I purchased a Samsung Galaxy S4 Clone (Chinese) from Chinese border and brought it home, knowing it was a clone.
What I did not realize when I purchased it were:
The Clone looks just like ANY other S4 Clone you can read about on the Net (ALL of which mention the Android OS). I put Adobe Reader APK file and it says "Unsupported file format" or something similar, which means its not running Android.
I bought it ENTIRELY thinking of it as an Android device, and now i feel SO pi**ed off
My Questions are;
It used to boot with the "Samsung Galaxy S4 GT-i9500" Boot Screen, after i inserted a MicroSD memory card in it, it started showiong the "Android" Boot Screen BUT HEY, the Chinese could insert any video or image at the boot, that does not help the fact that it can't even run the Android Native APK file ..
Thank you ..
{ I CAN'T UNDERSTAND GERMAN }
- the Screen does NOT support the (now common) Auto-Rotate function
- it does NOT even have the Photo Zoom function {, to add to my headache, }
- turned out, it WAS NOT running an Android OS in the 1st place
My Questions are;
- How can i install Android OS in it?
- Could it be that its actually running Android, and i need to fix something for it to work?
- Has anyone else faced the same problem?
Thank you ..
