Newman K18 - MT6592 5" FHD 6,17mm dick OTG 5/13MP Cams TD+W dual sim
J
johndebur
Neues MT6592 Handy von Newman:
Hersteller: http://newman.mobi/
纽曼K18谍照曝光 八核平台/外形方正 mtksj
Newman K18 Spy Shots eight -core platform / shape Founder
MediaTek MT6592 uncertainty of production time after , Newman Newman 's phone immediately announced the eight-core product plans, will be launched later Newman K18, K2S and a 6- inch large-screen products, from time to analyze these three products may will adopt MTK6592 really eight nuclear program . Just recently , more than Newman K18 suspected spy real machine was exposed out of the phone's industrial design seems to be more of concern.Newman K18
This group of pictures is K18 main show back design , to be seen from the picture , Newman K18 back of the fuselage like a mirror generally very smooth, glare well, may use a special glass material to build, and some time ago Xiaolong XL waveguide exposure similar to that in anti-abrasion, scratch , etc. may have " miraculous " , which was at the same level design is also more difficult . You can see the entire machine was back to back plane , including the main camera, and almost no prominent element in the body , after the shell has Newman phone LOGO and official website and other information, if the aircraft is not a K18 , then, is bound to be three new machines in one .
Earlier news show, Newman K18 will be playing classic products , and the thickness is only 6.17mm, can be found under the spy photos , the phone is very slim indeed . Furthermore K18 will be equipped with a 5-inch screen OGS full fit , 1080P resolution , equipped with eight -core processors.
There is also a mysterious picture of the product emerges from the corner arc of view is not Newman K18, greater curvature of the phone four weeks , with ultra- narrow frame design, perhaps Newman three new machines in one . See below:
1-131103010FaA.jpg 1-131103010H5A9.jpg 1-131103010IS05.jpg 1-131103010K3314.jpg 1-131103012410426.jpg
MJ85
Eigentlich ein sehr schönes Gerät mit tollen Specs aber ich befürchte dass es einfach zu unhandlich ist. Genau wie das Xperia Z.
Wenn es 5" hat finde ich es nicht zu unhandlich. Habe schon das Newman K1 und das passt. Allerdings hat der Nutzer auf dem Foto entweder sehr kleine Hände, oder das Gerät hier ist definitiv größer wie 5".
Dirk
MJ85
Naja, auch 5" kann unhandlich sein, wenn es so harten Kanten hat wie das Z1 oder das Huawei P6. Es ist dann definitiv kein Handschmeichler und wird bei längerer Benutzung unangenehm. So zumindest meine Erfahrung :)
J
johndebur
Noch ein paar Fotos.
外观漂亮 纽曼K18大量真机实拍照 mtksj
Beautiful appearance Newman K18 lot real machine photos
Not long ago, there have been suspected spy real machine out of the Newman K18 is back, a lot of the real machine spy K18 has been exposed , it is understood the aircraft entered a trial production phase, the pictures appear real camera also works machines Although follow-up may make changes in the details , but the overall style is basically already fixed.
Real machine photos show K18 uses a law-abiding straight rounded design , rather than spread out before the rectangular style , the aircraft joined the metal elements enhance texture . Engineering machine has black, red two colors, red version with red not a large area , but only around the screen for the red dotted circle , starkly. In addition to the back of the machine is a rare three-stage design, the thickness of only 6.17 mm slim whether to support battery replacement needs further understanding.
This product was Newman dubbed " Classic K18" in the name , in addition to industrial design aspects of the upgrade, the core hardware configuration should be no shortage of things to watch . Known message display will be equipped with five inches K18 1080 full HD resolution screen, using OGS full lamination process , a black screen from the real pictures look excellent results . Another Newman K18 will be equipped with MTK6592 eight -core processor, from the "carrier class " configuration to analyze , 2G RAM/1300 Wan cameras may appear in mainstream configurations K18 body .
1-13111602400YS.jpg 1-13111602402S60.jpg 1-13111602403V09.jpg 1-13111602405V04.jpg 1-13111602410a11.jpg 1-13111602411S45.jpg 1-13111602412S37.jpg 1-131116024050S6.jpg
J
johndebur
das Handy unterstützt TD-SCDMA + WCDMA zusammen.
