 1.5 Ghz
Betriebssystem
Android 4.2
CPU-Modell
MTK6589T
Anzeige
Browser
Unterstützt
Licht-Sensor
Unterstützt
Abstand Sensor
Unterstützt
Bildschirm-Auflösung
1920*1080
Bildschirmgröße
6.0 Zoll
Multitouch
5 Punkte Touch
Marke
ULEFONE
Speicherung
Hot-Swap
Nicht Unterstützt
RAM
2 GB
ROM
32 GB
Max-Speichererweiterung
32GB
Kamera
Blitzlicht
Unterstützt
AF
Unterstützt
Kamera Vorderseite
5 Megapixel
Serienaufnahme
Unterstützt
Kamera Rückseite
13 Megapixel
Video Wiedergabe
MP4/3GP/MPEG-4
Entertainment Funktionen
Radio
Unterstützt
TV
Nicht Unterstützt
Ebook
Unterstützt
JAVA
Nicht Unterstützt
Video-Capture
Unterstützt
Musik Wiedergabe
MP3/AAC/AAC+/WAV/AMR
Verbindungen
Bluetooth
Unterstützt
GPS
Unterstützt
Kabellos AP
Unterstützt
Weitere Details
Gravitation Induktion
Unterstützt
Kopfhörer
3.5mm
Datenkabel
Mini USB
Schützende Hülle
Nicht Vorhanden
Personal Assistant
Office
Unterstützt
Email
Unterstützt
Taschenrechner
Unterstützt
Wecker
Unterstützt
Audioaufnahme
Unterstützt
Anruf-Aufnahme
Unterstützt
Netzwerk
Produkttyp
Standard Handy, Touchscreen Handy, Android Phone, 3G Handy
WIFI
Unterstützt
Farbe
Schwarz, Weiß
UMTS/3G
Unterstützt
Smartphone
Ja
Netzwerk-Standard
Dual SIM - Dual Standby
Netz-Frequenz
GSM 850/900/1800/1900, WCDMA 850/2100
Speicherkarten-Typ
Micro SD
Welches Smartphone gibt es da sonst noch oder ist besser ?
Soll folgendes min. haben:
- Quad-Core
- Aus hochwertigen Alu
- Selber flashen möglich sein, also updatebar Android, rooten usw.
- Gute Kamera
- Akku austauschbar
- Nicht zu teuer....
Dankeschön.
Das ist die Kopie des Huawei Ascend P6.
Es wurde hier im Forum auch schon einmal als Jiake P6 vorgestellt.
Es ist auch das Haipai P6s: Link
hannimuun
Ja, nur blöd daß dafür keinerlei schützende Silikon/Plastikhülle hergestellt wird;
ein einziger Fall auf Asphalt und das Ding ist auf einmal sowas von unsexy...
guesa
Für diese preise kann man auch locker das original huawai ascend p6 kaufen....;)[DOUBLEPOST=1387263107,1387262760][/DOUBLEPOST]Das original huawai ascend p6 kostet hier in deutschland 258€. Die einzige alternative sind derzeit das haipai oder jiake...das style ist das gleiche
synk
điện thoại Man
Das Original P6 hat 4,7", dieser Nachbau 6"....so flexibel kann keine Hülle sein, dass sie passen würde.... :hehehe:
verschossen vom ZP980H
guesa
@hannimuun ...du hast natürlich recht....denn die schutzhüllen für das ascend passen alle nicht....[DOUBLEPOST=1387263838,1387263697][/DOUBLEPOST]Hey @synk ..musstest du das jetzt schon verraten?:p
matt_smith
Die P6 Klone sind noch sehr neu. Ich habe ein Jiake P6 bestellt welches sich gerade im Lieferwagen befindet und in den nächsten 60 Minuten bei mir eintreffen sollte. Also verfolge einfach mal den Topic des Jiake P6.
taikee
Vielen Dank für diesen tollen Beitrag und für die Vorstellung der tollen Phones.
Wer hat noch tolle neue Smartphones mit 5,7 -6 Zoll die viel für das Auge bieten.
Am besten welche die demnächst zu haben sind und schon auf octa core laufen :grin:
taikee
ein up für diese, meiner Meinung nach, sehr wichtigen Diskussion da viele, sofern die tech. Details stimmen, nach dem Äusseren gehen.
Wer kennt weitere high-techs die auch was für das Auge sind?
taikee
Wenn es denn mehr tech als octa core und 2GB/32GB usw. gäbe könnte ich mir das iocean X8 schon antun. Es gefällt mir recht gut. Aber die Daten sind fast identisch wie von meinem THL T200. Daher warte ich noch.
Das Jiayu G6 ist vom design eher ne Note 3
Wer hat noch mehr leckerlies? :spiteful:
goll