6.1毫米纤薄机身 纽曼K18已经入网 mtksj
6.1 mm slim Newman K18 has network
For the upcoming eight-core era , Newman Newman phones already made plans , three will be powered by eight-core chip MTK MT6592 product was exposed early to come out , and one of the most anticipated product of course is a slim figure and a high profile in the Newman K18 it. The latest good news is that Newman K18 has appeared in the Ministry of Industry Certification Center , this phone is also the first certified eight-core products.
K18 is the official definition of "classic" models, so we can find many products are not available in the past highlights Newman K18 body. The phone uses a unibody design, with impressive thin body, the thickness of only 6.1 mm , a width of less than 70 mm is also proof of the machine frame compared to the force . Another machine back using alloy material to create more beautiful on the grade.
In addition to progress on the appearance of the process , the core configuration of this product is also worth noting , 1.7GHz main frequency of the MT6592 eight-core processor , built-in 2G RAM +16 G/32G ROM 's large memory . 5-inch full- fit screen resolution of 1920 * 1080 , is said to be the original LG screen , Camera, using a combination of Sony's 13 million pixel main camera with 5 million pixels, vice camera , although very thin , but there is also the battery capacity 2000 mA . In addition it also supports OTG function , built-in gyroscope, electronic compass sensor.
It is particularly worth mentioning is that the one-piece design of Newman K18 only supports up to 64G memory card , also has dual SIM card slots ( external design ) can support TD + WCDMA dual-mode dual standby .
As the product of the net , you can see the phone Newman has done full preparations , K18 and K2S two eight -core products will be officially listed in December , and now the only unknown price only.
J
johndebur
Das Handy wird es in 2 Ausführungen geben, Klassik, was nur TD unterstützt und die Ultimate Edtion unterstützt WCDMA + TD. Die Ultimate Edition kostet 1299 yuans (155€). Im chinesischen heißt das Handy Newman Williams, allerdings mit Google übersetzt. Bestellbar am 28.2.
纽曼大威手机发布 八核最低999元起!mtksj
Newman Williams released eight -core handset lowest 999 yuan !
NEWMAN Newman phone after the first eight -core products K2S listed more than one month , another more is expected of the new machine - Newman K18 finally have clear pricing information and time to market , these two points are also many users focus . Williams named K18 to Newman , will launch the classic and Ultimate editions both versions , both prices and specifications are Xiangxi surfaced .
Newman Williams double version difference is that the memory specifications and network standard , classic version of the conventional combination 1G RAM +4 G ROM , support for TD-SCDMA + GSM dual sim dual standby , as previously advertised as Ultimate can support TD + dual 3G WCDMA dual standby , while backward compatible with Unicom / GSM mobile network , built-in 2G RAM/16G ROM memory. Configuration is not the same as the price of course is not the camera , Newman Williams Classic and Ultimate editions are priced at 999 yuan / 1299 yuan .
The remaining specifications no significant difference between the two versions , using 1.7GHz frequency MT6592 main eight-core processor , 5-inch LG display has a resolution of 1920 * 1080 , supplemented by full- fit technology, and a 5-megapixel 88 degree wide angle front camera , the main camera for Sony stacked 13 million pixels, the aperture of f/2.2, the standard 2000 mA battery , Android 4.2 system . Further aspects of a more complete sensor , equipped with gyroscopes and electronic compass , and the other to support OTG function.
Newman Newman Williams is this year's masterpiece , the main slim design , only the thickness of 6.17 mm , using unibody design , the border has only about 2.4 mm , the thinnest become Newman 's products, but also more grounded gas pricing , Viagra price of $ 1299 Ultimate Edition will be the first big market, starting in the official website on the 28th of this month , limiting users to buy an appointment .
bom
Kann irgendwer sagen, ob das Ding einen magnetischen Kompass hat, und inwieweit ein elektronischer kompass annähernd an einen magnetischen rankommt?
Dracki
